Question about Cross Sentinel 10 Sheet Cut Shredder
Sentinel mx120d shredder. It runs in reverse, but not in fwd -- it does not seem to sense paper in the feed slot, the only way it runs in fwd. Any ideas??
fellowesrep
  • 102 Answers
SOURCE: Shredder not working
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol. Sensor is usually located in the center of the paper feed opening.
If neither of these help your paper feed sensor or your pc1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
Posted on Mar 02, 2008
JayBlair
  • 328 Answers
SOURCE: Aurora AS1512X Cross Cut Shredder
Sounds like the cutter is jammed. Do you ever feed staples or clips in it? Will it reverse? If not, the power borad is burned out.
Posted on Jul 31, 2007
fellowesrep
  • 102 Answers
SOURCE: Rexel rdx1750 shredder jam
This is the available numbers for ACCO Rexel 0845 658 6600 or 01296 732466/732468 in the UK or you may contact by email mailto:informationeurope@acco.com and this is the web address http://www.acco.co.uk/
Posted on Mar 06, 2008
fellowesrep
  • 102 Answers
SOURCE: fellows paper shredder
First try to clean those sensors with a qtip dipped in rubbing alchohol if that does not work call 1-800-945-4545 to check for part availability.
Posted on Apr 07, 2008
SOURCE: Shredder runs in reverse, but will not feed in auto.
For me, I had to move the 'black thing' in the center of the shredder at the top out of the way with a screwdriver. The black thing, whatever it is, seemed stuck against the top. So, once I moved it out of the way, it works. That may not be the right thing to do, but it worked for me.
Posted on Oct 20, 2008
Turns on, << works,won't shred when paper is inserted. doesn't seem to be jammed
Is it running in reverse? A lot of shredders have a switch for fwd/rev. Otherwise maybe the gears are stripped (plastic).
Dec 29, 2015 | Office Equipment & Supplies
How do I fix my auto feed, which has stopped working?
Use a flashlight to examine the shredder from the top and look for a shred of paper blocking the slot. The shred may also be blocking the sensor. If you don't find anything, turn the shredder upside down to examine the shredding mechanism from the bottom.
Mar 05, 2015 | Staples SPL770M Shredder
How do I clean the paper from around and behind the rollers?
Forget the cardboard and feed in less sheets at a time.
It overheats because the motor is working too hard.
Aug 20, 2014 | Cross Sentinel 10 Sheet Cut Shredder
Paper stuck in feed slot
The usual process is to run the shredder in reverse, and the half shredded paper comes back out of the slot. I guess you have tried this and it did not work? Next step is to dismantle the cover and clean out the shredder blades with a small screwdriver and/or tweezers.
May 18, 2014 | Epson EPS1200X Shredder
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
When I try to feed a piece of paper into the shredder, the overload light comes on and the motor stops running. It will run in reverse. Oh and when the overload light comes on, the pull out basket is...
You say it runs in reverse...does it seem to run slowly??? Have you ever "oiled" the machine.???
This is a x-cut shredder and must be oiled...get some "shredder oil " and try pouring some of the oil across the cutting blades and running the machine in reverse. See if it seems to pick-up some speed after the oil in tried. Then see if it will run in the fwd direction for you.
Dec 07, 2010 | Royal VF1012mx Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
This is an issue with the paper feed sensor usually located in the center of the paper feed slot. If it is mechanical you need to jiggle switch in and out to free possible interference behind switch (piece of paper or debris) if it is an electronic sensor you more than likely have a bad sensor or pc board. You will need to contact manufacturer for any further assistance.
Mar 16, 2008 | Tech Solution TS-4500 Shredder
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Jan 01, 2008 | Tech Solution TS-8000 Cross-Cut Shredder
421 people viewed this question
Top Cross Office Equipment & Supplies Experts
Computer Links
Ivan
Ivan
Level 1 Expert
k24674
Are you a Cross Office Equipment and Supply Expert? Answer questions, earn points and help others
