Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
The bottom drawer does not lock, the plastic spring catch on the right side rail (rear) is "sprung" before the drawer is fully engaged, suggesting that something is in the way and pushing closed the plastic catch - any suggestions?
  • Fisher and P... Master
  • 3,247 Answers
I am slightly unsure of the problem you are having with the bottom drawer.
Not sure which plastic catch you are referring to. There are no locks in the drawer. It slides on the rail and shuts against the face of the housing. On start (when ON is pressed) the lid seal decends from the top and locks the drawer so that water does not leak during operation.
Have you actually taken the drawer out from its rails? Are you please able to take a photo and attach to your comment.
Posted on Oct 10, 2010
  • cjsgraham Oct 10, 2010
    If you pull out the drawer and remove from rail, on the back wall next to the slide is a plastic u shaped piece on a spring, this catches the drawer when the drawer is pushed in, if the catch is pushed in before the drawer is fully engaged, it stops the drawer from going all the way in and thus does not allow the lid seal to descend from the top and lock the drawer. We think we may have solved the problem, which is the cabling was actually engaging the plastic spring catch and pushing it into it's lock position, but without the drawer, leaving the drawer partially open and thus not allowing the lid seal to come down and lock the drawer. Will advise if this does not solve issue. Thanks
I just bought a house with a Kenmore stainless steel bottom drawer freezer. The freezer drawer does not close completely and large amounts of snow and ice accumulate inside. I have taken the drawer out,...
Check top see if the arms of the drawer are fully seated into the rails which support it and extend from inside the freezer when the drawer is opened. On most french door refrig's, there are hooks on the back side and tabs on the front side which are sometimes hard to get back in. Then the door is locked into the rail with a screw at the point where the rail meets the freezer door.
Aug 21, 2010 | Kenmore 73503 Stainless Steel Bottom...
What does the wrench and F1 mean when the dishwasher isn't working?
F1 signifies that the flood sensor in the rear of the cavity on the bottom drawer has been activated. This is caused by water leaking into the rear of the drawer. I have had the same problem with my own and also repaired a friends unit which was doing the likewise.
The water in the drawer is only the symptom of the underlying cause. You will need to be reasonably handy to undertake this operation.
Firstly you will need to remove the bottom drawer and dry out the flood sensor. Turn the unit off at the wall power outlet before you touch anything! You need to pull the drawer out fully and then activate the tabs on the left and right side at the bottom front of the drawer to move in move it out further and off the tracks.
Make sure you have some towels on the floor in front of the unit. Once you have the drawer out lay it on it's right side on top of the towels. There will be an amount of water still in the unit which will likely drain onto the towels as you do so. Now you will be able to see into the drawer cavity, preferably with a torch, and also see the flood sensor on the rear left hand side. You should also notice a fair bit of water in the bottom of the cavity. As you've made sure the power is off, you can mop up the water.
The plastic cover over the flood sensor can be gently removed by pressing down and sliding it to the right. Once the cover is off you can again mop up the excess water before using a hairdryer to fully dry the flood sensor out. Don't put the hairdryer too close to the flood sensor, just let the warm air slowly dry things out over a 10-15min period.
Once it is all dried reverse the above instructions to put the unit back together. Be sure to make certain the both the left and right tabs are engaged when you are putting the drawer back onto the rails. There should be a positive click if they are engaged properly. If not undo them fully and try again. You will notice that if either side is not engaged properly the drawer won't run in and out smoothly.
Now you can try to run each drawer. I prefer to test the top one first on a short rinse cycle. If that runs without any problems do the same of for the lower drawer. If you don't get any errors you're in business. If you do then read on for further help.
If the F1 code comes up after running either drawer then you've narrowed down which one is the problem. You will again need to remove the offending drawer and check the drainage hose. There will likely be a split at some point along the drainage hose. It's quite fiddly to remove the old one. Note: You can only get a replacement hose from an authorised parts supplier. This is due to the narrow diameter of the hose and the couple which joins the pump under the drawer. Before you throw the old one out, make sure you remove the small rubber valve. It would appear to prevent backflow into the pump and is not supplied with the replacement.
I didn't totally remove the clear housing from the motor assembly, but was able to remove it part way and gently open it enough to get the old hose out. In order to more easily complete the fit of the new hose, I would recommend carefully removing the whole unit from the wall cavity. Make sure you disconnect the inlet hose, power and drainage hoses under your sink. This allows the unit to move freely from the cavity without damaging anything. There are four securing tabs inside the bottom drawer cavity which need to be removed to do this. (All quite clear in the instruction manual).
If you are at this stage I would also recommend installing the 'retro fit link support'. It is much more practical and robust when compared to the plastic one the originally came with the unit. It has a metal rod and a mount that fits into the corner of the draw cavity. Makes much more sense than the plastic rod.
If in doubt get a service technician out. Also search up 'F1 fault' on this site for further assistance.
Jul 06, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
23 in. DD-603SS Built-in Dishwasher: dishwasher makes a beeping noise and displays F1 w...
If you are at this stage I would also recommend installing the 'retro fit link support'. It is much more practical and robust when compared to the plastic one the originally came with the unit. It has a metal rod and a mount that fits into the corner of the draw cavity. Makes much more sense than the plastic rod. Mine broke anyway when I had reassembled the unit so I had to as a matter of course.
Hopefully this assists someone :)
May 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My fisher and parkel dishwasher keeps displaying F1
The best thing to do is turn the power off ,remove the bottom drawer by pushing in the clips on side of the drawer ,just below the round plugs. The clips are attached to runners, push them back to release the drawer and ( after taking out the rack and spray arm) put the drawer on its r.h.side. Mop up the all water in the base, then remove the cover that goes over the back L.h. corner, this will expose the mains/flood switch board ( make sure you dry the roof of the drawer before you take the cover off , or water can drip onto the board .....not a good thing!!!yikes.gif).
To remove the cover, push in the clip in the middle front edge of the cover with a flat blade screwdriverand slide the cover foward a bit, then put the screwdriver under the clip and twist up, the cover should now pull off to the right. Spend a couple of minutes drying the board with a hair dryer and mop up any remaining water ( be careful of the board again). Refit the cover and switch back on ( you shouldn't need to force the cover on, just slide it on from right to left , but you may have to push down the cover just above the clip to get it to lock once it is located correctly). If it doesn't F1 again ,all good, if it does , remove cover and redry, and repeat until it doesn't.
To refit drawer, slide out L.h. rail and sit drawer on it, then lift right side of drawer and slide out other rail and sit other side down. If the rails don't want to slide foward and lock, lift the drawer at the front while sliding the rail fowarduntil the front edge of the rail is just at the clipping gap at the side of the drawer, then make sure the drawer is sitting down firmly on the rails and pull clips foward to lock. If the drawer has been clipped in correctly it will slide in and out nicely, if not , look at the back edge of the drawer when it is fully open to see where it is sitting too high and rectify by refitting the rail on the affected side/sides. By this point if any part of the bottom drawer was broken ,you would have seen it. Also check the top drawer by releasing it and pulling it foward,shine torch in and have a good look.
Hopefully it won't leak again unless ther is a faulty part not visible to the nakedshock.gif eye, check by running one drawer for a couple of minutes, stop the cycle and open the drawer and check the outsides for water ( don't be too worried if you see water in the bottom between the drawers as it will drip from the roof, unless the drain or fill hoses are split ) ,if ok, run the other drawer and check.
Remember, if you get to a point where you don't feel confident with what you doing or you think you might break something, leave it and call a professional to do the job, you may save money in the long run and if you going to expose wires or connections always switch off and unplug before removing the cover, you dont know whats underneathxbones.gif.
Nov 14, 2009 | Dishwashers
My freezer is frosting...there is snow all over
In my case with constant snow and frost build-up in my bottom drawer GE freezer, it was because the drawer never properly closed. As one user noted, "there is no adjustment." However, there are "catches" at the rear of the drawer glides and in my case one needed adjustment because it was preventing the drawer from remaining closed tightly. SEE PHOTOS. The photos show many items removed, but to make this repair, you only need a butter knife to pop out the black plastic catch mechanisms at the back end of the drawer glides, and only if you can see that the spring is not properly positioned. SEE PHOTOS
May 09, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
How to take or remove drawers out of 2 drawer Fisher Pakel
Hi, welcome to FIx Ya...
1. Unplug machine.
2. Slide drawer open, remove two pegs that secure front panel to drawer (one on each side of drawer)
3. Slide front panel down and out, remove green ground wire.
4. Depress tabs that hold bottom plastic cover on bottom of drawer and remove entire cover, being careful not to break the tabs.
5. Disconnect tan water fill hose from rinse dispenser.
6. Disconnect two wire harnessess at control board.
7. DIsconnect drain hose from pump base. (might want to put a pan underneath to catch water)
8. Depress tabs on hose/harness coupler at bottom rear of drawer and dis-engage the coupler.
9. Lift drawer off slides.
Jan 13, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Kenmore Elite bottom freezer drawer won't shut
Has something fallen behind the drawer, and is preventing it from sliding back all the way? Remove the drawer by pulling it all the way out and lift it up and out. Look for anything that has fallen back there.
Dec 31, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Flood switch
I had the same problem and I fixed mine. It wasn't hard at all. First, make sure power is off either unplug or shut off breaker. Next, open the lower drawer and on the sides toward the bottom you will see a circular recessed pin with a flat slot. Without forcing, wiggle the door down. When you get it off you have to remove the wire harness, just unplug it. Now, on the sides at the bottom, you will see where the drawer fits on the slid rail. Push the plastic button slightly to release the lock for the slid rail to the drawer and push the slid rail all the way back as to release the drawer fronm the rail. Be carefull when you release one side as to hold it up still while removing the other one. Now, flip the drawer on its side and try to get it as far out of the way as possible to the right of the unit. You will now notice a plastic cover at the back left of the unit. This is where the flood swith is. Remove this cover by sliding to the right. The will be water under the circuit board you see. Soak up as much as possible and you can use a hair dryer to get the tough spots. Now try to find the resson for the water. I had a mouse living under mine. Look for a break in one of the hoses. After all dried up turn power back in before reinstalling lower drawer. If dried properly, the dishwasher should stop beep beep beeping. Now turn water back on and run upper drawer. Inspect hoses again. 50/50 chance. If now water, reinstall lower by replacing plastic cover, place drawer on rails and slide all the way back. It should click back in if on rails correctly. Now install the door face, line up tabs into drawer, and slide up. Align holes for recessed circular pins and just push them in. Test lower. Thats all I got, Hope it helps.
Oct 03, 2008 | KitchenAid 23 in. KUDD01DPPA Stainless...
Kinderkraft crib model 710
On the bottom of the front rail that drops (the drop rail), there are two plastic tension pieces (one at either end) that engage the two fixed, bottom rail slider hardware (the long, narrow pieces screwed top-and-bottom into the lower, inside portion of the tall, upright crib ends). These tension pieces are spring loaded, and the outer edge of each one rides along the outside (i.e., the parent's side) of the two bottom metal rail guides. Their purpose is to supply outward pressure against the lower part of the drop rail - that's what you push against when you press your lower leg upon the bottom of the drop side of the crib to lower it. They insure that when up, the drop side locks safely into place. I suspect these tension pieces are your problem. It sounds like they are improperly installed. Good luck.
Sep 10, 2008 | Kinderkraft Vermont Crib
Phaser 860 maintenance tray A stuck
1. The Maintenance Drawer will not come out. - Often times this can be overcome by waiting 2 minutes for the ?Hot Ink? timer to expire, then remove the Maintenance Drawer. 2. If the printers Maintenance Drawer is locked in place and can not be removed and there are no cleaning functions currently taking place then the Maintenance Drawer can be unlocked by removing the right side cover and move the Cap/Wipe/Purge belts evenly down to the home position. This will raise the sensor flag from I/O Left and disengage the locking pin that is preventing the Maintenance Drawer from being removed. 3. If either Maintenance Drawer Guides (Blue Plastic Rail guides) have been replaced or removed and reinstalled and this is preventing the proper insertion of the Maintenance Drawer then check on the outside of the chassis frame that both rear locking tabs for the rail guides are protruding through the printers frame and are properly seated and notched into place. ? If they are not properly installed and seated then remove the rail guides and reinstall and then test for proper insertion and removal of the printers Maintenance Drawer. 4. Obstructions or spilled ink (wax) may be covering the Drum Maintenance rail guides and preventing the proper insertion or removal of the Maintenance Drawer. ? Check the printers Drum Maintenance Rail guides for any paper scraps or spilled ink or leaking ink from the Printhead. Make sure that there is no spilled ink under the Maintenance drawer waste tray and that it is seated properly. TROUBLESHOOTING TIPS AND HINTS: In order to provide more clearance when removing the printers Drum Maintenance rail guides, use the X-axis gear to move the Printhead away from the drawer guide that you are removing/installing. Also raise the Cap/Wipe/Purge assembly to reduce interference. When a drawer rail guide is mounted, double check its rear locking tabs where they go through the chassis side frame. Both blue tabs should be visible on the outside of the frame of the printer.
Apr 28, 2008 | Office Equipment & Supplies
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
159 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
