Question about GE Spacemaker Washer and Dryer Electric Laundry Center
My GE Spacemaker washer (Model WSLS 1100D) only hums if the temp. setting is on HOT. Warm is fine, just no hot. What's up?
5 Suggested Answers
SOURCE: washer does not drain water
Make sure the drain hose is not kinked
Posted on Jul 20, 2008
gdmisp
  • 66 Answers
SOURCE: hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Posted on Jan 16, 2009
canbruce75
  • 1776 Answers
SOURCE: Washer Fills HOT WATER ONLY
If you checked the screens at the water inlet valve and they were not clogged, then you probably have a defective water inlet valve and will have to replace it. Hope this helped.
Posted on Jul 19, 2009
rickyrt441
  • 4399 Answers
SOURCE: WASHER WILL NOT AGITATE, MOTOR
Thanks for choosing FIxYa and welcome to the site. If you have a washer that has a weak agitation or no agitation at all, here are some possible solutions. You need to check your belts. Most washers have one or two belts. Check your lid switch. If a lid switch is bad, it can cause the washer to not work properly. Sometimes, they will not work at all. Make sure you check your drive motor. The drive motor controls the spinning, draining, and agitation. Most washers have the reverse motor, meaning the shaft rotates in both directions, clockwise and counterclockwise. It is possible to lose one direction and not the other. Some washers have a clutch that controls the agitation. If it is bad or worn, it may prevent the agitator to work. Most of these washers come from General Electric. You could have a bad motor coupler. They are located on the side of the motor drive inside the washer. It is also possible that you have a bad transmission. Check the agitator itself. You could have a bad spline or two. The splin accompanies the shaft and allows the movement of the agitator. If you rule out all the parts above, you may have an electrical issue or an issue with the control board. It is very important to test each part and make sure it is getting power. If a part is not working and not getting any power, the power loss may be the reason that it doesn't work. You can test the current in the wires with a voltage meter.
Posted on May 07, 2011
Cold Pulses when set to HOT only
if you want only hot water, shut off the cold.. its only really used during the rinse anyway..
Feb 02, 2014 | GE Spacemaker Washer and Dryer Electric...
Wash machine water issues
pull the hot water hose off at the faucet and machine and check for blockage in the hot water hose,clean or replace the hose sediment screens,then hook back up to water faucet and flush hose with hot water,then check water valve on machine for a screen and clean it as well before reconnecting hot water hose
Apr 07, 2013 | GE WSM2480DWW Unitized Spacemaker Washer...
Fills cold and warm but not hot
This is a common problem with hot water lines to washing machines. The hose connecting the washing machine to the hot water supply has a small screen in the inlet of the hose. These are used to keep grit, etc from getting into the washing machine and causing bigger problems.
Here's what to do:
Pull the washing machine away from the wall a little so you can access the shut-off's. Turn off the hot and the cold water valves.
Take the hot water hose off the valve and check the screen in the rubber washer of the inlet hose. Replacement screen/washers are available at local hardware stores for a couple bucks.
You can clean the old ones, just be careful not to damage the rubber washer because that's what keeps your hose from leaking when you reinstall it on your faucet.
While you're at it, clean the cold water screen as well.
REcheck your fill on a hot cycle... you've most likely solved your issue!
May 09, 2010 | Washing Machines
WPXH214A Water Temp: Any selection that has Warm
The cold side of the water valve is either clogged or not opening. Take the cold water hose off of the machine and see if the screen is clogged. If clean you may need to replace the water valve.
Feb 25, 2010 | GE WPXH214A Front Load Washer
Warm water temp Maytag PAV1000aww washer
Perhaps you need to simply open the hot and cold water faucets all the way.
Jan 05, 2009 | Maytag PAV2300 Top Load Washer
Washer won't fill with hot water
If you hear a humming, the coil on the water valve is probably OK. On warm, you are getting cold fill only. (hot + cold = warm) Take the hot water supply hose off the machine and look inside where the hose attached to the washer. There should be a screen inside. Remove it and clean it out. Also, check both ends of the supply hose, as sometimes you will find a screened washer in there too.
Oct 26, 2008 | GE WBSE2090A Top Load Washer
Washer is a top load set it hot water and starts with hot and then will go cold willnot stay on hot G E Profile ,model wwa8350g
most new washers sense water temp and will try to adj final tub water temp by alternately running cold or hot as needed ..most hot settings are not faucet temp but a predetermined temp so if your hot water is 140 degrees coming in the control will switch the cold on to bring final tub water temp down to preset ..which could be as low as 100 degrees the industry's way of energy conservation
Sep 23, 2008 | GE Washing Machines
Washer does not drain water
Dec 27, 2007 | GE Spacemaker WSLP1100D Top Load Washer
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
105 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
