Question about Samsung Washing Machines
Washing machine flashing de - Samsung Washing Machines
    Scholar:
  • 39 Answers
I haven't seen a DE is it maybe DC? these are the known codes
DL - Door unlocked when washer is running DS - Door is open when washer is running NF - Washer tried to fill but was not successful due to clogged water lines or closed water valves. ND - Washer is not draining it can also mean that the unit senses a small clog or frozen hose. DC - Unbalanced load prevented the washer from spinning. When the weight of the laundry is about 1kg the center of the weight gets shifted. redistribute the load and restart or add more clothing.
SUDS - Too many suds are detected, the unit will be put on hold until the suds are reduced the it will go back on. when it completes the wash it will flash END and SUDS. make sure you use HE (high efficiency) detergent
Posted on Oct 10, 2010
Top load machine, been fine til today, will not move thru cycle, keeps turning itself of with 'de' notice, also has leaked some from inside machine
Troubleshooting LG Top-Loading Washing MachineDoor Error. The washing machine gives a flashing beeping DE error that the door (top loader) is still open while this is not the case. The small magnet has broken/fallen off. Attach a new magnet to the door (top loader) that will trigger that the door is now closed. Why dE Error is displayed on the panel of the Washing Machine
Why 'dE' Error is displayed on the panel of the Washing Machine? Last Update date : 2017.01.19
You may encounter a situation when your washing machine displays 'dE' error. This error appears when the door is not porperly locked.
If the Machine is displaying "dE" error, kindly check for the following :
? First and foremost the door must be properly closed.
? You can check the end of the drain hose is too low (Make sure the holder of drain hose in the back is intact).
? Also, you can check the end of the drain hose is submerged in water.
Jan 02, 2018 | Washing Machines
The message flashing says 'door' what do I do?
You have a problem with the door switch interlock.
Indesit WIDE 146 (DE) Washing Machine Spares ' eSpares
www.espares.co.uk > Home > Washers & Dryers > Washing Machines > Indesit
  1. Cached
Items 1 - 10 of 60 - Universal stacking kit suitable for most washers and dryers measuring 60cm across More information. In Stock. Stock Number ES187394.
Get Indesit Washing Machine Spare Parts ' eSpares
  1. Cached
  2. Similar
Genuine Indesit washing machine spares including Drum lifters, Indesit ... Start your Indesit parts search by selecting your washing machine model number from ...
Indesit Washing Machine WIDE 146 (DE) Spares - indesitspares
www.indesitspares.co.uk/washing-machine/wide-146-de.../catalogue.pl?path...
  1. Cached
Indesit WIDE 146 (DE) Washing Machine Spares ... Fits models with serial number from 30127.0001 Please Note the above serial number changes does not ...
Indesit Washing Machine IWDE 146 UK Spares - indesitspares
www.indesitspares.co.uk/washing-machine/iwde-146-uk-f084074/catalogue.pl?...
  1. Cached
Indesit IWDE 146 UK Washing Machine Spares ... This part fits the following models: WIL133UK, WIL133UKCO, WIXE127UKV & Does Not Fit Mod. .... If you have just replaced the door seal on your appliance then you may need this retainer ...
Indesit Ecotime IWDE 146 Built-in Washer Dryer - White
www.indesit.co.uk/appliances_i/Washer_Dryer_IWDE_146/pid_F084074UK/42.do
  1. Cached
  2. Similar
Rating: 8.5/10 - ‎19 votes Indesit Ecotime IWDE 146 Built-in Washer Dryer - White, ... News & Offers; Service & Spares. Service · Spare Parts ... IWDE 146 reviews · Ask-an-owner ...
Washer dryer no wide 146 Google Search
Mar 24, 2017 | Washing Machines
My lg intello front loader washing machine door is stuck the machine will not wok as the de keep flashing any ideas how i can open door to get clothes out
put outlet hose on ground drain water out ,then between the handle and the manchine theres a hook put something there to pull it towards u and it will open but its not easy , but is for me
Jan 17, 2013 | LG WD-1080FD Front Load Washer
My washing machine is flashing DE what does it mean
DE error code is indicative of a "Door Error".
Check this diagnostic procedure: DE lgknowledgebase
Hope helps.
Aug 13, 2011 | Washing Machines
When starting the washer it flashes dE several times - then starts it;s wash cycle
As you do not mention the make and model I am guessing that 'dE' stands for Door Error. It thinks the door is not closed. It could be the lock itself or the door lock sensor is malfunctioning and requires checking/adjusting (if that is possible on your machine).
John C
Mar 03, 2011 | Washing Machines
Washing machine comes up flashing with a de sign
LG machines with DE (Drain Error) Water has not drained enough in 5minutes...Probably due to a partially blocked pump filter....Repeat drain to empty machine and cleat pump filter,,,Access via small door at floor level, unscrew pump cover, and clear filter... Some water may be released. Leaning machine back can help!...Good luck..Nomess
May 17, 2010 | Washing Machines
Flashing
revisar el nivel puesto que las lav tienen un sistema de anti bibracion que el cual la detiene
Aug 05, 2008 | Washing Machines
Door locking dE flashing
This generally refers to a locking latch not operating. I would need the make and model number to further assist you.
Jan 08, 2008 | Washing Machines
Washing Machines Logo
258 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
