Question about Apple iPod touch
How to unlock the volume limit on the ipod 3rd generation nano
  • 864 Answers
Unfortunately the password is whatever you set it as but you can do this. Plug in your iPod and iTunes will open ( or open it youself)Select all you songs by clicking ctrl and A. (PC's: Ctrl and A at the same time. Mac's: Apple and A at the same time.) Right click your songs.
Click "Get Info"
Click "Yes"
Click the "Options" tab
Check "Volume Adjustment"
Put the Curser all the way to "+100%". Select Ok!
Hidden Folder for Mac's
Enable hidden folders.
If you go into Terminal and run these two commands all the hidden files appear when you open Finder.
defaults write com.apple.finder AppleShowAllFiles TRUE
killall Finder
To get back to hiding hidden files use these commands
defaults write com.apple.finder AppleShowAllFiles FALSE
killall Finder
Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked". Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Hidden folders for windows PC
In Windows explorer,go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders".
Navigate ("My Computer" to double-click on the icon of your attached iPod) to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, copy the file named "_volumelocked" to a folder on your hard drive then delete it from the iPod.
Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. If using an iPod Nano, hold down the center button and menu button simultaneously for about 10 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Warning: Note that some methods may not work on all iPods. Not all ipods have the file called "_volumelocked" it is impossible to get better sound on some of the ipod gens, for example the 5g 60-80 gigabyte ipods. Don't Listen to musictoo loudly. It will destroy your hearing. Don't delete any more files than necessary as it may prevent your iPod from working
Posted on Oct 22, 2010
I have a 6th generation iPod Nano. This is the fifth one I've had and they all have had the same problem. At some point (usually after I've had it about a month) it starts to turn the volume down...
The only thing I can think of is that maximum limit has been set low and is somehow lowering itself. To set the maximum limit
On the home screen, tap settings
Tap Music, then tap Volume Limit
The volume limit control will then come up to raise the limit move the slider all the way to the right.
If you want to stop the volume limit moving you can put in a passcode by clicking on the Lock Volume Limit and entering a passcode (I'd just put in 1234, so you can remember it easily(
Hope this helps.
Sep 07, 2011 | Apple iPod nano 3rd Generation
Why does my ipod play music with my headphones in it.
Dear joycemdais2,
- Check if the volume is open: scroll with the click wheel to check if the volume is open - See if volume limit is disabled in Settings
Kind regards
Jan 01, 2011 | Apple iPod nano 3rd Generation
Wish to remove eu volume limit on ipod nano 5th generation
Go to settings then playback and then volume limit. You can then use the click wheel to select the volume limit once you have the volume you want use the centre button to set, Hope this helps.
Apr 06, 2010 | Apple iPod nano 5th Generation
The volume on my ipod nano 4th Generation won't turn up all the way
You have the volume limit adjusted so that it won't blow your ear drums out.  Go into your settings and turn the volume limiter off.
Nov 24, 2009 | Apple iPod nano 4th Generation
I recently returned my Nano. The volume could
Have you checked whether there is a volume limit on the nano. Go to settings then playback and then volume limit. From there you can adjust the maximum volume you can have. Hope this helps.
Nov 13, 2009 | Apple iPod nano 3rd Generation
Ipod nano volume locked forgot password
Basically you cant unlock the voulume if you dont know the password. You would probably have to reset your iPod in order to adjust your volume and when you put a new password in be sure to remember it.
Feb 25, 2009 | Apple iPod nano 3rd Generation
Ipod Nano can't unlock volume lock
on my ipod the volume limit is a software setting in the menu that does not require any kind of passcode so you have me a bit confused as to what you are asking
Oct 13, 2008 | Apple iPod nano 3rd Generation
Apple Ipod Nano 3rd Gen Volume troubles
Seems like a manufacturers fault on your click wheel. The new nano's have their click wheels held in place with just a strong adhesive so this one might be slightly out of place.Take it straight back as faulty. Make sure inside your headphone socket isn't red else Apple will say it's water damaged.
Aug 17, 2008 | Apple iPod nano 3rd Generation
Apple iPod touch Logo
526 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
