Question about Vizio L32 32 in. LCD HDTV
The is no sound coming from the speakers. The mute button if off and the CC button if off. Do you have any suggestions to correct the volume?
    Scholar:
  • 39 Answers
Press the menu button on your remote. go down to Audio Settings and make sure speakers are set to ON
Posted on Oct 10, 2010
My volume buttons on my compaq presario c769us are not working , is there a combination for the volume buttons
From the manual:
http://h10032.www1.hp.com/ctg/Manual/c01114193.pdf
Hotkeys are combinations of the fn key (lower left of keyboard) and one of the function keys:
Mute and restore speaker sound. fn+home
Increase speaker sound. fn+pg up
Decrease speaker sound. fn+pg dn
To use a hotkey command on the computer keyboard, follow either of these steps:
Briefly press the fn key, and then briefly press the second key of the hotkey command.
- or -
Press and hold down the fn key, briefly press the second key of the hotkey command, and then
release both keys at the same time.
Muting speaker sound (fn+home)
Press fn+home to mute speaker sound. Press the hotkey again to restore speaker sound.
Increasing speaker sound (fn+pg up)
Press fn+pg up to increase speaker sound. Hold down the hotkey to increase speaker sound incrementally.
Decreasing speaker sound (fn+pg dn)
Press fn+pg dn to decrease speaker sound. Hold down the hotkey to decrease speaker sound incrementally.
More manuals for this model:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=3678775&
Jan 25, 2013 | HP Compaq Presario C769US Notebook
Where is mute button on model 5189 keyboard. sound does not come on. speakers wires seem to be installed correctly. Trouble shooting guide said mute button may have activated.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 24, 2011 | Audio Players & Recorders
Very weak sound from ibm t42 thinkpad - internal and exteranl speakers
There are two ways to set the sound on an IBM thinkpad, hardware and software.
Hardware sound can be set via the speaker buttons below the screen. There should be three buttons: Mute, Volume Down, and Volume Up.
Software sound can be set in windows through the speaker icon on the bottom right of the screen. Click on the icon, and drag the slider up or down to change the volume.
If you don't have the correct drivers installed, these two settings are separate (e.g. It is possible to have the hardware volume down low, and the software volume set really high, and still have music playing relatively quietly). I would suggest turning both of them up and see if the sound gets louder.
Mar 07, 2011 | IBM ThinkPad T42 Notebook
Pc sound is not working right now hepl me
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 20, 2011 | Computers & Internet
No sound my system
If there is no sound coming from your computer try these "simple" but common solutions first.
1. Make sure the power cord is plugged into an outlet and the speakers are turned on.
*Make sure your speakers are correctly connected to the computer.
*Make sure that the speaker cable is plugged into the speakers and the correct jack on the computer.
2. Make sure your computer has a sound card and that it is enabled and working properly:
To open Device Manger...
*Start
*Control Panel
*System and Maintenance
*Device Manager
*Expand the Sound, video and game controllers category.
If a sound card is listed, you have one installed.
*Check the status of the driver and update if necessary.
3. Make sure that the speaker volume is not muted or turned down too low.
To open Volume Control...
*Click the Start button ,
*Click Control Panel
*Click Hardware and Sound
*Under Audio Devices and Sound, click Adjust system volume.
*Under Main Volume, move the slider up or down to raise or lower the volume.
If you still have no sound after checking the solutions above, you more than likely have a bad sound card.
Jul 13, 2010 | Computers & Internet
Speakers are not making any sounds
ok let's try a simple test.unplug the the usb.i hope that your speaker has its own power supply.turn it on.try to touch the inputs of the speaker, you should hear humming sounds.if yes, then your speaker is ok.if the speaker is getting its power from the USB port, i suggest you should use its independent power.the USB does not have enough to supply your speakers. try also the output jacks for built-in audio of the pc, ok.
May 31, 2009 | Insignia 2.0 Speaker System (2-Piece)
No sound, cenral and rear speakers Dell 5650 speakers
the surround sound speakers connect to the computer by way of three connectors. the system should have come with an adapter that plugs all three connectors into one green connector. if you color match that green connector into the computer you should get sound out of the central and rear speakers. not sure if the surround sound will work correctly for movies, but you should get sound
Jan 20, 2009 | Dell 5650 Computer Speakers
Speakers are plugged in correctly, lights on but still no sound
Check your output jack again and make sure its on the green jack
and also check your speaker wires, if okay then check this;
For Windows XP;
  1. Go to Control Panel
  2. Sounds and Audio Devices
  3. On the Volume tab under "Device volume" check that sound is NOT muted
  4. Adjust volume control
  5. Check "Speaker Setup" under "Speaker settings" under the "Advanced" button
For Vista:
  1. Control Panel
  2. Sounds
  3. Select Speakers then properties
  4. Make sure device is enabled
  5. Test sound
  6. Adjust volume controls
Under Device Manager make sure that under your sound card that you dont have a yellow exclamation. Yellow exclamation indicates you need to install the correct driver.
Jan 18, 2009 | E-Machines T6420 PC Desktop
Volume
re install the driver for your audio device.compaq will have the download you need
Dec 30, 2008 | Compaq Presario Notebook
Proview TFT has got volume option mute , need to unmute it & dont know :(
navigate with the monitor buttons to the OSD (on screen display). menu button brings up the OSD. then use volume buttons to move around. there should be a mute option or indications by symbols how to unmute the sound option. if there is not, i would guess pressing two buttons at the same time might do it.
Sep 30, 2008 | Computers & Internet
Vizio L32 32 in. LCD HDTV Logo
56 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
