Question about Sharp AL 800 Copier
Black line on side of copies
There seems to be a strange line on the sides of all our copies. I have a Sharp AL-800 copier and its about 5 years old. Any suggestions on if it can be fixed or should i just get a new copier? Thanks!
  • 148 Answers
You should replace the drum and toner cartridge if you haven't in the 5 years, that should take care of the lines. The only problem is the cartridges can cost more then the machines is worth... Hope that helps
Posted on May 31, 2008
What does E7 Error code mean for SHarp AL-800 copier?
?7 03 Problem related to the brightness of the laser emission 04 Error in determining the level of white in the performance of hatching 05 Error in determining the level of black during hatching 12 Error output level in the performance of hatching 14 Failure ASIC (MCU PWB) 15 Trouble copying lamps
Sep 19, 2010 | Sharp AL 800 Copier
I have a Sharp AL 1642 CS. It prints black copies. It came out of no where so I know it isnt dust on the lens. Even after adjusting brightness settings it prints pitch black pages. The bulb on the scanner...
Problem on three things.
1.OPC drum cleaning blade is very old,so lost her activities.
2. Laser unite very dirty,so you need clean.
3. setup or configure exposure control.
# Press Auto key three second
when exposure light indicate now position,select way lighter side.
Jan 20, 2010 | Sharp AL-1642CS Copier
How can i reset the drum on al 800 sharpgrayscale
You should have on the right side of the display panel a "C" key and on the far left side your "light" exposure key.
Press c-exposure-c-exposure the scree should go blank. using your key pad make the display show 24 then press your copy key. then make it show 7 the press your copy key. Press the C or CA key until the copier resets. The light should have gone off.
Oct 14, 2009 | Sharp AL 800 Copier
Sharp AL 1655CS Grayscale Copier prints with black lines
Lines on copies can come from the optict area, charge grid and comb or the fusing roller. Stop the copy halfway through the cycle and see where the line starts to appear. If you see it as much as you do the rest of the print, it is either optical or in the drum charge unit.
Jun 26, 2009 | Sharp AL-1655CS Copier
2 lines down the right side of paper - sharp 1641 CS copier
Your problem is most likely not the drum.
Can you make a copy on the glass itself and the lines DO not appear?
if yes this confirms it is not from the drum. Open the top and look at the Small strip of glass : is it dirty or have two dots, white out or Anything on there???? clean w/ alcohol. Any dots will look like lines when making a copy because the paper is moving on the glass.
If the lines are still coming out even on the glass then take a look at the Fuser (exit where it gets hot) are the rollers smooth and uniform or are they scratched???
Dec 11, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp Copier AL-1631. Copies with a black line (which moves positions on the page each time). Checked the manual and cleaned the part that it told me to. That did nothing to fix the problem.
If it only happens when using the document feeder (if fitted), then the small glass on the right hand side needs a clean ( normally tippex), if it occurs when copying from the glass and doc feed then your charge corna needs cleaning
Dec 01, 2008 | Sharp AL 1631 Copier
Big Black Ink Line in all copies
Lift up a lid and clean the tiny scanner glass. One black dot will cause that effect to happen when using the document feeder. If the glass is clean, open the door on the right side and look at the green drum for lines. If you see any lines on the drum, then it's time for it to be replaced.
Sep 22, 2008 | Sharp AL 1631 Copier
Sharp Al-800 Skewed Copies
one problem with this machine, a small pin comes out on the paper release handle in the back, which lets on side of the paper lift tray to come up higher than the other. might look in that area. good luck
May 15, 2008 | Sharp AL 800 Copier
Sharp AL 800 Copier Logo
99 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
