Question about Toshiba 56HM195 56" Projection HDTV
Amber light blinks 3 times every 2 to 3 seconds no picture no power. can hear noise in the back seems to be trying to start
  • 597 Answers
The reason you have the amber light blinking is because you are having power supplied to the television, but the television is not using it up.
There is a problem with the power board of the television that is why it is not having power supplied to the main board of the television.
Have your power panel replaced and your television will be in good shape once again.
Take care
Posted on Oct 10, 2010
Why would my projector refuse to start with a seemingly intact light bulb?
If you only have 300 hours on it it should still be under warranty. Before doing something to void that I would check with Optoma techs.
Jul 23, 2014 | Optoma HD20 DLP Projector
Aux power led light is amber on dimension E521
I think your problem is your memory or video card.
Below are some steps that I recommend.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Below are links and info I found from Dell's Website based on your model.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/specs.htm
Controls and Lights Front of computer:
Power button - push button
Power light
green light - Blinking green in sleep state; solid green for power-on state.
amber light - Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see "Power Problems" in your Owner's Manual).
Diagnostic lights
four lights on the front panel (see Diagnostic Lights.)
Standby power light
AUX_PWR_LED on the system board
Hard-drive activity light
green light - When the computer is reading data from or writing data to the hard drive.
LAN indicator light
green light - Solid green indicates that a LAN (local area network) connection is established.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/adtshoot.htm#wp1056411
Jun 03, 2012 | Dell Dimension E521 (D10E16) PC Desktop
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
I turned on my Dell Dimension 4700 computer,but the amber light started to blink . I held the start up button for 5 seconds and the light went out. I tried to start it up again and got the same thing,...
Vaughn it sounds like the power supply is going bad, try another known good working power supply. If that doesn't work then the motherboard would need to be replaced. If the power supply isn't giving the correct voltages that could cause the computer not to turn on. If the motheboard isn't able to convert the voltages properly then the motherboard could be faulty.
Dec 23, 2009 | Dell Dimension 4700 PC Desktop
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Blue light off can't turn on t.v.
The behavior of your LCD is related to a failing or defective power supply.
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Mar 09, 2009 | Astar LTV-32ASB 32 in. LCD Television
Lcd monitor power light flashing with no img. seems 2 be frozen
The display is in safe mode and you will need to reset the display to get the display out of the safe mode. There are 2 different model revisions. Please choose the method that will match your revision. Depending on the revision of the monitor, one of the following 2 methods should reset it to a normal state. This reset generally requires both hands and it is sometimes easier with another person.
If the serial number begins with an A and/or your power button on the far right (5th button from left):
Method #1
1. Unplug the VGA cable.
2. Remove the power cable from the back of the monitor.
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 3 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
5. If the procedure worked, the green light will go to amber and you should see a "No Signal" message on the screen for a few seconds.
Method #2
4. Keep holding the buttons until the 4th green LED blink; then, let go. The green light should be steady when you release the buttons.
If the serial number begins with a B and/or your power button is in the middle (3rd button from left):
Method #1
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see attached picture) and while continuing to hold the buttons, plug the power cable back in.4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
Method #2
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
If you have tried the reset a few times and it does not solve your issue, please Ask a Question to submit a request through the system or call 1-866-752-6271 Option 1 to contact technical support.
Mar 02, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
Protron 26' t.v
Dec 30, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
TV doesn't turn on
You really should give make & model number when posting, it helps us immensely, your lamp and possibly the ballast is bad, start with a new lamp first, odds are very good that it will fix your problem, can`t help more without manufacturer and model number, good luck, ps, order the original lamp, generics are junk and a waste of your money.
Nov 27, 2007 | Televison & Video
Toshiba 56HM195 56" Projection HDTV Logo
296 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
