I need the 4 digit code to use for an RCA tv that will work with my universal GE remote control.
    Scholar:
  • 143 Answers
Total Control Universal Remote. URC 4140. What is the 4 digit code to operate the above TV
Search Results
    [PDF]Total Control URC-4140 - Universal Remote Control Codes
    www.remotecodelist.com/remotes/URC_4140_B00_and_B01.pdf
    UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
    Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
Jan 13, 2016 | Sanyo 42 in. LCD TV
I NEED THE CODES NUMBERS TO PROGRAM THIS TV WITH UNIVERSAL CONTROL
GE Universal Remote Codes ' Jasco
https://jascoproducts.com/support/ge-universal-remote-codes
Make a note of which version you have and replace the batteries and cover. A version 2 through version 4 remote will have a "V2" to "V4" after the model number. ... Programyour GE Universal Remote using the correct code list and instructions. ... Sometimes a code will allow limited function control (e.g. volume and channel ...
Codes and links for a number of universal remote controls, including Sony, RCA, ... If you have a remote for which you know the codes (or a web page that lists them) head to ... How to Program a GE Universal Remote Control .... look for your model of TV or VCR and find the online instructions that include the remote codes.
RCA Universal Remote Control- Target Programming ...
Jan 05, 2016 | Coby TF-TV3217 32 in. LCD TV
Need Source Dode for an RCA TV model DETK185R.
The RCA DETK185R TV can be controlled with Universal Remote Controls. I tested several.
The best match was a 4 digit universal remote from GE. Model Number 10841. Code 1961 worked almost everything.
With a 5 digit remote from RCA, model number RCRN04GR, Code 12372 worked Power, Channel, Volume and Input.
A 3 digit remote from GE, model RC24912-B. Code 166 was able to control Power, Channel, Volume and Input.
An old 3 digit remote from RCA, model RCU-403A. Code 062 was able to control Power, Channel and Volume.
Most remotes from GE and RCA will use the same code numbers. So even if you have a different model remote from GE or RCA, these codes may work.
These codes should work with other TV models in this series from RCA, including Detk215r, Detk186r and Detk156r.
Apr 15, 2013 | RCA Detk185r 18.5" Led Hdtv
I have a ge universal remote and have a toshiba tv dont know codes and how to programe it could you please help?
Which GE universal remote do you have? Does the remote use a 3-digit or a 4-digit code? To program most GE remotes for a TV, turn on the TV. Then press and hold the Code Search or Setup button until the indicator light comes on. Then press and release the TV button. Enter the first code available for your device. The indicator light should go off then check if the remote controls the functions of the TV. Repeat the above steps if the code doesn't work or doesn't control all the features of your TV.
The manuals and code lists for GE remotes are here: http://www.jascoproducts.com/support/universal-remote-codes.asp .
Toshiba 4-digit TV codes are: 0159 0178 0109 0120 0181
.............0105 0049 0095 0170 0260 0358
.............0394 0924 0012 0095 0117 0141
The 3-digit codes are 170, 181 or 641 for Toshiba HDTVs.
Please note that the remote probably only has codes for devices that were released 6 months or more before the remote was programmed. If your TV is newer than your GE universal remote, you may need a newer remote.
I hope this helps.
Jul 06, 2011 | RCA Televison & Video
GE RC24914-E 1022 universal remote..Needed for an 46' RCA HD TV...None of the 4 digit codes that came with remote worked
tengo un control general electric 24914-e y quiero el codigo para programar una tv marca toshiba
Mar 17, 2011 | GE RM24948 Remote Control
Needs codes rca remote
I'm not sure which remote and device you have. The header says a GE remote and the text says RCA remote. I'll provide locations for both types of remotes.
Try the following web site: http://remotefinder.rca.com/default.aspx?site=rca for RCA universal remotes. Enter the model of the remote as well as the brand and type of device to be controlled.
GE Universal remotes use either a three or four digit code. Find the code lists here: http://www.jascoproducts.com/support/universal-remote-codes.asp . Then determine if you have #24912 remote or which of the remote code lists that applies to your remote.
The code lists for any given remote will be limited to codes for devices released 6 months or more before the universal remote was programmed. If your device is newer than that date, the codes may not work.
I hope this helps.
Nov 20, 2010 | Universal Remote Control GE174Universal...
NEED CODE TO GE UNIVERSAL REMOTE RC24912-D FOR RCA TV.
The code to programme your remote with RCA TV
3 digit code are
000, 003, 004, 005, 007, 009, 011, 031, 048, 054, 078, 082, 083, 094, 096, 098, 099, 100, 101, 102, 103, 107, 113, 129, 133, 167, 179, 181, 187,188, 191, 194, 342
4 digit code are
0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
thanx
Aug 05, 2010 | GE RM24912 Universal Remote Control
Lost manual for ge universal remote 24912
I found it finally!!! This stupid $10 remote was pissing me off, I couldn't find anything but ppl needing the same help as me so I thop this helps you!!! This link worked for me, and you prob want the 4 digit code b/c I also have a Sanyo I had to program. good luck, hope this helps!!
-Summer
Jan 14, 2009 | GE RM24912 Universal Remote Control
I need a 4 digit code to work with rca universal remo
1213, 1122, 1123, 1141, 1321, 1434, 1343,
1342, 1123, 1124, 1143, 1114, 1244, 0018,
0019, 0029, 0038, 0047, 0090, 0135, 0174, 0278
Nov 18, 2008 | RCA RCR460 Remote Control
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
