Write Error 7:39:54 PM #30 CDR -1135 File Writer.cpp, Line 303 Write error R: MATSHITA DVD-RAM UJ-851S 7:39:54 PM #31 Phase 38 File dlgbrnst.cpp, Line 1762 Burn process failed at 24x (3,600 KB/s) 7:39:55 PM #32 Text 0 File SCSIPTICommands.cpp, Line 261 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 7:39:59 PM #33 Text 0 File Cdrdrv.cpp, Line 11185 DriveLocker: UnLockVolume completed 7:39:59 PM #34 Text 0 File SCSIPTICommands.cpp, Line 424 UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL Existing drivers: Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
  • Milaries May 31, 2008
    Utility use Nero 7 write error
  • falconace92 Nov 24, 2008
    at any speed nero 6 express says that it has faild to finish writing files
  • 981 Answers
That's almost an adequate error description! It is odd that a 24x CD speed description is given for burning in a DVD-RAM; what media and session types did you pick? If there is nothing (hair, fingerprints, soap...) on the particular disk preventing a burn, perhaps something has a write lock on dlgbrnst.cpp so it can't be reeled off to DVD-RW?
Posted on May 31, 2008
MadDog MD-16XDVD9 could not perform end of disc-at-once
Have you tried checking your basics ?
Firmware ?
ASPI ?
Disk Defrag ?
IDE location ?
Jumper settings ?
What type of media are you using ?
What programs are you using ?
Exactly where are you and what are you doing when your error occurs.
What are your PC's specs ?
Do you have any Roxio products installed on your PC ?
Please answer ALL of the above - if you don't know, say so, don't make something
Oct 20, 2009 | Computers & Internet
My gsa-t20n will burn regular disks but will not burn DL disks all of a sudden...it burns most of the way then Nero says it cannot finalize disk. 22:48:29] NeroVision [22:48:29] NeroVision 10:36:44 PM ...
Hello there jpd0490.
Here's your geek-steer ...
There are principally two chief causes for this type (calibration) of burn failure:
  1. Inadequate quality media (disks). Verbatim is always a solid choice. However, more important than the brand-name disks are sold under, is the actual manufacturer. You can determine this with the aid of a little software tool called "DVD Identifier". There is an entire sub-culture devoted to tracking the best media available, right down to the manufacturing lot level.
  2. Drive failing. Since you say that it works consistently otherwise, this option is unlikely.
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 10, 2009 | LG GSA-T20N DVD±RW Dual Layer Burner
Sir i write a cd i get this error somu 4C85-1000-0805-6481-407K-8KE9-**** Windows XP 6.0 IA32 WinAspi: - NT-SPTI used Nero Version: 7.10.1.0 Internal Version: 7, 10, 1, 0 (Nero Express) Recorder: ...
turn off buffer underrun protect in neros settings. It gives back the wrong info to nero causing it to crash. Contact nero about the issue. there may be a patch on the nero site to fix it.
Aug 30, 2009 | Acer Aspire 4720 Notebook
Sharp Actius AL27 strange DVD burning problem - The drive will burn a DVD+RW at 4x. A cheap (Imation) DVD+R burns OK, but a good 16X DVD+R (Verbatim) tries to burn at 2x and fails a few minutes in. This...
man it's not a condition that if the DVD Bulck writeen on it 16X that ur DVD writer will burn on this speed.
always don't try to burn ur DVD on maximum, always use the previous speed or the last previous one
ok good luck
Jun 17, 2009 | Sharp Actius AL27 Notebook
Burn fail or cd skip
Kind of sounds that way. They are pretty inexpensive now days, and simple to install.
Good luck
Mar 17, 2009 | Gateway M680X PC Notebook
Memorex DVD+R DL 8.5 GO 8X compatibility
If all you are looking to do is write a DVD (ie, burn ordinary OS-managed files onto DVD, without transcoding, etc.), or write transcoded DVD-structured files, or an .iso image file, then don't even try to use Nero. Use ImgBurn, it is 500% better for those kinds of tasks, and it's freeware. I use it to burn DVDs but use Nero to transcode files and create the VIDEO_TS folder files. I then use ImgBurn to convert them to an .iso file, then burn it to DVD, also using ImgBurn. URL: http://www.imgburn.com/
Mar 30, 2008 | Ahead Software Ahead Nero 6.3 Suite 1...
Burn error
You unit is faulty.. replace the unit with a new one. The CD Write Laser has probably "Burnt Out" or perhaps the "Quadrant Detector" has faulted.. either way a new unit is only way solve ya problem ... sry :(
Sep 03, 2007 | HP Media Center m7250n (ED842AA) PC...
YAMAHA CRW8424 gives Track following error..
PROBLEM DEFINITION: Basically, it is a hardware error that occurs when a drive is not capable of following a data track on a CD-R or CDRW or on the other hand, poor power flow may cause the problem SOLUTION: 1. Try use another disc, a disc with a different band. 2. If one doesn't work, you may have to open your system and use a different power connector, making sure no other devices are using the power connector in the same strand. 3. Lastly, if neither the above doesn't work, you may have to send your drive in for servicing as the head may be dirty or misaligned.
Aug 05, 2007 | Yamaha CRW 8424 Burner
Computers & Internet Logo
274 people viewed this question
David Payne
David Payne
