Question about Sony PSP-3000 Black Console
I downloded videos from my pc to psp but I cant find the videos anywhere on my psp. how do I get into my psp memory stick?( I have checked under music,picture,and video sections. )
    President:
  • 2,653 Answers
You've got to copy them to the correct folders or else they won't show up. Videos go into the video folder, music into music, etc. etc.
Posted on Oct 10, 2010
My memory stick works fine in my psp but my pc does not recognize when I insert it into the pc. :-/ It doesn't show up anywhere...Please give an input.
might be that the reader in pc needs to have an extender as some of those are a bit deeper than on other devices
perhaps the model of pc might help with next solution
Jun 02, 2012 | Sony Memory Stick PRO Duo (2GB) for PSP
Pc driver for sony psp-1000
It's not so easy to erase PSP OS and if even you do it you wil brick your PSP(Your screen will be black when you will turn on it and only green light will flash few times.) I think you have bad memory stick or something like that. Because you are browsing memory stick and not PSP when you connect PSP to computer. Check if you have memory stick inside your PSP. Try to format memory stick in PSP. You can also try to restore PSP deafult settings. If you have Card Reader try to read and format card on computer. If nothing helps buy new memory stick.
Jul 11, 2010 | Sony PlayStation Portable (PSP) Console
Cant downlode stuff off my computer onto my psp
have you tried drag and drop, or copy and paste, or right-click and send to... be sure there in the right files and you have enough memory on your stick to do it. also make sure the files are psp compatable. if the problem still precists then update the driver for your psp.
Dec 15, 2009 | Sony PlayStation Portable (PSP) Console
How to put videos from pc to psp
You need to first make sure you have a video file on your memory stick in your PSP. The easiest way is to format the Mem stick. You can do this under the first icon with all you options on your PSP. Now the harder part of it.. You need to make sure the video is compatible with your PSP. The PSP plays Mp4 h264 files you cant just load any formatted video on the player and expect it to play. There are plenty of programs out there to do this. You can google it and find which product best suits you. I have found that DVD Fab works really well for this project. Once you have converted the video file to the proper Mp4 format connect your PSP to your pc. It will recognize it and usually auto-play. Click view files .... this will open a seperate window with the memory sticks files on it. Find the file labeled Videos and click and drag the file over to the PsP. After that disconnect the PsP by either pushing the O button or use your disconnection icon on your task bar on your pc and wholla you should be able to enjoy your video on a great screen.
Nov 12, 2009 | Sony PlayStation Portable (PSP) Console
PSP 2000 MEMORY STICK SLOT PROBLME
Turn the psp on go to system settings then format memory stick then insert the memory stick and format it and it should be fine.
Jan 28, 2009 | Sony PlayStation Portable (PSP) Slim...
Psp illiterate
Yes there is a way. What you will need is a PC, Some form of Memory stick Duo card Reader, And a PSP Compatible Memory stick Duo/Pro Duo.
If you havent already used the memory stick inside the PSP it will not have the correct Formatted file System for use in the PSP. but you can create the file system using your computer.
heres how to do it ! :
1) plug your Memory stick Duo/Pro Duo into the card reader on your computer.
2) open my computer, locate the Memory stick usually found under the "devices with removable storage" area.
3) once inside the memory stick, create 2 seperate folders. One called "PSP" and the other one called "MP_ROOT".
4) Navigate into the "PSP" Folder and create 3 Folders, "MUSIC", "PICTURE" & "VIDEO"
5) Copy & Paste the Necessary files into each Subsequent Sub-Folder within the "PSP" Folder.
Note : The PSP Can only handle Certain File types for Pictures, Music, And Video. i would suggest Navigating to http://psp.about.com/od/hardwarefirmware/p/compformat.htm before you transfer your files to ensure that you are adding files which are Viewable/Readable by The PSP's software.
Hope this helps !?
Oct 27, 2008 | Sony PlayStation Portable (PSP) Console
Transfering
place it in the video folder (note you probably want to convert it to mp4 format)
also if there isnt a video folder create one in your memory stick or under psp
in order to convert it download a program called prism converter from here
http://www.nchsoftware.com/prism/plus.html
Oct 19, 2008 | Sony PlayStation Portable (PSP) Console
I tryed putting a video on my psp and it didnt pop up in the videos but took up 400 mega bites of memory i cant get it off
You can play files of the following types on the PSP system.
  • Memory Stick Video Format
  • - MPEG-4 Simple Profile (AAC)
  • - H.264/MPEG-4 AVC Main Profile (CABAC) (AAC) and Baseline Profile (AAC)
  • MP4
  • AVI
  • - Motion JPEG (Linear PCM)
  • - Motion JPEG (μ-Law)
Copying a file manually Copy the video file to Memory Stick Duo media to enable it to be played on the PSP system. Using a PC, create a folder named "VIDEO" within the Memory Stick Duo media, and then copy the file into that folder.
Jul 07, 2008 | Sony PlayStation Portable (PSP) Console
Usb cable
Just like sorta of add-on to szwaan's answer:
You must have a memory stick to put music into your psp such as mp3 files, the psp itself does not have any internal memory for you to store any music files whatsoever.
if you got a memory stick already, connect your psp to your computer via usb cable, select usb under the setting section of your psp, and the memory stick drive will appear in your "my computer", so you can drag your music into the Music folder of your memory stick and play them from your psp.
Dec 21, 2007 | Sony PlayStation Portable (PSP) Console
PC doesnt recongize my memory stick as a formatted memory stick...
Do both systems run XP? Also, check the driver files on your PC, and test it with another card of the same make. Is the write-protection switch set to on? Test the card reader with other formats of cards, if it is a multiple reader, just to make sure that it is functioning at all.
Jun 04, 2007 | Sony PlayStation Portable (PSP) Console
Sony PSP-3000 Black Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
