Question about Jenn-Air JDB6510 Built-in Dishwasher
Plastic is melted onto the heating element. is this a problem? what should i do?
  • Jenn-Air Master
  • 3,247 Answers
I am assuming the dishwasher is not working.
You will need to check where the plastic has come from. The temperature has to be very high for the plastic to melt. This can happen if the dishwasher heater has been on with no water in the dishwasher. Normally the controller should not allow this. Also the thermostat should cut in to prevent the temperature from going high.
Most likely it is not plastic but a problem in the wash pump which is causing some residue to circulate in the water and deposit on heating element.
In any case, try to scrape off as much of the material as you can and then run the dishwasher with a Finish dishwasher cleaning kit. The instructions are on the kit label.
Hope this helps. Please rate the solution.
Posted on Oct 10, 2010
jsrock516
  • 5911 Answers
SOURCE: A child's plastic cup top melted on heating element. . .how to remove residue
Gently scrape with a razor blade or paint scraper to remove the large pieces, then use some emery paper or very fine sand paper to remove the rest. Use care when applying any pressure on the element, and try not to leave any gouges in the element surface. I have also had good luck with a nail file. Hope this helps you.
Posted on Feb 02, 2008
  • 171 Answers
SOURCE: melted utensil on heating element
Hi amsaunders5,
I'm Harvey the Master Plumber.
Your problem is: Children tried to surprise you by doing dishes. The plastic spatula melted and stuck on the heating coil on the bottom
This is a common problem. First, thank the children, it really wasn't their fault.
It's going to take some effort but you'll have to scrape/remove the plstic from the element. Replaceing the element is not a repair I recomend for the average homeowner.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 21, 2008
  • 3 Answers
SOURCE: plastic melted on Dishwasher heating element
youll have to run a whole cycle again and pay attention to when the heating element comes on again. Once its hot the plastic will be soft enough to remove it with a tight cotton rag. Use you oven mitts for protection. Hope this helps
Posted on Dec 01, 2008
jsrock516
  • 5911 Answers
SOURCE: A piece of plastic spoon melted on heating element. Is th
Make sure the heating element is cool. Remove as much of the melted plastic off that you can by hand first. You can use a straight edge razor to lightly scrape it off. When you have most of the material removed, get some fine emery paper or steel wool to finish removing it. DO NOT use anything that is so abrasive that it penetrates the outer shell of the heating element. Once a hole forms and water gets inside, the element has to be replaced. I hope this helps you.
NOTE: I would not recommend using any kind of cleansers as they tend to leave residue.
Posted on Feb 08, 2010
BElectric
  • 1140 Answers
SOURCE: It get to hot, and the heating element stays on
STOP USING THE DISHWASHER IMMEDIATELY.
It's dangerous and using it will cause further damage. It's likely that considerable damage has been done already if plastics have melted.
Your thermostat has failed and will need replacing but it's unlikely that the thermostat is the only part that will need to replaced. Your washer may even be damaged beyond economic repair.
You need to call an engineer. Your machine needs to be professionally inspected and assessed for damage before further use. If the washer is still under warranty, please contact Electrolux
customer support - the phone number for your region will be in your user manual.
Posted on Nov 03, 2010
Can calcium deposit on the heat element cause the unit to smoke and smell like an electrical fire? And how can. I fix this?
It could be.... It could also be something plastic that got onto the element that is melting and smoking. It could also be a connector to the control board that is loose and is over heating. This is more serious. Carefully check the heating element for some foreign plastic part that is pressing up against it. If there is nothing, then call a professional to make sure that it's not the controller that is overheating and in danger of catching fire.
Jul 27, 2014 | Frigidaire Dishwashers
Melted plastic on heating coil
you can not remove the plastic safely please replace the heating element
Sep 30, 2013 | Frigidaire (FEB30S7D) Oven
I a Westinghouse dishwasher 920 and a plastic spoon fell onto the element while it was on and its melted the spoon on the heat element and i cant remove it. how do i replace the element i am a motor mech...
Break as much of the plastic off as you can and just let the rest melt off or melt it with a solder gun . won't hurt anything. If you want is easy to replace just hall machine from hole and tilt back remove the wires and the nuts holding it on .
Dec 03, 2010 | Westinghouse Dishwashers
Melted plastic on the heater element.
Safety overules your financial decision, get a new element.
Feb 11, 2010 | Cadet Manufacturing CADET SL Series Small...
Tp 409 smells burn when turn it on
I would advise checking the elements as well. It is possible that plastic has melted onto the elements. Try to Identify which slot the smell is strongest. If there is a spot where the elements do have some sort of foreign material melted to them, you may need to replace them.
I
Mar 08, 2009 | Toastmaster TP409 4-Slice Toaster
Dishwasher had a burning smell and smoke was coming out
If the smoke was coming from inside the dishwasher... A common problem is a plastic item , utensil etc has fallen down onto the heating element. During the drying cycle this could possibly melt the plastic and generate some smoke.
Jan 04, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Plastic melted on Dishwasher heating element
Dec 01, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Melted utensil on heating element
Hi amsaunders5,
Thank you,
Sep 19, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Feb 01, 2008 | GE 24 in. Profile PDW7800 Built-in...
Melted plastic *bread wrapper*
mix vinegar and water in a container,turn the element on to the highest setting.get a METAL paint scraper pour the solution onto the element while scraping off the plastic.hope this helps.
Dec 02, 2007 | Robert Yick Co. RanRYC168 Gas Kitchen...
Jenn-Air JDB6510 Built-in Dishwasher Logo
208 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
