Question about GPS
Hi, Looking for a manual for a Cetrek 3400 marine GPS Chartplotter Sonar unit serial number 6076276. Cheers Pat
5 Suggested Answers
  • 13433 Answers
SOURCE: Garmin GPS GSMAP 182C Chartplotter will not boot up
If the unit doesn't go further from the reading card. this may indicate that theres a problem in the memory card.
Not being able to a get a signal lock on satellites would indicate a problem either in the software something is wrong or not geting loaded correctly (the memory card) Or a hardware problem.
You may have to take it in for service if you are unable to check the memory card or replace it.
Posted on Jun 27, 2008
AlmostBob
  • 550 Answers
SOURCE: besides the unit what is
for the fishfinder, a transducer to go in the water
batteries
Posted on Oct 13, 2008
SOURCE: Navman Tracker 5500 Marine Chartplotter
Yes the screen is replaceable, there are four screws holding it to the PCB and a short ribon and a two wire power lead.
Posted on Oct 21, 2008
hfmiles
  • 1165 Answers
SOURCE: Wondering if or how i
All Hummingbird products manufactured for use in the United States only read in English, fathoms, feet,miles. You would have to see your dealer about a metric unit.
Posted on Jan 06, 2011
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
Can i get a free manual for the matrix 97 combo fish finder / gps chartplotter.
Call our Customer Service Group at 800-633-1468 and they should be able to help you.
Joby
Humminbird
Feb 06, 2011 | Humminbird Matrix 97 Combo Fish Finder And...
My unit display note gps fix required for this operation? I can't see nothing only white page.My model # is385ci
I would contact our customer service group and see if they can help you out. The number is 800-633-1468.
Joby @ Humminbird
Jan 06, 2011 | Humminbird 385ci Fishfinder Chartplotter...
I cannot get a clear high definition picture on my gps. also no fish symbols on sonar. low voltage message keeps appearing on screen. any help would really be appreciated.
sounds like you might not be getting a full 12 volts DC to the unit. check the voltage with a volt meter,, and also check to make sure that your battery/batteries are in top shape and charging properly. ( one bad battery in a bank of many can cause voltage issues ).
c...
Dec 31, 2010 | Humminbird Matrix 97 Combo Fish Finder And...
Can i replace my 330c head unit with the 525c using the same wires antennae etc lowrance
Hope its not to late, before you replace (buy a new one) call Lowrance. I have a 525 and working through some problems and they advised me that they would replace my unit for $200 no questions asked. To answer your question not 100% positive but I did see a recent question where Lowrance lost his unit and sent him the 525 as a replacement and the connections were different. I believe my 525 has a 5 pin system with one notch. Does yours have a external gps module? The 525 does!
Mar 01, 2010 | Lowrance Lms 525c Df 5" Df Sonar...
Sonar inop at most times . onec in a while it works fine
(1) bad transducer. (2) bad ground from unit to battery. The cable next to the battery will have no effect.
Sep 05, 2009 | Lowrance Lms 522c Sonar Gps Chartplotter...
Hi,when i switch on my lms-332c the map does not come up on the screen.If I remove and replace the map card it works perfectly. Can I fix this? regards nigel
I am guessing that the card you are using is a NAVIONICS chart? There have been some Lowrance units that were made around the same time that have had problems recognizing a Navionics chart right from power up.
Make sure the LMS-332 has the latest firmware version which can be downloaded from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/
If the update doesn't help, this is going to be a compatibility problem with the LMS-332 and that particular card. You will need to replace the card or upgrade to a newer unit...but probably can just get used to removing and replacing the card when you turn the unit on.
Jul 08, 2009 | Lowrance LMS 332c Mapping Sonar/GPS...
GPS Logo
156 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
