Question about Whirlpool GD2SHGX Refrigerator
REFRIGERATOR MODEL GS6SHAXML00 SUDDENLY STOPPED COOLING ON BOTH SIDES.
HVACRH20
  • 237 Answers
SOURCE: Refrigerator not cooling
You will have to let it run for a while, then take the interior back cover off the freezer side to look at the frost pattern on the coils. There should be a nice even white frost on them all, if there is a solid block of ice the defrost cycle isn't working and if there is not much frost but a few inches then you likely have a sealed system leak (no more refrigerant). There can be other issues like the compressor start device not working or the temp control failed, etc. so we will have to go back and forth to do more troubleshooting. Repost with more info when you have it.
Posted on Jan 31, 2007
SOURCE: refrigerator stopped cooling
I too have a Kenmore, Model 106.52209100. No cooling at all in freezer and refrigeration sections. Lights and control panel status lights working. Motor running but only warm air. Issue was a relay that needed replacement. $71 for the relay, $180 fo the repairman.
Posted on Mar 05, 2008
SOURCE: Maytag refrigerator model #MFD2561HEW, 2
show me a diagram of ice water system for maytag
Posted on Apr 06, 2008
SOURCE: Refrigerator stopped cooling
I have the same problem on my GE model :
GTS18FBMERWW
It is a 18 cu ft, top freezer model.
If you get an idea please let me know.
TK
Posted on May 26, 2008
  • 125 Answers
SOURCE: Whirlpool refrigerator model ED5GTN cooling problem.
With the unit unplugged, take off the back cardboard panel. On the lt rear side you will find the compressor. On the lt side of the compressor you will see a white box mounted on the side, this is the relay, and it most likely will have a zip tie holding it on. Cut the zip tie or unhook the clip. Gently pry the relay from the side of the compressor. If it is badly burnt make sure there are 3 connectors on the compressor, sometimes they will burn one off or burn it so bad the compressor will need to be replaced $$$$ if not in warranty. If its not burnt thats hopefully what you will find, hold out your hand with the compressor side of the relay pointing down. Shake the relay like a salt shaker into your hand. If you get grey flakes/chunks in your hand the relay is bad and will need to be replaced. easy fix for about $45 - $50.
Posted on Apr 18, 2009
My Samsung side by side refrigerator stopped cooling suddenly. Is there a troubleshooting tip or re-set? It was running fine and then without warning both refrigerator and freezer stopped cooling.
First step - disconnect power, wait 15 minutes, plug it back in again.
Second step - find model and sub-model number, do a search to see if it's a common problem.
Nov 02, 2017 | Samsung Refrigerators
Kitchenaid side-by-side refrigerator is running but not cooling. What is the possible cause?
Many different possible causes. We'll need more information to troubleshoot this
Mar 10, 2014 | Refrigerators
All of a sudden, water started comming from the freezer. Seems the freezer stopped (refrigerator) cooling/ What do you think is the problem, and is it a major situation. ????
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 24, 2010 | Whirlpool GS6NBEXR Side by Side...
My freezer is working fine but my refrigerator stopped working suddenly
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 09, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerator stop cooling
THIS DOESN"T SAY WHICH FAN IS WORKING IF THE FREEZER FAN STOPS WORKING THE FRIGE WILL NOT GET COLD.
DOES FREEZER STILL FREEZE?. IF SO ITS YOUR FAN
Aug 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Suddenly stopped cooling. Fan runs compressor doesn't.
Hi, If fans are running, most likely relay and/or capacitor. Do you here the compressor try to click on at all?
May 13, 2009 | Refrigerators
Side by Side fridge stops cooling and the works again !
soiunds like the defrost timer is bad, Unless your highly mechanically inclined I would go ahead and call out the service repair company and tell them to be sure to bring allong a timer fo your unit. Hope this helps and good luck.
Jan 09, 2009 | Whirlpool ED2FHGX Side by Side...
Water Dispensor leak on Whirlpool Refridgerator
The solenoid valve needs replacing, located at the back of the refrigerator. If you have well water you will need to install a filter on the supply line.
Jan 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Coldspot Side by Side Model 51559101
I also have the same refrigerator model 106.56566400 and periodically when the power goes off in the house the refrigerator & freezer will stop cooling. Try pushing the on/off button located inside the refrigerator to the left of the digital temperature controls. Hold the button down, this turns the unit off, then press it again to turn it back on. This basically resets the refrigerator, and most of the time works to get the refrigerator cooling again. Try this first before calling a repair man.
Nov 22, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Whirlpool GD2SHGX Refrigerator Logo
60 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
