Question about Kenmore 53642 / 53644 Side by Side Refrigerator
I Have A Side By Side Kenmore Refrigerator model#106.53859300 And The Frigertor And Freezer Is Not Cooling . All I Keep Hearing Is Like An Motor Is Study Going And A Fan That Keeps Blowing And A Loud Sound Thats Coming From The Compressor. I Want To Whats Going On With That.
SOURCE: Kenmore refrigerator is cycling compressor on and off. Not cooling
WHEN I OPEN THE DOUBLE DOORS RIGHT IN THE MIDDLE OF IT IS VERY VERY HOT WHAT CAN IT BE
Posted on Oct 02, 2008
aborcass
  • 2651 Answers
SOURCE: FREEZER NOT FREEZING REFRIGERATOR NOT COOLING
can you feel the compresor??? is it hot??? if this is hte case, your compressor is hot and hte fan the freezer section is still circulating warm air sounds as ifyou have a sealed system issue, 5yr manufactue warr.. (should be anyway check your manual)
Posted on Nov 30, 2008
  • 399 Answers
SOURCE: Refrigerator and freezer not cooling but lights are on and motor
It's not cool If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator
Posted on Dec 06, 2008
peyton32034
  • 410 Answers
SOURCE: frig and freezer not cooling
it is possible that a start relay has gone bad but more likely is that the compressor has seized up. if the unit is under 5 years old most likely the comp will be under warranty from sears. peyton
Posted on Jan 20, 2009
tborn6
  • 700 Answers
SOURCE: Kenmore side by side refrigerator/freezer is not cooling
http://www.appliancerepair.net/apnet/frameset?
http://www.appliancerepair.net/apnet/refr/ch05.htm
try this site for the aanswers that you seek
Posted on Jan 23, 2009
Freezer and fridge not cooling. kenmore elite side by side, model # 52293100
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 11, 2011 | Kenmore Side by Side Refrigerator
I have a ten year old, side by side, Kenmore refridgerator, model 596.5069 that will not get cool. Started noticing the ice in the frezzer was melting and now it will cool only a bit. Have another fridge...
heatman101
Jun 04, 2011 | Kenmore Side by Side Refrigerator
Kenmore side by side....freezer is not staying cold enough to keep ice cream frozen, middle wall between frig and freezer is extremely hot.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Mar 01, 2011 | Kenmore Side by Side Refrigerator
I have a Kenmore side by side fridge Model 51562101. We just noticed a burning type of smell coming from under the freezer side. My wire thinks the smell is more like a chemical smell. The fridge is...
Your compressor just went bad...
Refrigerator
heatman101
Feb 15, 2011 | Kenmore 62832 / 62834 / 62839 Bottom...
Kenmore refrigerator 598586 intermittent cooling. when not cooling only condensor fan runs. evap motor has been replaced by service company same problem. thanks
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 16, 2010 | Kenmore 58522 Side by Side Refrigerator
Have a Kenmore side by side model#363.58062893 the freezer side is cooling and making ice but the refrig. side is not cooling there is some cool air but not enough to keep food cool enough. Traci
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 17, 2010 | Kenmore Refrigerators
Freezer side not cooling motor running air is blowing
heatman101
Jul 06, 2010 | Kenmore 57029 Side by Side Refrigerator
The motor is on but its not cooling. The light is on, I can hear the motor running but the ice has melted and it does not feel cold in the freezer or cool in the frig.
heatman101
fkjf
Sep 16, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore cold spot not cooling properly
heatman101
jsrha
Apr 19, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
91 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
