Question about Evga (133-P4-NF51-AX) Motherboard
I get the EVGA screan and the post code is 52 iam trying to get into bios and cannt what do I need to do
PC Freezes During Boot and at the BIOS Screen, EVGA P55 Classified 200
Beep Code Descriptions
1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps 3270 keyboard card
Aug 30, 2012 | Evga P55 Classified 200 (160LFE659KR)...
I reinstall O.S. Windows XP Home, need the all driver!!! were i can find for the mb EVGA 131-k8-nf44 Tanks Enzo agostino
Go to:http://www.nvidia.com/Download/index.aspx?lang=en-us
Select: Legacy> Nforce 4 series > nforce 4 SLI AMD > then select your OS and Language.
Then download the drivers.
Here is the updated BIOS too ftp://ftp.evga.com/BIOS/NF41_E61.exe
Hope this helps.
Jul 22, 2011 | Evga (131-K8-NF44-AX) Motherboard
Cannt inter bios becuse close by password acer 5720
i not sure but ill try to help all bios password user
enter wrong password 3 time if u get a code send me that code ill send u master password if i could not help dont angry let me know ill find another way.. Thanks
Aug 04, 2010 | Acer Aspire 5720-4230 Notebook
I have a EVGA 133-K8-NF41 mobo and want to update my BIOS but can't find what the latest would be and the flash utility for it. can you help?
forum topic: http://www.evga.com/forums/tm.aspx?high=&m=63702&mpage=1#65116
direct link to bios: ftp://ftp.evga.com/BIOS/NF41_E61.exe
Feb 25, 2010 | Evga 133-K8-NF41-AX Motherboard
I've been building computers since 1992. Never saw this. My EVGA MB is in a BIOS loop. Boot .. beep .. EVGA Splash ... -Reboot automatically- Beep ... EVGA Spash ... -Reboot automatically. It's like a...
Turn the computer off.
Hold DOWN the "any" key.
Turn the computer on.
When you see "keyboard error. Press Fxx to enter BIOS SETUP", RELEASE the "any" key, and press the 'Fxx' key.
While in setup, change the boot-order to "floppy-first".
Then, everytime that you boot, your motherboard will "grind" the 3.5-inch disk, looking for a boot-sector.
If it DOES "grind", then BIOS-loading has completed, and there's something wrong with the boot-sector on either the CD-ROM or the disk-drive, i.e., Windows "crashes" during startup, and reboots itself.
Or, press F8 when you think that your computer is booting from the disk-drive, to enter the "Windows boot menu". Try "Boot In Safe Mode".
Feb 03, 2010 | Evga MB 115-K8-NF33-AX NF3-250 754...
MSI nForce 680i Refernce board SLI problems
Try first resetting the bios to default, sometimes there is no way to have a video adapter working when you get this kind of problems, I will tell you more.
Dec 12, 2008 | Evga nForce 680i SLI (122CKNF68)...
Evga 790i bios
Does it sound like it is powering up...making any noise at all?...anything such as beeps or anything??
be sure to check all connections!!
Jun 06, 2008 | Computers & Internet
Open Questions:
Reset button on EVGA motherboard solid yellow I have an EVGA X58 SLI Motherboard, model 132-BL-E758. My 1200w power supply went out and I had to replace it. I did so with a Corsair 860 hoping it would do the job. I'm running a Radian 7970 video card. I understand it needs a 550w power supply so this should be enough. It may not be. The computer kept shutting down. The Motherboard lights were still on so I presumed the power supply was still working. I checked all my wiring to the Motherboard and may have created a problem. Now, although the fans come on and the Motherboard lights up (green, yellow, and blue lights in the middle of the board) the computer won't start up. The monitor says No Input. I hear nothing to suggest the drives are turning or loading Windows (7). Additionally, and where I hope someone can help is that now my red LED light next to the start switch on the computer case won't come on when I press the start button. Looking inside I see that although all three lights are on (green, blue, yellow) the green power button (next to the yellow reset button and red CMOS button) is not on. Additionally, the yellow reset button is lit up and pressing it doesn't change anything. The question is, is the yellow reset button and green power button on your Motherboard supposed to be lit up, or off? Secondly, with the reset button lit up and the power button off, does that tell you anything? If so, please share that with me. I'm at a loss as to whether I have a possible Motherboard problem, or whether the problem lies in the possibly undersized power supply that I installed, or if I've wired this incorrectly. If all fans come on and the board lights up, does that suggest that the board is fine or could there be a part of the board that isn't working and causing this problem? Because I wired this myself when I installed the new power supply is it possible that I've not installed a wire? Do these symptoms tell you anything that can help me or lead me in the right direction?
Jan 15, 2018 | Evga Computers & Internet
Evga (133-P4-NF51-AX) Motherboard Logo
Top Evga Computers & Internet Experts
David
David
Larry Rider
Larry Rider
Josh Levin
Josh Levin
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
