Question about Kenmore Dryers
The power of the dryer is on, but it is not engaging. It is an electric dryer, older model about 13 years old.
  • Kenmore Master
  • 7,482 Answers
LWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 10, 2010
Kenmore elite oasis st model #110.68062801 won't run.
First check the breaker. You may have one leg out. Then check the starter switch. Also check the door switch. It could be broken or mislodged. When it is fully engaged, it will start up. Lastly the motor could be burned out. If it is an older model, then consider a new one. However, the repair on this is not that high if you can do it yourself.
Apr 26, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
My electric dryer will turn on butonly runs for 15 to 20 minutes then shuts off you can still hear it hum a bit
If its over ten years of age I would consider replacing it as it might not be possible to find parts and might not be a good investment in a "old" unit.
Dec 09, 2012 | Dryers
Ge Dryer 4 years old model DBVH512EF0WW no heat power is good to dryer heater ok thermostats ok PROCESS OF ELIMINATION LEADS ME TO a power board above drum, diagram says it has some relays on the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Sep 10, 2011 | GE DCVH515EFWW Electric Dryer
I have a 10 SEER heat pump about 16 years old, yesterday I notice that the outside unit was making a loud click noise in the heating mode. It's very close to the defrost electrical curcuit board. The unit...
Depending on make and model sounds like a check valve clicking. It can sound like it is coming from that area. You say your unit is 16 years old. Honeywell did servey on unit 10 years and older and found out they loose 25% effeicency after 10 years. You may think about changing it out. With the new tax credits you can get a 16 seer unit for the price of a 13 seer. I went from a 10 to 15 seer and my power bill dropped 40%. Rus.
Dec 03, 2009 | Heating & Cooling
Older dryer just stopped heating. Air still blows
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
Jun 16, 2009 | Kenmore 64742 Electric Dryer
Kenmore 80 series Gas Dryer
HI. you are correct. this dryer, although gas, is using a Glow igniter system. most older models used the snap igniter that clicks over and over to spark the burner but, this dryer is only 2 years old so, it should be outfitted with a glow igniter system. This igniter is powered by electricity.
It works in conjunction with a Flame sensor.
Jun 02, 2009 | Kenmore Dryers
New kenmore dryer, set up right from box, wont turn on
call Sears your dryer is guaranteed for 1 year, parts and labor
Jan 18, 2009 | Kenmore Elite HE4 Electric Dryer
Whirlpool Electric Dryer Won't Start
Your dryer has a non-resettable "thermal safety fuse" part number 3392519 which stops the machine dead when the temperature near the heater gets too high. Typically a restricted vent system causes this so you definitely want to check that before replacing it. A failed control thermostat can also cause this so check the operating temp too.
Dec 30, 2007 | Dryers
Dryers Logo
27 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
