Question about Frigidaire Heating & Cooling
I bought a new Frigidaire wall mounted air conditioner last year. I want to run it but I can clearly see a lot of mold in it. How do I take it apart and clean the mold? It's mounted in a hole in the wall because it is so big so I cannot take it down.
    Scholar:
  • 110 Answers
Go to your local hvac part provider or online and order a canof evaporator spray cleaner and condenser coil cleaner perferable the lemon sented cans and follow the instrutions on the label
Posted on May 30, 2008
Replacing this ac?
you know bleach gets rid of mold why dont you just spray it out kill mold and use the one thats aleady in your wall????
Jun 02, 2013 | Maytag M6Q10F2A Air Conditioner
My goldstar air conditioner has a lot of mold growing in where the fan blades are and the vent. How can I clean this or get rid of the mold
Air condition and coil cleaner,can be found at your local hardware store.
I have used simple green full strenght,cleans and kills mold.
Jan 18, 2010 | LG Goldstar GWHD5000 wall/window Air...
A.C. unit is draining on the inside of the house.
There is a drainage and it is stucked with dust, mold etc. Just open metal lid on the wall inside your house, where the coil is installed and where you're changing filters, remove air filter, there at bottom you will see the drainage hole (now under water probably). Rent an air compressor from Home Depot or Lowe's, stick the hose to that hole and turn compressor on. This shall blow the drainage through. After that slowly pour 1-2 cups of Chlorox or Tylex in there, let it stand for 15 minutes, then pour some more water and blow with compressed air again, then flush it with water and blow last time.
Do that at least once in two years, or you gonna have same problem again.
Sep 14, 2009 | Frigidaire FAC126P1 wall/window Air...
A lot of water leaking out of A. C. into neighbor's window below
Place a flat piece of sheet metal or aluminum under the unit that is LONGER and Wider than the unit.....the water will drip on it and run down it and away from the building.
Aug 17, 2009 | Frigidaire FAC126P1 wall/window Air...
MY 2YEAR OLD WINDOW AIR CONDITIONER WON'T POWER ON
Apparently the gfci on the plug (the reset button) has gone bad. The best thing to do is to purchase a new cord and replace it. These switches sometimes go bad. Good Luck
Dave
Jul 28, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Through the wall vs. window installation
window mount doesn't have to extend out on the back to clear the side /top intake vents because a window is about 2" thick,
but a wall mount has to have about 6 to 8 " clearing before the intakes vents can be exposed. you can't have your intakes buried in the wall.
in short if you see about 8 " of dead metal in the center area (just behind the window sill) then you can mount it in a wall as it will protrude far enough to clear the side /top intakes.
a sleeve just gives you a way to balance / attach to the outside wall
Jun 12, 2008 | Heating & Cooling
Can a window air conditioner fit in an exhisting wall mount?
I bought window AC (5000 btu) that fit 17 in. at home depot. made by Zenith. Keep in mind of your room size.
Good luck.
Jun 10, 2008 | Frigidaire FAC124 wall/Window Air...
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
Apr 09, 2008 | Frigidaire FAC124 wall/Window Air...
Heating & Cooling Logo
287 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
