Question about Napoleon PTHC38PK Heater
What is the biggest tank size i can use? - Napoleon PTHC38PK Heater
  • Napoleon Master
  • 2,517 Answers
Well what size fits safley in the base , the one that came with it ?, or run a gas line from the heater to any size you like , but this would have to be done by a gas fitter ,
Posted on Oct 10, 2010
Can anyone please provide a diagram naming the parts for each of the three holes that are on the fuel tank of a 2003 mercury sable?
25754868-gppiebehbpzqam0zqcwnz1ao-3-0.gif Item Part Number Description 1 9B593 Evaporative Emission Valve (Flexible Fuel Only) 2 9002 Fuel Tank 3 9G332 Evaporative Emission Tube Shut Off Valve 4 9B593 Evaporative Emission Valve 5 9C052 Fuel Tank Pressure/Vacuum Transducer 6 9H307 Fuel Pump Module 7 9S278 Rear Fuel Supply Return and Vapor Tube
Jun 21, 2015 | 2003 Mercury Sable
What is the biggest size can I can crush?
The biggest can crushers that I have seen can handle cans up to 16 oz. your standard size can (in America) is around 12 oz.
Aug 19, 2013 | Home
Won't stay running
The biggest problem with any petrol/petroil equipment is the gae of the fuel.
petrol is hrgoscopic, when means that it tends to attract moisture. The biggest problem with petroil equipment is usually where the fuel tank is not drained after use, so when you come to use it the tank apears empty as the petrol has evaporated leaving only the oil which blocks the carburettor and gives a doubly rich mixture. Water in the fuel is usually easy to analyseas when running the equipment will have a really uneven tickover, sort of accelerating and then decellerating as if it's running out of fuel.
As an earlier blog, drain the tank, wash it out, spray quick start into the air intake and she should start and remeber when finished empty the petrol tank into a container specifically for two stroke.
Nov 10, 2012 | Ryobi RY09440 30cc Gas Leaf Blower...
WHAT IS THE BIGGEST SIZE CARD AND WHAT TYPE FOR THE canon powershot SD630 ELPH?
The biggest size SD card compatible with Canon Power Shot SD630 is 1 GB. Visit canon showroom to buy SD card.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Oct 21, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
Biggest mud tire u can fit on a stock 2009 chevy 3500HD
the biggest i have seen is 315/70R17, not sure of your rim size though.
May 27, 2010 | 2008 Chevrolet Silverado 3500HD 2WD
How to copy ledger size to ledger size - overriding the letter size in brackets. Can't find a manual anywhere
yep!
depending on the setting of your machine.
if your machine is set to us standard, there you will be able to see ledger size paper selection
but if your machine is set to jp/eu (default) you can only copy with a3 size as the biggest size
that's it
May 21, 2010 | Panasonic DP-8016P Copier
Max size of memory stick for sony cyber-shot 2.1mp
You can just go to the Sony website and look up your camera by model number. you can find out the maximum size memory card for your model. It could be bigger that what your instruction book says, because your camera is a few years old, and was made before most of todays memory cards were available. For example. The Sony site says my camera can accept a 2Gb card, but it came new with a 128kb, and the biggest at that time was only 512Kb , which is listed in my user guide as the biggest I could fit. Good luck with yours.
Oct 10, 2009 | Sony Cameras
I am trying to find a diagram of the hose routing for the evap canister on a 1996 S-10 with a 4.3 V6. Any chance you can steer me in the right direction. Thank You
there should be a hose diagram/white sticker under the hood either by the radiator support or by one of the shock towers.let me know if this helps you.
Sep 06, 2009 | 1996 Chevrolet S-10 Pickup
XD card What is the biggest card my FujiFinePix 3800 can handle?
FinePix 3800 can handle any xD Picture Card size.
Unfortunately the largest ones are only 2 Gb
Here a chart of all available sizes, speeds
and approximate number of photos that can be taken on each.
Tested the xD 2Gb H & M+ on my own 3800 and both work great.
Jun 02, 2009 | Fuji FinePix 3800 Digital Camera
Seven boxes puzzle
1 2 3 4 5 6
. . . . . . 1
. . . . . . 2
. . . . . . 3
. . . . . . 4
. . . . . . 5
. . . . . . 6
first box is the 4 corner dots at top on left hand side
Biggest box is 4th across on first line 1st across on 3rd line 3rd across on last line and 3r up on last line on
next box bottom left hand 2nd across 3up, 1st 2up, 3rd across 2up, bottom line 2nd frm left.
next box is just about inside biggest box, slightly smaller
next box is also inside biggest box again smaller
th other 2 boxes are the same size of the one in the left bottom corner, 1 inside biggest box and then you should find the last on no bother.
Hope this helps
Feb 11, 2009 | Nintendo Professor Layton & the Curious...
Napoleon PTHC38PK Heater Logo
Top Napoleon Heating & Cooling Experts
paulcarew
Bill Long
Rick12345678
Level 1 Expert
Are you a Napoleon Heating and Cooling Expert? Answer questions, earn points and help others
