Question about Maxtor One Touch III 500GB FireWire/USB2.0 External w/16M buffer Retail ****... 500 GB USB 2.0 Hard Drive
I keep getting a message telling me that "the volume maxtor has 14% free space remaining". Does this mean it is running out of space and if so what can I do about it.
  • 2 more comments
  • onesuperb Oct 11, 2010
    I have considered that but if I delete it of the Maxtor will it also remove it from my iMac?
    Bad news, everything I deleted from the Maxtor also were deleted from the iMac
  • onesuperb Oct 12, 2010
    My imac has 3/4 free space, the Maxtor is the external backup hard drive. At this
    point I have ordered a new backup with 1TB which should solve the space issue.
    In the mean time I will try the two programs you have selected. My next question is this, once I get me new external hard drive is it possible to complete erase everything off the Maxtor without connecting it to my mac because every time I delete something of the Maxtor it also deletes it off the imac.
  • onesuperb Oct 14, 2010
    I am in the process of compressing files and it seems to be working. Thank you.
    President:
  • 1,216 Answers
Hi ThIs DEFINITELY MEANS YOUR HARD DRIVE IS SHIRT OF SPACE NOW BY NO MEANS YOU CAN INCREASE THE CAPACITY OF YOUR DRIVE, BUT THERE IS AN ALTERNATE SOLUTION.FIRST OF ALL YOU MAYUSE A COMPRESSION UTILITY TO COMPRESS THE FILES YOU USE LEAST OFTEN.I RECOMMEND WINRAR FURTHERYOU MAY DOWNLOAD AUSLOGICS BOOT SPEED AD USE ITS DRIVE CLEANER TO REMOVE UNNECESSARY FILES SUCH AS TEMP AND LOG FILES JUNK FILES ETC.IT HAS A DUPLICATE FINDER WHICH WILL ALSO HELP YOU. IN THIS WAY YOU CAN RECOVEER LOT OF SPACE. THANKS
Posted on Oct 12, 2010
  • 4,472 Answers
Yes that means that it has 14% space left. Your only option is to delete/back up files off of it to a different media. If you go to my computer and right click the drive and select properties it will tell you exactly how full the drive is. If you need any further assistance please let me know. If you find this information helpful please take the time to accept/rate my solution accordingly and I can continue assisting you as well if you need it.
Thank you,
Lee
  • Lee A.
    Lee A. Oct 19, 2010
    If you haven't already please accept/rate a solution that you have found helpful.
    Thanks again,
    Lee
  • 6,487 Answers
Base from the description of your problem YES it is already running out of hard drive space so what you can do here is to remove some files that you don't need from this hard drive to free some hard drive space.
Posted on Oct 11, 2010
  • Mark Gil
    Mark Gil Oct 11, 2010
    If its save to your maxtor it will only be deleted from it not from your MAC, just remove those things that you don;t really use or need.
Hi i was having a few problems with my maxtor 500gb external hard drive after using with my xbox, i soon came to see that it had been reformatted into FAT32 so it wasnt letting me move files that were over...
You could download and install Seatools, free, from the Seagate website (Seagate incorporates Maxtor). You can run a check and possibly repair the disc if it is damaged. Seatools and can also automatically report on the manufacturer's 5 year warranty, and provides a reference to have it repaired under any guarantee which may remain.
Dec 14, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
I believe I have a virus or worm that Norton cannot detect
Ok. How much space do you have free on your hard-drive right now? (I'm assuming that you know how to check this).
If its low, then maybe you didnt free up enough space on the drive. If it is high however, then answer this: is the message you are receiving telling you that you are low on disk space? or is it telling you that it is low on virtual memory space?
if its low on virtual memory, then the problem could be many including 1) virus etc 2) a program is running that is using up more RAM than is avaivable 3) you need more RAM on your system.
if its low disk space, then the problem could be 1) You need to free up more disk space (that may mean getting a bigger hard-drive installed)
Try using an updated virus scanning utility. If it says that you are virus free, then try one of the solutions above.
Oct 02, 2009 | Computers & Internet
I need to free up space on my Maxtor One Touch
Sounds like the default settings is trying to back up your entire drive. If this is what you are wanting to do you will need an external drive. If you are just wanting to back up your documents and the system registry you should change the options. That is what I back up and suggest
Aug 30, 2009 | Maxtor DiamondMax Plus 9 160 GB Hard Drive
The little Maxtor icon is red; what does this mean and how do I fix it? Thanks. scbriel@comcast.net
That means that your last backup has failed. This could be caused by a number of issues and you should double click on the icon to open the program and check the log. Normally when you are attempting to backup a file that is locked by the OS such as a system file it will fail to copy. This could also happen if a file was moved or removed that was flagged to be backed up while the backup process was running or if you ran out of free space. Honestly, your software's error log will be the best thing to check for a solution.
Jul 28, 2009 | Seagate 750GB One Touch 4 Lite-maxtor USB...
Maxtor 3100 external hard drive,FULL :<
If this can be done on DOS mode environment why not try it. Delete some unimportant fies so that it can free some spaces. Then try to view it again in windows environment if this helps.
Apr 13, 2009 | Maxtor Personal Storage 3100 (M01E100) 100...
Low memory on C drive
14GB is not usually enough for a C drive. Because the system restore feature is good at hogging up your space. And yes gettting a new hard drive should do the trick. But make sure that the windows drive is allocated atleast 20-40GB. Maxtor drives are an inexpensive option. I have seen a 1000GB Maxtor drive priced at around 120$!
Sai.
Mar 02, 2009 | Sony VAIO PCV-RS530G PC Desktop
Download and run maxtor powermax, when you run the program it will idenify your hard drives, select your one touch and run the recertify, this will not erase anything but will run a complete diagnostic and attempt recovery of data to recertify as good. If the drive fails I have recovery software I can e-mail you.
Mar 14, 2008 | Computers & Internet
Running out of space
Go to www.download.com and they have software to remove and free disk space I personally use Advanced windows care
Dec 14, 2007 | Maxtor OneTouch II external hard drive...
Open Questions:
Maxtor One Touch III 500GB FireWire/USB2.0 External w/16M buffer Retail ****... 500 GB USB 2.0 Hard Drive Logo
57 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
