Question about Ovens
I have a Simpson 2001 68-642 oven and it would appear that thermostat has gone because it just keeps getting hotter and hotter no matter what the temp dial is on. I have had this problem before and called a guy out and as i recall he said it was one of the settings was incorrect rather than a physical fault... it was a long time ago though and I can't remember exactly what happened. Can ypou help?
  • 1462 Answers
SOURCE: NEFF Oven Model B1430NOGB/02 Oven Temp not heating above @50 degrees
probably the element. to save wasting money, check continuity with a multimeter
Posted on Jun 25, 2008
  • 338 Answers
SOURCE: Kenmore oven doesn't keep heat
im going to assume it is gas.. you may have a bad ignitor.. it is not gettin hot enough all the time to ignite the gas.. eventually it will not lite it at all..
Posted on Feb 15, 2009
Sea Breeze
  • 4655 Answers
SOURCE: New replacement thermostat needs calibrating on my Kenmore oven
There is no real way to calibrate the thermostat. Most ovens have the same problem. By lowering the setting slightly will help get a closer temperature. Sometimes similar thermostats are substituted and may not be exactly the same as the original that came with your oven. Hope my trying to answer your question was helpful, Thanks, Sea breeze
Posted on Mar 27, 2009
  • 1253 Answers
SOURCE: oven temp gets hotter than control indicates.
Alot of the thermostats are adjustable and can be recalibrated but when they act like this, it is best to replace them. It is just a matter of time before it quit all together. Electronic units are some what different.
Let me know what you do and I'll give you a hand in getting it going.
Posted on May 09, 2009
dniro592006
  • 121 Answers
SOURCE: Simpson oven 736 evolution turns itself on briefly then turns off
sounds like you have a control board problem
Posted on Jun 12, 2009
Hi, it's not the oven of my electric range that I have problems with. They are two of the top burners elements that keep getting hotter and hotter even when I turn the switch to a lower setting.
indicates that the thermostats in the switches are faulty find the service agent spares and replace the switches are ensuring that the thermostat is part of the switch
Jan 31, 2018 | Ovens
Temperature when using frigidare oven, keeps getting hotter and does not cool down
Good Afternoon Andrea,
I see that you're having issues with your Frigidaire oven, and the heating element being red hot the entire time you were cooking no matter how much you turned the temperature down.
I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your oven, you will need to set the clock by entering in the time and pressing start. Preheat the oven, to whatever desired temperature, and if it is still running hotter than it should be, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Apr 22, 2014 | Frigidaire Ovens
My new oven just keeps getting hotter and hotter. I think the thermostat dont work.
Hi, you guessed right. You need to replace the thermostat which is in charge of regulating the heat in the oven.
Take care
Jul 17, 2010 | Whirlpool RBS305PDS Electric Single Oven
Inconsistant oven temperature
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 25, 2010 | Ovens
When using the oven setting it justs get hotter and hotter.
tt sounds like the thermostat sensor
Dec 27, 2009 | Ovens
Oven temp gets hotter than control indicates.
May 09, 2009 | Ovens
Bottom oven gets extremely hot
It would appear you have a faulty thermostat that controls the temp. SUggest you get a new thermostat fitted.
Dec 08, 2008 | GE JTP27 Electric Double Oven
Simpson 2001 series upright electric stove oven does not get hot only gets warm
It could be the oven element (behind the cover plate in the back of the oven), or the fan not blowing the heat into the oven.
Aug 19, 2008 | Ovens
Stoves 720ef top oven warms but does not reach high temps. element replaced - no fix. thermostat ok as heating light cycles on and off at around 120 deg C, but reluctant to get hotter.
Have the same problem. Went and bought an oven thermometer from Lakeland and found that when the top oven thermostat was set to 160, the temperature only got to 140. I did clean the sensor inside the oven using a cleaner from Lakeland which did improve matters but it is still running cooler that it should. ( It takes at least 20 to 30 mins to warm up)
May 01, 2008 | Stoves 720EF Electric Double Oven
Ovens Logo
78 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
