trying to start a load all i get is the pre wash light flashing press start but nothing happens .also tried to restart but no joy can you please help regards andy.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual) There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (maximum 7 inches). Snaking out your standpipe & drain would be good. All lights flashing indicates you have a block somewhere.
Pl. rate me if helped............
Was this helpful?
Yes
No
Popular Solutions for Hoover Nextra HNWL 3136 / HNWL
The selected programme will not complete and Im unable to open the door. If I select the rinse or...
(More)
The selected programme will not complete and Im unable to open the door. If I select the rinse or spin programme separatly it seems to work. Could it be anything to do with the soap dispenser as I removed and cleaned this out and found some hard lumps that I picked out.
Hoover Nextra washing machine - does first half of wash, then stops and the start and delay start...
(More)
Hoover Nextra washing machine - does first half of wash, then stops and the start and delay start lights flash 3 times, any help much appreciated - fridge has just stoppped working and could do without having to buy a new washer too! Thanks
how do you fit the spring in the door handle on my hoover nextra. I have split the door apart and...
(More)
how do you fit the spring in the door handle on my hoover nextra. I have split the door apart and got hold of a new part no problem, but the catch fell apart before I could make a detailed note of how the spring was fixed to the latch. Can anyone give me a clue to how the parts are assembled as I have tried many ways but the catch will not work properly
