Question about HP Pavilion F1703 17" LCD Monitor
HP TCO '03 MONITOR SHUTTING OFF
I have dual HP TCO '03 Monitors and the one one the right turns itself off. Each time I turn it on, it shuts itself off? Any Ideas?
Thanks, Josh
    Sergeant:
  • 458 Answers
Did you check the sleep mode or power off mode? What do you do to make it come back on? Sounds like it might be getting too hot and/or going bad. Not sure how to diagnose this without seeing it myself. That is the best that I can do. Your video card could be going bad. Try another video card on that monitor. This will be the only way to decide if it is the card or monitor.
Posted on May 30, 2008
When i turn on my hp pavillion mx50, it shuts itself off after a few seconds and doesnt work. What could be the problem?
The problem is more than likely caused by the flyback transformer, this generates the high voltage to the crt screen, when this part fails the protection circuit activates causing the monitor to shut down.
Jun 03, 2012 | HP Pavilion MX50 15" CRT Monitor
Monitor just turns itself off after 2 sec.
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
Apr 16, 2010 | HP w1907 LCD Monitor
Hi I have an HP LCD Monitor and i am receiving a message that says DVI No Input VGA No Input Monitor Going to Sleep and it shuts off.. I have tried unplugging all the cords and replugging them in and this...
caligrl2007, Sorry to hear you are having problem with your monitor. When very strange things start to happen with an LCD monitor, the first place I would look would be the "switch-mode-power-supply" inside of the unit. If unit does same thing when connected to KNOWN GOOD pc, then a technician will need to investigate the SMPS. 12fixlouie
Dec 03, 2009 | HP w1907 LCD Monitor
Monitor turns itself off
hi, you must have enabled power saving options. Thats why your monitor shut down. you can disable, just do the same:
1.Right click on desktop
2.Select properties.
3.Select "ScreenSaver".
4.Select "Power" under Monitor power option.
5.There select "never" from Turn off monitor (drop down menu).
Now your monitor will not turn off automatically.
Sep 19, 2009 | Dell Inspiron 531s Desktop Computer
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
I turn on my monitor and then it shuts off.
i had this same problem with an hp monitor of mine i called their tech support and they said that the monitor was bad, i think this is the way they start to go bad well bye bye
Jun 16, 2009 | BenQ FP71G 17" LCD Monitor
I have a acer AL2216w. it randomly shuts itself off
Replace the following capacitors:
3 pcs. - 220 microFarad - 25v
2 pcs. - 1000 microFarad - 25v
1 pc. - 2200 microFarad - 25v
Resolder the 2 inverter transformer's legs.
Roan
Triangle Tech Whiz
Jun 11, 2009 | Acer AL2216W LCD Monitor
Hp FX 70 monitor keeps shutting off
Sounds like the problem is with the switch itself. No real fix for this.
Both these monitors will work with your desktop without any additional software.
Feb 14, 2009 | HP Pavilion FX70 Monitor
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
Monitor randomly shuts off and computer restarts
After you turned it on and the screen shut off, check the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If the computer shut down immediately after the monitor shut off, it might be because of fault operating system. Check with another monitor.
Thank you,
Mar 08, 2008 | HP Compaq FS7600 17" CRT Monitor
HP Pavilion F1703 17" LCD Monitor Logo
180 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
