Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Why isn't my ethernet and internet light not on ...on my DSL
  • ramiboots Oct 10, 2010
    My model is E90-610030-06
  • 340 Answers
Try this... go to start and in the search bar type cmd, when the pop up comes up type the following... ipconfig /release then at the next C: type ipconfig /renew type exit and try to connect again.
Let me know if this works!
Posted on Oct 10, 2010
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
2wire2701hg-b lights: power-on, ethernet-off, wireless-blink steady, dsl-on, internet-on, dsl line ok
If ethernet light is the only one that's not on, that means there is no device that is connected hardwired to the router.
Sep 10, 2011 | 2wire (2701HG-B) Wireless Router
Cannot connect to web.
Follow this steps
1. Connect the provided power adapter from the gateway's POWER port to an electrical outlet. The POWER light on the front of the gateway should be green. 2. Connect the provided gray phone cable from the gateway's PHONE LINE port to the DSL filter jack labeled DSL/HPNA. 3. Connect the yellow Ethernet cable provided with the gateway from the LOCAL ETHERNET port on the gateway to your computer's Ethernet port
With your computer completely started, verify the POWER and ETHERNET indicator lights on the front of the 2Wire gateway are green. If they are not, see "Understanding the Indicator Lights" on page 15. The INTERNET indicator light will not turn green until the gateway software has been installed and an Internet connection has been established.
Mar 22, 2011 | 2wire Computers & Internet
My modems LAN light is blinking and I can't get Internet, I've tried unplugging it, but the problem still exists, please help
There will be 4 lights...
Power
Dsl
Internet
Ethernet
Power light indicates power supply is good...
Ethernet light indicates connection between modem and computer is good...
DSL light indicates connection between modem and telphone line is good... Also DSL light should be steady and it should not flash...
If it flashes then it says there is a lot of noise in telephone line...
Internet light says whether the internet status is connected or not...Internet light can flash depending upon the internet activity...
Feb 03, 2011 | Paradyne 6381 ADSL2+/ReachDSL Router...
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    I have had problems connecting to internet all weekend (internet - red light), am on now but internet and ethernet green light keep blinking, is this ok.
    No because dsl light should be solid green light. You need to contact your ISP to check if there is a problem on the network.
    Jul 11, 2010 | Computers & Internet
    Describe your zyxel p-600 dsl light turns off then on
    Hello kb_gimper,
    The power light and all other lights blink when the ZyXel P-600 is initializing. The ethernet, dsl and internet lights blink when data transfer is detected. The lights are from left to right:
    * Power Light
    * Ethernet Light
    * DSL Light
    * Internet Light
    If this solution is helpful please click a thumbs-up rating below.
    Have a great day,
    martyshaw152
    Dec 19, 2009 | Zyxel Prestige 660R Router (91004397002)
    Ethernet light went off and won't come back on
    I had the same problem. It seemed the modem reset and the address changed. I called my ISP (Verizon) and explained the problem to them and they had me online in no time.
    Hank
    Aug 21, 2009 | Computers & Internet
    D-link dsl 320b lan light
    Maybe it is ethernet driver
    Apr 23, 2017 | D-Link DSL-2320B
    DSL modem connected but no internet
    Have you installed DSL filters on all your phones and make sure you don't have on on the line for your modem?
    Jun 28, 2008 | Westell Wirespeed LiteLine 6100...
    Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
    66 people viewed this question
    Top Westell Wirespeed Computers & Internet Experts
    Prashant M
    Prashant M
    arnold balmaceda
    arnold balmaceda
    Level 1 Expert
    Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
