Question about Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
The freezer on my fridgidare frt21lr7ab7 is not getting cold enough...I cleaned the coil(for the first time since i bought it in 04)it was really dirty and thought it would work fine but no change...so i unpluged it and let it thaw(there was ice one the freezer condenser ) thinking for sure that was it but still not cold enough and condenser is frosting up again.....freon? compressor?....i have a 25 year old frigadare in my garage that works like a champ....how long should the freon last in a fridge bought in 04?.
3 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: the freezer on my fridgidare
There is a complete guide you could follow. This is written in simple words and cover the major part that does not require a tech.Look at :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
To inspect the freon, there is a nice article :-
http://fridgeman.wordpress.com/2008/06/08/simple-ways-to-know-if-your-fridge-is-low-on-freon/
It is made in 2004, so freon should be fine unless there is a leak. This could only be determined by a special instrument which is available with licensed tech.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 10, 2010
tunde007
  • 2382 Answers
Freon can stay as long as possible in a refrigerator depending on how you use it and the necessary operating condition of the refrigerator. I have seen many people find themselves in the same position you are now. You are not the first and definitely not the last. I also have a fridge at home now, less than 3 years with the same problem of not cold enough which i found out was related to freon issue.
An insufficient Freon charge is one of the last things I consider when troubleshooting a refrigerator that does not cool. FREON LEAKS OUT; IT DOES NOT WEAR OUT. It is unlikely that your refrigerator will suddenly start leaking just sitting in your kitchen UNLESS it is manual defrost and you recently removed the ice from the freezer compartment by using a knife, screwdriver, chisel, or pry bar and punctured the aluminum evaporator coil or an incompetent service person installed piercing-valves that are leaking.
Conditions which may seem like lack of Freon but are not:
  • Evaporator fan not running which ices up the evaporator and raises freezer and fresh-food compartment temperature.
  • Condenser fan not running which raises temperature of freezer and fresh food compartment.
  • Dirty condenser which raises temperature of freezer and fresh food compartment.
  • Defrost problems (if automatic defrost) which ices up evaporator raising temperature in freezer and fresh food compartment.
  • Old compressor with worn valves that raises evaporator pressure and temperature.
  • Worn door seals that allow hot air to leak into the freezer or fresh food compartment (Note: Some Haier refrigerator doors won't seal even when new.)
  • Clogged filter dryer or capillary tube which keeps the Freon from circulating properly.
All the above conditions make the compressor run continuously or almost continuously, but so does a lack of Freon. The compressor runs continuously because the refrigerator cannot reach the set-point on the cold-control. Keep in mind that if you set your cold control to mid-range and it can't cool to that setting, turning it to max (which asks it to make the temperature even colder) does absolutely nothing.
Freezer not getting cold enough (20-25) and fridge at 45-50 and running all the time
Check and clean the coils. If that doesn't work, then the Freon needs recharged.
Jan 23, 2014 | Kenmore Refrigerators
My kenmore top freezer is not cold enough. The temperature is not cold enough to make ice. how should I troubleshoot the problem?Model number is 106.8670680
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Kenmore 64802 Top Freezer Refrigerator
I have a GE side by side refrigerator bought in 2003. The freezer is not cooling enough and the ice creams have melted. The fridge is not cooling much but it is cooling enough to maintain the stuff in it....
heatman101
Jun 03, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi my freezer is not cooling enough. Ealier my
heatman101
May 24, 2011 | Fisher and Paykel Active Smart E522B...
My fridge is not getting cold enough. It's an upright LG Model that I bought 3yrs ago. I never tried to fix it though.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 24, 2011 | LG Bottom Freezer Refrigerator w/...
Nine y/o GE side by side not getting cold enough
More likely a defrost heater. Look inside the freezer at the back wall. Any frost there? If so, turn off refrig., unload freezer, take back panel off inside freezer, and use a hair dryer to melt off the frost. Replace the defrost heater located at the bottom of the frosted coils. (New heater may appear different than original, but instructions are included) If you don't have the defrost heater on hand, just manually defrosting the coils and re-starting the refrig will get is cooling again for at least a week before problem will re-occur. (this give you enough time to get the replacement part)
Mar 21, 2010 | Refrigerators
The motor runns but the freezer does not get cold
clean your evaporator and condenser coils thoroughly and then you may need to have unit freon cheched
Jul 26, 2009 | Freezers
Refrigerator not getting cold enough
IF THE COMPRESSOR IS RUNNING ALL THE TIME IT CAN ONLY BE THE FREEZER IS NOT MAKING TEMP.OR YOU HAVE A AIR LEAK SOMEWHERE ON THE DOOR GASKETS OR WATER ICE DISPENSER,LET ME KNOW-MIKE
Dec 06, 2008 | Maytag MSD2656G Side by Side Refrigerator
Freezer not cold enough to freeze items solid
Here are some things you can check yourself. Does it run all the time almost non-stop? if so check the vents under the front of the frig and make sure they are clean. Aslo check the condenser coil (either in back of the frig,or under the frig)Make sure that coil is clean. The condenser coil has to have contact with the outside air in order to release the heat it removed from inside the freezer.
Make sure you frig has plenty of ventilation ( wall too close on sides and back) Hope this helped. If not then you should have a pro look at it.
Jan 28, 2008 | Frigidaire GLRS264ZA Side by Side...
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
69 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
