Question about Roper REX4634KQ Electric Dryer
Runs for 15-20 min and shuts off when restarted it will do the same
  • Roper Master
  • 7,482 Answers
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a free answer, Please rate me.
Posted on Oct 10, 2010
Ac compressor runs 5 min shuts off then restarts 10 minutes later for another 5 min fan runs ok
Shutting down on safety. It's likely a pressure switch, possibly low pressure if fan is running.
May 24, 2017 | Heating & Cooling
1994 f150 6 cyl engine shuts down every 10 min restart after 5 min
Sounds like the module inside the distributor. Have to be replaced.
Sep 29, 2012 | Cars & Trucks
Air massage runs 20 min. then shuts down. when I restart it right away it only runs a short time.
air systems have a built in timer on them. 20 mins.
they are supposed to be shut off for 20 mins to cool the blower down then can be turned on again.
Feb 13, 2011 | Maax Home
Shuts off...restarts, then runs for a few mins
If the modem is 10 years old then its time to replace it even if it was working fine if not very good to be abreast with the latest technology. The ISP must have tested the lines which must be fine because they keep on upgrading so you need to replace the modem to a latest model.
Jun 19, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
94 chrysler con.3.3 eng.runs for about 15 min. shuts down,engine
suggest change crank sensor-rear of engine pas side
Oct 05, 2009 | 1994 Chrysler LHS
Roper REX4634KQ Electric Dryer Logo
224 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
