Question about Craftsman Garden
I wish to know the proper mix of fuel and oil for the 25cc leaf blower
  • 1,041 Answers
Here is a Link to a free pdf download of a Fuel Ratio Chart:
www.rctek.com/pdf/fuel_to_oil_ratio_chart.pdf
I'd like to be able to tell you, but without the Model # of your machine, I'm unable to do so accurately. It should tell in your manual what the ratio is.
Good Luck!
Jim
Posted on Oct 10, 2010
  • Jim Parker
    Jim Parker Oct 17, 2010
    Was this helpful?
    Jim
Backpack gas blower
Monching, You will have to hope there is not too much damage done already from running straight Gas. Empty all straight gas from blowers tank and refill with proper minimum 50:1 gas oil mix. Start blower and run on 1/2 throttle for a few minutes to be sure its going to be OK. If seized, you will have to try and unseize and if lucky it may run if not too much damage internally. You should run a heavier oil to gas mix 32 or 40:1 in an engine that's been seized. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
this is what happens when someone run straight gas in two cycle engine
Fixing seized up echo weed eater
Stihl FS120 Grass Trimmer RAN WITH NO OIL IN GAS Blown Top End
https://www.askmehelpdesk.com/tools-power-equipment/ran-leaf-blower-without-oil-36071.html
Jul 12, 2016 | Craftsman 25cc 2-Cycle Gas Blower/Vac
What fuel do I put in the weed eater gas blower fb25?
Regular unleaded with whatever oil mix the fuel cap has on it.
Try to avoid gasoline with high ethanol content. You can look online and find alcohol-free gas in your area. You wont regret it!
Oct 05, 2014 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
What oil goes in crankcase of poulan leaf blower
Are you sure this is a four stroke engine, i thought all the small blowers were two strokes in which case there is no oil in the crankcase, the lubrication is mixed with the fuel
Feb 19, 2013 | Poulan Bvm200vs 200mph 25cc Gas Pro Leaf...
I don't know what fuel my leaf blower needs.
Almost every leaf blower uses gasoline mixed with 2-cycle mixing oil. Unless you have a larger, commercial model with a separate oil tank, you'll need to purchase mixing oil and mix it with your fuel. You can find mixing oil at PartsBuggy.com.
Oct 22, 2012 | Echo Garden
Need gas mix
check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.
Jun 03, 2012 | Craftsman 25cc 2-Cycle Gas Blower/Vac
Need gas mix solution
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil).Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.
Pull cord frozen
if it died while in use and you can't pull the starter cord the engine might have locked up was the oil/fuel mixed properly?remove the cover and see if the flywheel can turn
May 19, 2012 | Poulan Pro 25CC 2Cycle Gas Blower
TB BLOWER 25CC WHATS THE OIL/FUEL RATIO MIX???
Try 40:1. Better to have too much oil than too little. If you find the exact ratio then use that. ...Lee
Mar 12, 2010 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Garden Logo
97 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
