Question about Fisher and Paykel DEGX1 Electric Dryer
There is no heat, when i pushed the reset button it blew warm air for a few minutes. Now there is no heat again. What can i do, or what do i need to fix. Where is the heating element. I can't see it anywhere fisher and paykel dryer DEG X1 serial # BAN 310361
  • Fisher and P... Master
  • 7,482 Answers
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a free answer, Please rate me.
Posted on Oct 10, 2010
Carrier air handler/furnace won't turn on
from what your saying the motor is hot to touch if that is the case the motor is bad need to be replaced.
Nov 08, 2014 | Heating & Cooling
Coleman Presidential Furnace 6806A842 heat switch pops then cool air
Make sure all vents are open and filters are clean. Likely an air flow issue but possibly, though unlikely, both switches are bad.
Jun 05, 2017 | Heating & Cooling
E1 Error on air conditioner
It's time to call a professional. Call the manufacturer and ask them who they recommend in your area. Note :Some questions can be answered if you put enough information such as brand and model number.
Mar 25, 2017 | Haier HWR08XC7 Air Conditioner
New amana refer worked when first plugged in, blew out really cold air, checked again in about five hours,warm air. warm air since.
Yes it is ok.... you need to actually create heat to create cold... It's the law of thermodynamics... refrigeration is actually the removal of heat not the creation of cold... pretty deep huh?!
Jul 24, 2011 | Amana ATB1832AR Top Freezer Refrigerator
Hello, When I set my AC unit to "Heat" and turn it on, the air will come out warm, then after a few hours the air starts to come out cool. To make it warm again I need to set the...
It sounds like you have a heat pump. When you first turn on the system the heat strips will come on and produce warm heat (referred to as supplemental heat strips), as temperatures rise the heat strips will turn off and the "A" coil will just exchange heat to maintain temperature thus conserving energy. . Initially the temps will be around 125 degrees at the register, and drop down to about 105 after the strips turn off.
On some TXV controlled outdoor condensing units the Thermostatic Expansion Valve will stick in the cool position and require replacement this will cause this symptom. It takes several hours to do and requires a licensed technician to do as it involves recovery of refrigerants. I hope this helps
Feb 17, 2011 | Heating & Cooling
My 99 pontiac montana has a heater problem.after engine is warm the heater blows warm air for a few minutes and then blows cold for a few minutes and then warm again. sometimes it blows warm for a few...
I would change the Thermostat. if that doesn't fix it? I would buy a Radiator flush and follow the directions exactly you will be surprised how much junk comes out. That should fix all your heat problems.
Jan 07, 2011 | 1999 Pontiac Montana
Blows warm air, unpluged it for 2 days plugged back in blew very
Either the start relay and start capacitor or the Adaptive Defrost control is burned out. If you have a voltage meter we can test a few things like the compressor and the capasitor. The part number for the Adaptive defrost is 241508001 and found inside the fresh food compartment behind the control panel. I can help you locate the problem if you like. Let me know, Thanks, Sea Breeze
Jul 18, 2009 | Frigidaire FRS3R5EMB Side by Side...
Intertherm heat pump blows hot then cold then hot
You may have a problem with a temperature safety system.  Before changing anything else, check to see if the unit is clean!!!  Dirt/dust can fool the safety system into an overtemperature status.  Inspect the heat coils for damage and dirt.  Gently clean.
Nov 23, 2008 | Intertherm P3RA-048K Air Conditioner
After heating beverage, turned off microwave before the three minute cooking cycle was up. Closed door and did not push any button. Shorlty after, the air smeleed of burning rubber and sensor error went...
Please reply back with your brand and model number so we can help you.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Jun 05, 2008 | GE Microwave Ovens
Heater not going on
Please send back the model number. Then we can narrow the roblem down.
Thx,
Peanut
RepairUSA
Jan 07, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Fisher and Paykel DEGX1 Electric Dryer Logo
879 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
