Question about HP Compaq Presario 2100 Laptop
My display is small and the color is off.Everytime i go into settings to fix it the computer reboots.How do i fix this?
    President:
  • 2,653 Answers
Try updating the video driver.
Check Compaq's support page for your model here.
HP and Compaq are the same company now so don't let that throw you off ;)
Also you have a 2100 series, there is a specific model number on the bottom ;)
Posted on Oct 10, 2010
  • RescueTechLA
    RescueTechLA Oct 16, 2010
    Did that resolve your issue?
1) I have a Toshiba Pro 600 model ps600c-01qw4. The problem of this laptop is that when i turn the computer on the screen is very small. So I went into the display setting and fix the problem. But when i...
Check the monitor in the device manager. NOT regular display properties. Make sure the monitor is the correct type. Try different settings in device manager for the monitor. Maybe try uninstalling the video card drivers, reboot and reinstall the drivers. Let me know if this does not work.
Joe
May 17, 2010 | Computers & Internet
SOYO DYLM24E6 DISPLAYS OUT OF RANGE WAS TOLD MONITOR HAS A RESET BUTTON IF SO WHERE OR IS THERE A FIX FOR THIS MONITOR IT IS NEW
Restart your computer in Safe Mode
(or reconnect your previous monitor).
Set the screen-resolution to 800 by 600 at 60 Hertz.
Shutdown, connect the new monitor, and restart, and your Soyo monitor will be able to display something, using these "NOT-out-of-range" values.
Try changing the resolution to 1024-by-768, or 1280-by-1024,
and "test' these values, to see what values are "in-range" for your new monitor.
Jan 07, 2010 | Soyo DYLM24D6 LCD Monitor
Unable to change color depth...
Ok I think i found your problem. You don't need to install any drivers.
Switch your display to 256 colors To switch your display to 256 colors
Some games and other software programs require that your monitor be set to 256 colors, or they run better in 256 colors. Many of those programs will switch your monitor to 256 colors automatically when you start the program. For those that don't, follow the steps below if you want to switch the display temporarily while the game or program is running.
  1. On your desktop or on the Start menu, right-click the game or other program that you want to run in 256 colors, and then click Properties.
  2. Click the Compatibility tab.
  3. Select the Run in 256 colors check box.
  • The screen will revert to your default color quality when you close the program.
  • Try switching to 256 colors if your software program shows the wrong color or the graphics redraw slowly.
  • If your software program appears in a small window in the center of your screen, you can increase its size by changing your screen resolution temporarily. Follow the procedure above, but in step 3 select the Run in 640x480 screen resolution check box. Your screen resolution will revert to its previous resolution when you close the program.
  • The Compatibility tab is available only for programs or games located on your computer's hard disk. It is not available if the program is stored on a floppy disk, compact disk, or a network.
Please rate this if it fix your issue
May 30, 2009 | eMachines W3611 PC Desktop
Display Color
check your display setings,,change the resolution,, if not download a new video driver
May 13, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My games keep telling me {unable to create 3d device} when ever i try to acess my games e.g jamesbond nightfire
I CAN HELP YOU WITH THIS PROBLEM IT IS IN THE ADVANCE SETTINGS OF THE VIDEO CARD SYSTEM DRIVERS
GOTO CONTROL PANEL AND OPEN UP FOLDER CALLED DISPLAY SETTINGS
FIND BOX SAYS ADVANCE SETTINGS
OPEN THIS FOLDER INSIDE THE FOLDER YOU ARE GOING TO SEE ALOT OF OTHER FOLDER AND THEY MAY ALL HAVE THE SAME INFORMATION MINE SAYS:
ADAPTER,
COLOR MANAGEMENT,
MONITOR,
TROUBLESHOOTING,
GAMING,
ATI CATALSTIC [TM] CONTROL CENTER ( OPEN THIS FOLDER)
INSIDE THE FOLDER IT ASK YOU AGAIN IF YOU WANT TO OPEN IT AGAIN AND YOU WANT TOO CLICK ON IT
INSIDE THIS BOX YOU ARE GOING TO HAVE THE FOLLOWING INFORMATIONS:
GRAPHICS SOFTWARE & HARDWARE
DISPLAY MANAGER
DISPLAY OPTIONS
MONITOR PROPERTIES 0 OR 1
3D SETTINGS
COLOR SETTINGS
AVIVO TM VIDEO
POWER PLAY
SOME OF THESE HAVE WHERE THE COMPUTER WILL SETUP CURTAIN DRIVER FOR THE GAMES YOU WANT TO PLAY, HELP FPS, GRAPHIC INTENSE, FAST SPEED, CONTROL SPEED OF FANS, CPU, COOLER DEVICES AND SO ON.
YOU WILL HAVE OPTION TO PUT THE ICON ON THE START UP MENU EVERYTIME THE SYSTEM STARTS UP SO YOU CAN MAKE CHANGES ON THE FLY.
OTHER OPTIONS: VIEW,HOTKEYS,PROFILES,PERFERANCES,AND HELP, AND SYSTEM INFORMATION
2D OPTIONS
2D DRIVERS FILE PATH & DRIVER VERSION
DIRECT3D
OPENGL VERSIONS
PROVIDERS
DRIVERS PACKAGING DRIVERS
GAMING OPTIONS
EVERRY GAME BOX YOU PUT A CHECK MARK IN WHEN YOU ACTIVATE THAT PROGRAM IT WILL LOAD YOUR DRIVERS FOR THAT GAME AND WHEN YOU SIGN OUT THAN THE COMPUTER WILL WANT TO RESET TO ORGINAL WINDOWS SETTINGS
REBOOT
ROD
Feb 21, 2009 | Dell GeForce2 MX, (32 MB) Graphic Card
Pc display
This maybe due to lack of Video Card/Monitor drivers or the resolution is set to a small size. You will have to find out which video card you have, and if you have an LCD sometimes they come with drivers (Samsung LCDs have drivers). To find out what video card you have, you can usually go off the model name and number of your computer and get the drivers from your manufacturer's website. If it is a home built computer, you will have to look at the card/motherboard model and serial numbers to figure out the video card they use. Normally XP has a default video driver and it should not do a miniature resolution, but it happens sometimes.
Nov 03, 2008 | Computers & Internet
Window xp display
This should be your graphics card driver is not it. The original installation of hardware drivers may be better.
If that is not what system you set up the software in question. Can be re-systems.
http://www.notebooks-driver.com
Monitor display problem
Your resolution or refresh rate has somehow gotten altered in the display settings. Reboot the computer in safe mode and correct the display settings to fix.
Aug 02, 2008 | HP Pavilion MX70 17" CRT Monitor
Screen colors
possibly screen color depth is set to 16 colors. - open control panel display - settings tab, slide the color depth to 16 bit. - change resolution to 800 x 600 for now. reboot and see if that does the trick, then readjust settings to your tastes.
Aug 26, 2007 | Compaq CV 7500 17" CRT Monitor
HP Compaq Presario 2100 Laptop Logo
52 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
