Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Sizzling noise illuminated coil in freezer - Whirlpool ED2FHEXN Side by Side Refrigerator
  • Whirlpool Master
  • 1,151 Answers
If it only does this in occation, it's because it's the defrost cycle. It turns on a heater, which melts any ice and frost build up on the cooling coil. As it drips on the heater, it sizzles.
Posted on Oct 10, 2010
The freezer is not getting cold and the water is dripping down the back onto the coils and it is causing a sizzling sound and smells like it is burnt. How do we fix.
Turn it off before you burn your hose down. Nothing should be so hot as to make a sizzling sound! There shouldn't be any water on the outside of the unit. It sounds like there is leak.
If this unit has been in operation for a while, like a couple years and longer -- the coil that is under the unit is most likely completely matted up with dust. This needs to be cleaned. With the unit off use a vacuum cleaner, brushes -- any way you can devise to get rid of all the accumulated dust.
Because I can not think of what water could be dripping on to make a sizzling sound - or where that water be coming from - I'm going to suggest you call in a professional on this one.
There shouldn't be any condensate that can drip on anything. The clogged up coils underneath could cause the freezer not to cool properly.
A burnt smell sounds like electrical - and that's why I'm concerned.
Don
Mar 24, 2012 | Maytag MSD2756G Side by Side Refrigerator
I have a ge side by side refrigerator/freezer and i'm hearing a sizzling sound from the freezer side. Sounds like water is hitting the heating element causing a sizzling noise. Should I empty th
If you are sure the sound is coming from the freezer side, then yes you should empty the frrezer and take off the rear shield. While the heating element is normally encased in glass or plastic. Water droplets hitting an electrical connection could also cause a sizzling sound.
Feb 03, 2012 | GE Refrigerators
I opened my freezer (arctica) and heard a sizzling sound -- i could see coils behind the grates on the back wall of the freezer that were bright red (like an electric stove coil on high) -- the water was...
I hope you unplugged your unit or tripped the breaker. If they are bright red then you have an electrical short that should have tripped the breaker a long time before they turned red hot.
Jul 15, 2011 | GE Profile Arctica Stainless Steel Top...
My side by side refrigerator on the freezer side is dripping water at the bottom on to the coil. The coil seems to be making a sizzling sound and turning red is this ok
There is a defrost heater that periodically turn on to melt the accumulated frost on the coil. The heater will warm the coil to about 45 degrees and a defrost thermostat should shut off power to the heater. The defrost cycle should only last about 30-45 minutes then the compressor should kick on. If you find that some items in your freezer are melting, or that the freezer is not maintaining temperature, then something is wrong. Hope this helps you.
May 24, 2011 | Maytag Freezers
Side by side refrigerator is making a sizzling noise at the back bottom of the freezer
The sizzling in your case means that it is working....it is just water dripping from the cooling coil onto the hot element that defrosts it...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 18, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator stoped cooling and freezing. The lights and the fan come on, but will not cool...
The first thing I would do is remove the cover on the back of the fridge and check if the compressor is running. If it's not, then it could be the start device. Remove the power from the fridge, pull out the start device from the compressor and shake it. If you can hear something inside is moving, replace the start device.but if otherwise then,
Your defrost timer located inside the control panel is bad OR the defrost thermostat located on a freezer coil is bad.
Get down low and look up at the bottom of the control panel.
You will see a small round hole. Onside the hole is the defrost timer advance knob.
Use a flat blade screwdriver and SLOWLY turh the slotted knod clockwise until the refrigerator clicks off.
Wait a few minutes then open the freezer door and listen for a sizzling sound from the freezer compartment.
If you do hear a sizzling sound that would be the defrost heater melting ice.
If you do not hear a sizzling sound,unplug the refrigerator and remove the rear freezer panel to expose the cooling coil.
Clipped to the coil will be the defrost thermostat. It will need replacing.
If you do hear the sizzling sound the defrost timer will need replacing.
Good luck and hope this will work
Jul 30, 2010 | Maytag Refrigerators
Whirlpool Mod ET18LKXHWo o Fridge not freezing,
Jul 20, 2010 | Whirlpool Refrigerators
Water is streaming out the bottom of my fridge on freezer side
the water should evaporate when hitting the coils,maybe coils s/b cleaned (dusty)
Mar 17, 2010 | Refrigerators
When the ice maker start to rotate there is very loud noise
Dripping sound.
During the defrost, water draining from the freezer section will drip into the pan by your compressor in the back and bottom of your refrigerator.
* Air rushing or blowing.
There is a fan in the freezer section and in some models in the back and bottom of your refrigerator to circulate air. This is a normal sound.
* Louder when starting or coming on.
Compressor operates at a higher pressure when first starting and noise should disappear as refrigerator continues to run and balance pressures.
* Popping, crackling, or sizzling about once a day.
If your model is self-defrosting, the defrost system utilizes a heater to remove the ice and frost from the freezer coil. During this period you will hear some expansion noises as heat is applied to the coil and you may experience some sizzling sounds as the melting water drips on the heater.
* Running water.
If you have an ice maker equipped model, the ice maker will call for water as the old batch of cubes is ejected and the ice maker starts to make more cubes. This will last for about 10 seconds and is normal.
* Vibrating or rattling noises
Sep 22, 2009 | Kenmore 25.1 cu. ft. Side-By-Side...
Falling water hits something hot in freezer and causes sizzle sound
the sizzling noise is water hitting the defrost elememt and this is normal - shows the defrost system is working. if water comes on the floor of the freezer, this may be the drain for the defrost water is blocked. remove the freexer back panel and the drain is in the tray where the defrost water is caught. if it is blocked - usually with ice - clear it with hot water and make sure the water drains freely. takes some patience and maybe several attempts
Jul 13, 2007 | KitchenAid Superba Architect KSCS25IN Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
113 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
