Question about HP Business InkJet 2800 Printer
Printing 11 x 17 from Visio, only prints part of form
  • 50 Answers
Under the file menu pulldown select page setup; change the margins to 0.0
also try to set print area from the word proc. program under file/print
usally if u highlight the whole doc. set print area is available in the menu
Posted on Oct 10, 2010
Legal paper printing for canon 1210laser
For printing the Legal Size in cannon LBP-1210, follow the instruction:
Go to Start - Printers and Faxes - go to File menu - click Server properties - Create a new form (give name for ex : Khan Legal) then go to width : 8.50 inch. and Height : 14.00 inch - and then give specifications for LEFT - 0.20 RIGHT - 0.20 TOP - 0.20 BOTTOM - 0.20 - and then save form - go to Canon printer icon - set as default printer - go to properties - select forms - click Form 2 - change form - (Khan Legal) what ever you mentioned name - then apply - click OK - print a test page -
Hope this works.Cheers.
Jul 02, 2011 | Computers & Internet
Problems with Printing Special Size Forms
you have to chk the setting on the print setup.
Jul 04, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
One label printing over two label forms
Always check to make sure the printer is advancing one label at a time by itself before printing. If it does then you know the printer has a good read on the label size. Then if it misaligns when printing then you know the problem is in the printer driver because the printer is only going to do what it's told to do.
So best is to turn printer off, power up, press feed to see if one label feeds ok. If the label feed is off at this point then the printer needs to be calibrated which is done by pressing and holding FEED while turning the printer on.
Hope that helps !
Jun 03, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Printer does not attempt to pick up paper but gives out of paper message and or flashing paper sign on panel
steps:
(a) driving a pickup roller, picking up printing paper stacked in a paper cassette, and then, feeding the picked up printing paper to an image forming unit
(b) after picking up the printing paper in step (a), checking to determine whether or not the printing paper has been fed to the image forming unit(c) when it has been determined in step (b) that the printing paper has not been fed and a paper feed error has been generated, again driving the pickup roller, so as to attempt to pick up the printing paper stacked in the paper cassette again.
Apr 21, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
It printing but with black forms on paper
black form because of ribbon is touching to the paper for this solution is adjust head gap of the printer or put the leaver in 3+1 setting ...and try ....
replace the ribbon mask ..........
Dec 10, 2009 | Epson LQ-2090 Matrix Printer
Lexmark Z2420: How to nudge margins to align a form
Go into your printer software before printing, tell the software what you are printing on letter, 4x6 labels etc.... then print
Jul 08, 2009 | Lexmark Z2420 Printer
TallyGenicom 2265+ not printing with custom paper size
There may be a number of causes for the problem you are seeing. There are a number of places which may hold the origin to the page length problem you are seeing, in order of precedence these are;
  1. The page size set in the software package printing the 6 x 4.25 cards
  2. The page size set the printer driver printing to the printer
  3. The page size set on the printer
I would recommend the follwoing;
  1. Set the form length on the printer to 6 inches (i am assuming this is the length of the card)
    The form length can be set through the menu and is normally set in lines (normaly the print size is set to 6 LPI) so the form length should be set to 33 lines
  2. Create a custom form size in SERVER PROPERTIES on the Windows XP machine to match the form size you are using.
    Ensure you select this form size in both PRINTER PROPERTIES and PRINTING PREFERENCES
  3. Try printing some Windows Test pages to see if these respect the page size selected withing the printer driver properties.
If the Windows Test Pages do not print correctly I would recommend checking how you are creating the CUSTOM SIZE form, perhaps create a new form and double check the form properties one it has been saved to confirm these are correct.
Check you are using the correct printer driver for the printer, you should be using the 2265+ printer driver. As a test you may wish to install the GENERIC TEXT printer driver or the EPSON LQ2250 driver, these will be included in the Windows Add Printers Wizard and should print OK to the 2265+.
If the Windows Test Page prints OK I think you would need to look at the software package printing to the printer. Ensure the correct page size is selected here also, perhaps try printing from another software package selecting your custom size form to see if these print correctly.
It is passable your software package is sending escape commands to the printer to call up the page size, I note you say Genicom printers printed ok from Win 98. The 2265+ may not have the same emulations as the Genicom printers.
You can print a menu print on both Genicom (if these are available) and 2265+ and compare the settings on these.
I do not believe the 2265+ has a Genicom emulation as standard, but you may be able to load an alternative version of firmware into the 2265+ which provides the Genicom emulation. If the data going to the printer contains Genicom Escape command to set form length this may resolve the issue.
You may need to contact your TallyGenicom support department for the firmware (I think it may be called 7265+ firmware)
If you are able to provide Hex Dumps of the data to the TallyGenicom support people they should be able to say what is going wrong with the form length setting.
May 07, 2009 | TallyGenicom 2265+ Matrix Printer
Feed and Tear Off position problem
You can give this a try. This will alter the top of form setting.
http://www.profitmonster.com/printers/ml320tb.html
Let me know if this helps.
Mar 27, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Network router printing issue
sure..you can put all the computers on the same workgroup, and form a network
we got fresh wireless drivers here too
Mar 17, 2008 | D-Link Wireless
Printing 'Form information: No form stored' non stop
rchamorro,
Sometimes, resetting the printer to the factory defaults solves some of the problems. For troublehooting and to overwrite all stored parameters, send the ^default command.
Mar 14, 2008 | Zebra LP 2844 Thermal Printer
HP Business InkJet 2800 Printer Logo
267 people viewed this question
Seeker5211
Seeker5211
