Question about RCA R52WH73 Projection Television
How can I fix blurriness on my tv? - RCA R52WH73 Projection Television
  • RCA Master
  • 1,525 Answers
Hello, have you tried your menu setting clicking on auto focus, if this does not adjust then you may have a fault with convergance ic these are 2 big black chip that sit a metal frame called a heatsink they are usually located behind tuner board also there will be some resistor in front of the ic and 2 capacitors at either end these will need to tested as well, it's quite a big job to do yourself even harder if you have no electronic exprience hop you can get it fixed good luck
regards
shaun
Posted on Oct 10, 2010
Blurry picture during football games
Get a TV with a 120 cycle or higher refresh rate. Nothing you can do with the TV you have
Dec 29, 2013 | Sharp AQUOS LC-42D85U 42 in. LCD TV
How to fix blurry picture on sanyo ht30744
Turn tv on picture is clear and sharp. no problems at all. However, after 30 or 60 seconds picture is blurry, color is distored. stays that way
Dec 31, 2010 | Sanyo HT30744 TV
Hitachi 57F500 blurry picture
its the convergence problem in your tv.the ic needs replacement.to fix the problem.its worth getting it fixed.get it repaired.
the cost will be negligible.
Mar 21, 2009 | Hitachi 57F500 57" Rear Projection...
How can I fix it? The magic foucs goes to two or three lines and goes back to the picture. The sides are blurry, like red and green.
Mar 18, 2009 | Hitachi 57F500 57" Rear Projection...
Rca projection tv is blurry
Find a large rifle and put it out of its misery. Bowing is either from a problem in the pincushion correction circuit or the convergence circuit. Blurry picture or poor color rendition is most likely bad CRTs ( picture tubes)
michtech
Feb 03, 2009 | RCA D52W19 52" Rear Projection Television
Blurry tv monitor
try to adj picture settings.
Aug 02, 2008 | Televison & Video
RCA 36
I got an RCA 27" TV from someone who had moved it to another room but found it was "blurry" after moving it. I brought it home and tried all the suggestions I had found online but it was still blurry. I looked at the back of the TV and found 2 tiny knobs on the right (from the back view) which I began to fiddle with while looking at the screen. It fixed the blurriness immediately! I now have a beautiful screen.
Apr 30, 2008 | Toshiba 36A40 36" TV
Blurry tv
Sounds like theres a leaky capacitor in the screen drive circuit. I have seen this problem also be a gassy crt but was able to clean off the grids of the CRT with a crt/rejuvinator. It happens because of low emmissions in the tube and when white is on thats a mix of all the colors, so the tube works harder. I bet when you whatch a movie and the scene changes suddenly to a white or brite scene the pic looks a little washed out. If this is not the case then I aggree with the Pravin and try it on another TV just to be sure .. This is not a repair for a consumer to do, though however it is only a three year old set you stated, so there should be life left in the tube, so im kinda thinking a capacitor is bad. Seek out a yechnician to check this out for you as a TV is not a place to see it you can fix it or to exoeeriment with. Good Luck
Jul 26, 2006 | Toshiba 36A40 36" TV
RCA R52WH73 Projection Television Logo
26 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
