Question about Dishwashers
When i clean my dishes it leaves soap or chalk like flim on the pot and pan
  • Dishwashers Master
  • 3,247 Answers
Check if the rinse aid reservoir is not empty.
Add rinse aid or if ok increase the setting to let in more rinse aid.
Hope this fixes the problem. Please rate the solution if you found it useful.
Posted on Oct 10, 2010
How do I get rid of white residue on dishes in dishwasher?
if its hard ? then its minerals in your houses water , install a demineralize filter on the washer line , if it flakes off with your finger nail then its left over soap , your using too much or your water pump needs cleaned out or replaced
Aug 15, 2016 | Kenmore Dishwashers
Leaves a white soapy film on pots, pans and dishes
Are you overloading your dishwasher? Are you loading the dishes in such a way to cover the water shooting up from the blades? Have you run your dishwasher a few times with no dishes in it, adding straight white vinegar to clean it out? How old is your dishwasher?
Apr 02, 2013 | Whirlpool Dishwashers
How do you clean a wok without ruining it?
After use;
1. Rinse your wok in warm soapy water and remove any food from the inside surface.
2. If you need to clean the wok more thoroughly you can do it in hot water but don't use any soap or chemicals.
3. Dry the wok with a towel
4. A properly seasoned wok won't give off any black smudges. If yours does, it may still be dirty or just need to be seasoned again.
Feb 18, 2013 | Home
No error message and is washing fine but it is rusting all my pots and pans and my cutlery also all my glasses are coming out all cloudy the dishwaser has also always asking for salt we have put in 3 bags...
Hi, I am only a housewife but salt is a corrosive. At home depo, menards, or lowes you can get a dishwasher cleaning kit. Use that to clean your dishwasher. Next because of new state and national laws soaps had to have a change in the chemical make up to have less sulfate or something like that. My glasses were cloudy all the time. I cleaned my dishwasher and now I
only put in dawn dish soap. I don't have to use anything else. My dishes come out clean and spotless. Now you may have to do a little more cleaning on your dishes before you put them in
because your not using regular dishwasher soap but I don't have those spots. Also I put about
a fourth teaspoon of the liquid soap in the 1st cycle soap dish and another fourth teaspoon in the 2nd cycle. You may have to experiment as to the amount you need becasue of how hard your
water is. If you put too much in soap suds will come out during the wash cycles. Hope is works
Marty Mouse the housewife.
Jun 05, 2011 | Dishwashers
My new dishwasher leaves a white residue on my pots. pans and stainless flatware. I have not changed soap. Could the water not be hot enough?
Check the incoming water quality. If water is hard and having calcium content this could happen. Use water softeners in the inlet water to the machine.
If dish washer salt compartment available fill with the special salt meant for dish washers.
Check rinse aid compartment and fill rinse aid. Or use two in one soap tablet.
Sep 19, 2010 | Whirlpool Dishwashers
Leaves baked soap scum on utensils
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jun 10, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
What causes my pots and pans to turn black on the botom when cooking on a gas stove? Many thanks
depends on the pots. Some is because of they type of metal. The metal turns black because actual fire will turn it when it touches the medal. Others could be grease. Some dish soaps dont get all grease off the pot. Specially if you use dish washer. Try soaking them and see if they will come clean. Dawn dish soap works great or there are products you can buy just for that purpose. good luck
Jan 07, 2010 | Ovens
Dish washer \does not rinse good leaves white flim
Hi:
Some things you can do to try to improve your dishwasher's performance:
1) Make sure your dishwasher rinse agent dispenser has rinse agent in it. The filler is usually close to where you put soap in the dishwasher.,
2) Consider switching brands of dishwasher detergent, if you are experiencing problems. Depending on the water condition in your area, certain brands work better than others. Ask your neighbors what works well for them.
3) try different wash cycle's with your dishwasher. Sometimes the economy cycle doesn't work as well as it should.
Dec 17, 2009 | GE Dishwashers
Dishs have soap flim
If your dishwasher has been in use for a period of time, you may need to clean the interior of the washer.
The next time you are at the grocery store, pick up (2) containers of "Tang" orange drink. With no dishes in the dish washer, fill the soap container with Tang, close the lid and poor the remaining Tang in the bottom of the dishwasher.
Close the door and run through your regular wash cycle. You may have to repeat this with the second container if it is an older model washer.
The citric acid in the Tang will clean the soap scum off the inside as well as the pump chamber inside the washer.
Good luck, it worked for me, cleaned it nice and shinny and smells good too.
Regards,
Aug 13, 2009 | Dishwashers
Dishwashers Logo
88 people viewed this question
Top Dishwashers Experts
Owen Barnes
