Question about Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Long drying times usually have to run loads twice to get them to dry..
  • Maytag Master
  • 1,250 Answers
Usually an indication that the heaters are not all working. I'd look there first. Could possibly be an undersized or partially clogged vent pipe too. Both are causes for you issue. check it out
Posted on Oct 10, 2010
  • 1122 Answers
SOURCE: Loads have to run through high heat cycle twice to
have you checked your wall vent hole and dryer vent hole to make sure they are clear?if there not it will keep the hot wet air from coming out and take forever to dry,let me know-mike
Posted on Apr 14, 2009
  • 1028 Answers
SOURCE: drying cycles taking way to long
ck vent to outside starting at back of dryer looks restricted or flatten vent hose then ckd vent from wall or floor to outside to verify problem is vent issue leave vent hose off and try a load may get a little warm and dusty but would be quick way to verify
Posted on Nov 25, 2008
  • 30 Answers
SOURCE: my dryer takes 2 times as long to dry a load
make sure u have proper venting...your vent pipe might be crushed or clogged...to many bends in the pipe also reduce the efficiency ...Good luck
Posted on Apr 05, 2010
SOURCE: it takes my dryer twice as long to dry a load of
You could not have enough voltage running to the dryer, so check the plug in and your breaker. Your heating element may also be shot and if this is the case, recycle the dryer and get a new dryer.
Posted on Feb 28, 2011
heatman101
  • 43501 Answers
SOURCE: In the last few months (5 yr old machine) the
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Posted on Apr 03, 2011
In the last few months (5 yr old machine) the dryer takes forever to dry normal loads. I usually have to run it twice to get permanent press type clothing dry. Is this normal wear on the machine, or is...
heatman101
Apr 03, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
It takes my dryer twice as long to dry a load of clothes than normal. I usually have to run one load at least 3 times on high heat, just to get them dried. what can i do to fix this problem, or would be...
Feb 28, 2011 | Whirlpool LER4634J Electric Dryer
My dryer is producing heat but is not drying, i am drying the same size load i usually do on the same cycle. the lent is cleaned out, and the oustide vent is blowing hot air. why are my clothes not getting...
make sure that all the seals are ok, door,front and back drum seal, blower housing seal(inside dryer). also consider that depending on washer type if you overload or have a worn drive belt in washer it will take twice the time to dry. also make sure that the dryer drum tumble. open door,press door switch and start dryer to see if drum turn. lastly disconnect vent pipe behind dryer and dry a load. if it dry ok then you have a partial blockage. you can also have a weak heating element.
Feb 11, 2011 | Whirlpool WED5300S Electric Dryer
Dryer not drying in alloted time
there is a thermostat. it usually is located on the heating element housing
May 26, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My dryer whirlpool wed5300sq0 is getting hot but clothes arent dry
I suspect you have a blocked air vent. A blocked vent will definitely extend your drying time. You may even find yourself having to run a load twice to get it fully dried. One way to confirm this is to disconnect the vent hose from the back of your dryer and dry one load with the machine venting directly into your laundry room. If that load dries quickly then you know the problem is a blocked vent. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
Jul 07, 2009 | Whirlpool LER5636P Electric Dryer
Dryer doesnt dry clothes
Jun 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer not performing as it should
A blocked air vent will definitely extend your drying time. You may even find yourself having to run a load twice to get it fully dried. One way to confirm this is to disconnect the vent hose from the back of your dryer and dry one load with the machine venting directly into your laundry room. If that load dries quickly then you know the problem is a blocked vent. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
May 28, 2009 | Oregon Scientific Electric PTO Clutch for...
Clothes not drying completely, still damp when taken out.
the heating element has probably blown a coil or your thermostat is broken
Apr 26, 2009 | Whirlpool LER4634J Electric Dryer
Our dryer isn't drying completely. We have to put it on twice to dry clothes. Gas front-loading dryer model FSG446RHS0
first and foremost check your venting, por/blocked/clogged venting will result in longer then usual dry times
Jan 20, 2009 | Dryers
Dryer not drying completely
Sounds like your heater element is going out.
Dec 06, 2008 | Whirlpool LER4634J Electric Dryer
Open Questions:
See all Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Questions
Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
641 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
