Question about Whirlpool GB9SHDXPS Stainless Steel Bottom Freezer Refrigerator
I have a whirlpool gb9shdxpq bottom freezer fridge. It stopped getting cold in the fridge part so i started troubleshooting. The freezer was still frozen and the frost is what was causing the fridge to not have any airflow. I used the force defrost through the control panel and that has fixed the problem but the freezer is freezing up again. Before i change the control panel what other testing should I do. i already know I can force it into defrost mode so what does that prove besides the element being good. Any help is appreciated
  • 4,070 Answers
Part 5 in this diagram is your electronic control which controls the defrost cycle. Like you said you know the heater and the defrost thermostat works. So the control is all that's left.
Posted on Oct 10, 2010
  • mtbguy614 Oct 10, 2010
    does the thermostat have to be good to use the force defrost function? 130 dollars is a lot to spend on the control board so I need to be totally sure. I also did the thermostat and defrost circut diagnostic test through the control board. With everything all iced up it show the circuit was shorted (closed) It flashed on the open for half a second then went to shorted. What does this prove. thanks
  • Charles T Nevin
    Charles T Nevin Oct 10, 2010
    If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
    With an ohm meter it should show continuity when cold and none when warm.
Hello, We have a Whirlpool Gold bottom freezer
I don't know about Whirlpool refrigerator freezers, but my Amana has a temperature control in the freezer that regulates the overall cooling, and then the control in the refrigerator compartment controls how much of the total cooling is sent to the refrigerator section. My advice would be to lower the temperature setting of the freezer, and see if the temperature lowers in the refrigerator as well. Also, you can go to the Whirlpool website and they can help you further.
Aug 02, 2013 | Refrigerators
5 year old whirlpool fridge/freezer uk style freezer on bottom. freezer still cold but not working? fridge part still working but temp seems reduced. no ice at back of freezer area inside?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 10, 2011 | Whirlpool Refrigerators
Fridge and freezer stopped cooling/freezing
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Jan 03, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Bottom of fridge and freezer cold ice maker not
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Nov 28, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Whirlpool bottom freezer - freezer working but fridge not cold
Hi check to see if the unit has 2 compessors! If so then remove the plug from the mains and remove the thermostat housing in the fridge compartment and join the live and common wires together and switch on! It then should start to freeze down. Just get a new stat if this happens and replace it. Becarefull not to bent the log capilary wire as this has a liquid in it and any kink in the wire will mean you will be buy another one..
Good luck....
Oct 28, 2008 | Whirlpool GB9SHKXL Bottom Freezer...
Whirlpool GB9SHDXPS Stainless Steel Bottom Freezer Refrigerator Logo
1,034 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
