Question about Vivitek Televison & Video
On my 42 inch TV my standby light and power light flashes and the TV never powers up
    Scholar:
  • 143 Answers
The flashing is the service code telling you (or the repair tech) what is wrong with the TV. How many times it flashes let's the service tech know where to find the problem with the TV. My guess is the power supply is probably bad, but it could be anything. You need to count the number of times it flashes and then search for the service codes for the unit. Good luck!
Posted on Oct 10, 2010
  • 597 Answers
The reason your television flashes light is simply because there is a problem with the television, it is receiving power but not supplying it to the main board of the television.
This could be as a result of a burnt capacitor on the power panel of the television.
Run a check on the televisions power panel to detect any burnt capacitor, you can replace the capacitor or the entire power panel, which ever pleases you and is convenient for you to replace.
After replacing the power panel or the capacitor, then you will be able to enjoy the services of the television.
Good luck and take care
4 Suggested Answers
djchillsnyc
  • 152 Answers
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Posted on Oct 14, 2009
panchal643Ja
  • 243 Answers
SOURCE: tevion 42 inch lcd flashing standby light and tv
If you can checked LCD Inverter Board & Micom Board.Most of Inverter board is defective.
Posted on Jan 23, 2010
  • 11 Answers
SOURCE: sony 42 inch plasma tv standby light just flashes tv
You might have a bad B board. What's worse is that the power switch is connected to the Q board which works in conjunction with the B board. Replace B board, You can send your B board for repair to a company called modus link pts. They are the largest part supplier of after market parts and repair.
Posted on Apr 07, 2010
Technika 3d 42 inch tv
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Dec 03, 2013 | Televison & Video
Flashing green power indicator
It is a indication the set is not going to come on---usually a standby power supply problem in the set.
May 19, 2012 | Sharp Lc42d65u 42 Inch Full Hd 1080p Aquos...
TV turns itself off and power light flashes green
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
May 12, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Alba 42"lcd tv watching tv it just went off,
Alba is now a product of Argos, their low cost help line number is 08456040105
Nov 18, 2010 | Televison & Video
When i turn on my 42 inch hitachi pd9700 tv it makes a fizzing noise from the back.after 10 mins it gets louder until its like a high pitched whistle.then when i try to turn it off by the remote the...
This problems it the cause by the power supply board.Those transformers on the power supply board is the cause.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 17, 2010 | Hitachi 42PD9700 42 in. Plasma Television
Sony 42 inch plasma tv standby light just flashes tv
Feb 24, 2010 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
hello if the lamp cover is not mounted securely the self diagnostic function works and the power /standby indicator flashes 3 times when you've corrected it power/standby indicator goes out the tv enters standby mode
shaun
Oct 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
NO POWER ON THE TV SANSUI PLASMA SV EPD 4230BP .IT HAS TRIPPED THE ELECTRICITY.NOW THERE IS NO POWER ON THE PLASMA TV WHICH IS 42 INCH.
If you have a power cut when tv is on - it shuts down for safety - leave it for 1 hr or overnight - then it works!! I have a UPS as our power here in Mozambique always goes out
Aug 12, 2009 | Televison & Video
My emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Dec 04, 2008 | Emerson EWL3706 37 in. LCD Television
Panasonic th-42pa20 plasma 42 inch tv
Try to replace the Main Power Supply board first.
Dec 29, 2007 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Televison & Video Logo
129 people viewed this question
Top Vivitek Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
matt martin
matt martin
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
