Question about GE (PSS26MSRSS) Side by Side Refrigerator
Model #GSH25JFRFBB Seriel # DH255267 Clicking sound behind metal panel right hand side on back Not cooling Compressor not activating? Looking for reset
    Sergeant:
    Champion:
  • 351 Answers
That the computer sound like it bad no reset need to replace the computer jim
Posted on Oct 10, 2010
Fan working but no cold air
Electricity, enough Freon, a working fan and a good compressor and you usually have cold air. Maybe the compressor?
May 10, 2015 | Refrigerators
Whirlpool side by side is not working, cold air is blowing from bottom of unit under freezer, there is a click like something is trying to start
if everything is melting inside freezer and you hear a clicking sound most likely you have a bad start device located on the side of the compressor,unplug it until you repair it or you can damage the compressor,pull out the machine.unplug it and remove the bottom panel,look at the compressor,you'll see a metal clip holding a cover onto the start device,pop the clip off,remove the cover and then slide the start device off of the compressor,there's three pins on the side of compressor,the device slides onto the pins,when you have it off of the compressor,the easiest way to check it is to shake it,if you hear pieces rattling around in it it's cooked.next time send the model number and i can look up your machine,open the fridge door,look up on the right hand side of the wall up near the ceiling,you'll see the model number,you'll need this to get the correct part.
Jan 23, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
WILL NOT COOL OR MAKE ICE. COMPRESSOR DOES NOT SEEM TO COME ON.
next time send the model number off of the fridge,side by side or bottom freezer model number is in fresh food section,right hand wall up near ceiling or on ceiling,top freezer look on left side wall.if the compressor isn't running most likely you have a bad start device located on the side of compressor,pull out the fridge,unplug it,remove the back outside bottom panel and you'll see the compressor,pop off the metal clip,remove the cover and slide off the start device or overload and relay same thing,then shake the device,if you hear pieces rattling around inside it it's bad,easiest way to check it,if you open the freezer door and you hear the fan blowing around most likely this will be your problem,you might hear the compressor clicking trying to start and it will be hot,also vac out the condenser coil and make sure the condenser fan motor is running good,over heating can take out the start device.good luck.
Jul 05, 2012 | Frigidaire Refrigerators
The freezer and the refrigerator stop cooling. I'm looking for the electronic control board, but I don't know where is located??
The control board is located behind a panel on the back of the fridge...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 31, 2011 | Maytag MSD2736GR Side by Side Refrigerator
Hello there, I have a GE model GSH 25 JF side by side fridge. I believe it's a 2005 model. The Freezer and Fridge are running, but neiher is cool at all. There is a clicking noise happening about every...
Sounds like you have a starter problem. There is a part on the compressor used to start up. It should be if I remember correctly a capacitor near or on the motor. When the light dims it is trying to start up but failing.
Sep 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge gss25ifrf ww side by side fridge clicking
Sounds like the main control board is bad . Pt # WR55X10656 . This board is located behind the 8 " X 10 " , panel just above the compressor compartment . The compressor relay , is what you hear clicking , cutting the compressor , on/off . Even the dispensor board , is operated by the main control board .
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side refrigerator
You need to replace the PTC relay that is on the compressor. The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Feb 25, 2009 | Electrolux Refrigerators
Maytag side by side
Sounds like a compressor problem. Unplug it and check the condenser for cleanliness. Clean if you see any dust build-up. Condenser may be located in back behind a removable panel. be sure to reinstall the panel when you are done. If the compressor is hot allow it to cool off and plug the refrigerator back in. If you get a hum and click from the compressor call for a service tech.
May 22, 2008 | Hotpoint HSS25GFP Side by Side...
Relay clicking, not cooling either side
check you paperwork , and manual. sounds like a compressor issue, which "should" be covered by 5 year manufacture warr. reason i say "should" is hte warr's all changed jan1/06. only one year form there . but check your manual itll have the warr info in it
Mar 20, 2008 | Hotpoint HSM25GFRSA
First of all Give me model# and Serial#.
you will most likely have to replace main control board and evaporator fan motor. They have had a service bulletin out on this problem.
Jan 17, 2008 | Hotpoint HSS25GFP Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
197 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
