Question about Sansui 27" TV
Sansui 27" TV squeals when I plug it in after my kids pressed the on/off button repeatedly. Why?
    Problem Solver:
  • 17 Answers
Replace the switch
Posted on Oct 10, 2010
To setup digital
Setup codes for sansui are:
0135 0310
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Mar 16, 2012 | Sansui 27" TV
27 inch sansui tv is there a reset button
hi
reset button have desapear on tv sets 20 years ago
Sep 28, 2010 | Sansui 27 inch TV
Trying to program my sansui tv with the cablevision remote control. unable to find codes
You have to do the universal way which involves:
1) turn on tv and dvr
2) press tv button + select, hold till the io button stays lit (5seconds)
3) once io button is lit, press up and down channel buttons and flip through them until the tv turns off.
4) press mute, this should turn the tv on.
5) press tv button to save the settings (turn off tv)
Oct 05, 2009 | Sansui DTV2760 27" TV
Sansui TVS2746
You can download the manual explaining how to program the timer from Orion who makes this TV, http://www.orionsalesinc.com/Downloads/27-/View-category
If you need a new remote you can get one from Orion or search on Ebay.
Dec 01, 2008 | Sansui 27" TV
New Sansui 27" and remote does not work
On later model Sansui tv's, you can bring up the menu by pushing both volume buttons on the front of the set at the same time. After the menu is on the screen, you can navigate using the channel and volume buttons.
Nov 01, 2008 | Sansui TVM1916 19" TV
Sansui TVM1902A
Try codes for Orion.
Aug 27, 2008 | Sansui DTV2760 27" TV
How to switch to dvd mode
If you can provide the RCA remote model # I can be more specific (it should be located on the back or inside battery case.
Anyway depending on whether your remote uses 3 digit codes or 4 digit codes the Sansui TV code is usually 191 or 1191.
  1. Press and hold the TV button on the remote. LED will stay "ON".
  2. Enter the code for your brand of TV into the remote while continuing to hold the TV button down. LED will go out during number entry and turn back on when the last digit is entered.
  3. Release the TV button. LED will flash and go out if number is entered sucessfully, or flash 4 times if it detects an error.
  4. Press Channel up or down to see if this has worked.
You can also use the code search function.
  1. Turn on the device you wish to control.
  2. Press and hold "CODE SEARCH".
  3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
  4. Release "CODE SEARCH".
  5. Press ON/OFF repeatedly until the device turns off. You may have to do this up to 100 times.
  6. When the device shuts off press and release ENTER.
  7. Try using the remote. If it does not function repeat steps 1 through 6.
Mar 21, 2008 | Sansui H TV2600 TV
Unlock childlock sansui sv-t21pa2s
hi
how to open child lock for this sansui tv
Feb 29, 2008 | Sansui DTV2760 27" TV
Sansui Model: TVS2542A 27" TV
check line output transformer, look for dry joints
Dec 09, 2007 | SansuiM1315 TV
Black box on screen
go into menu find
cc settings and
change setting to off
(make note of the one thats
causing the problem)
Dec 02, 2007 | Sansui DTV2760 27" TV
Sansui 27" TV Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
