How to delete SATA Port O HDD when I Sign in - Computers & Internet
  • thanhlam8468 Oct 10, 2010
    I have tried your instructions but I still can not delete Sata Port o HDD when I sign in.
    I have come to Security but I can not reach the HHD O and it said the``Hdd password Frozen"
    Please help me. thank you very much.
    Aspire 5520 Acer
  • 4,281 Answers
When you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios. Then go to IDE configuration disable SATA then save settings and exit from bios. If you are not able to enter in bios or if it need password then open cpu cabinet then pull cmos cell from motherboard for 10 seconds so all settings defaults. then you can disable SATA from bios. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Oct 10, 2010
  • 3,530 Answers
Granted that you know the password, you need to enter your BIOS set up and disable this.
Here is a link for the step by step instructions.
All the best!
  • Jose Cada
    Jose Cada Oct 10, 2010
    Please tell me what your machine is and your operating system.
5 Suggested Answers
s_4u_11
  • 535 Answers
SOURCE: bios not recognising Sata HDD
u have to change the bios battry
Posted on Oct 27, 2008
  • 85 Answers
SOURCE: use sata hdd on vt8237r +
Normally they will be recognised,after connecting reset your cmos jumper ,set date etc and save your settings before reboot
Posted on Jan 15, 2009
SOURCE: I have a asus K8S-MX i want to connect SATA HDD
To enable sata port press Delete Key when computer Starts. U will get BIOS menu. On there the Main settings window the second last option is to enable sata option. If u want to install widows OS (XP,2000, Server edition) **** Driver CD and go to RAID folder there u get a driver ( shown as Floppy drive Image). Incerte Floppy in drive and click that icon. And click Extract. Then incert the OS CD. On starting of instalition u will get a option press F6 to install Raid Disk. Press F6. On Bitween instalition u will get a option to install this Raid. ( With out this RAID u cant install XP or Other vartions of windows in ur sata hard drive)
Posted on Jun 07, 2009
  • 11800 Answers
SOURCE: connecting sata hdd on 845ge
Directly you can't, the chipset on that motherboard doesn't support SATA. You will have to buy a PCI SATA card and plug the disk in it.
Posted on May 04, 2010
Pc
start pc press F2 or Delete enter Bios, check boot priority is dvd-rw od hdd set to suit, change ide/sata cable to hdd they do burn out... make sure sata 1 hdd / or ide 1 master, for C drive. hope this helps. I/O errors can occur usually swapping order of boot can fix this...
May 30, 2013 | Acer Aspire Computers & Internet
Can't setup OS in SATA HDD in Intel d945gccr
Hi.
XP will not install until you go into the BIOS and find the menu page (probably by moving across the top level of tabs) where the SATA hard drives are configured. On that page you will see the ports and at least one, maybe all, will be Enabled. Close to that will be the port mode, usually setable individually for each port. Choices may include IDE (or PATA) Emulation, SATA, AHCI. Set your port to IDE emulation. Now look at the bottom for the key to Save and Exit - often the F10 key, press that key and select OK, the computer will restart and you should now be able to install Windows XP without any problems.
To get into the BIOS you have to press the Del or Esc key when you first turn the computer on.
Regards.
Feb 04, 2013 | Intel D945GCCR Motherboard
I got a new SATA 500gb HDD but the motherboard wont detect it.
Access to your Bios Setup & configure the Bios settings.
Features Setup Page : This page sets up some parameters for peripheral devices connected to the system.
CMOS SETUP UTILITY - Copyright (C) 1985-2003, American Megatrends, Inc.
Features Setup
OnBoard Floppy Controller : Enabled
Serial Port1 Address 3F8/IRQ4 : Enabled
OnBoard IR Port : Disabled
Parallel Port Address : 378
Parrllel Port Mode : ECP
ECP Mode DMA Chnnel : DMA3
Parallel Port IRQ : IRQ7
OnBoard PCI IDE Controller : Both
OnBoard SATA-IDE
: Enabled *(Make sure This is enabled)
Audio Device : Enabled
Modem Device : Auto
Ethernet Device : Enabled
If you have got a SATA III HDD, ie if it is a Western Digital Sata III you need to configure the jumpers to work with your older Sata interface port.(Only Sata 1 & 2 ports on your Mainboard Socket 478). As for Seagate Sata III HDD, the configuration is automatic.
If your 500GD HDD is not detected, try updating the BIOS!
A word of caution "Updating the Bios is not for the Novice" Do it at your own risk. Failure in updating the Bios may render your Mainboard useless.
Hope it helps.
May 14, 2011 | PC Chips M955G Motherboard
Connecting sata hdd on 845ge
May 04, 2010 | Intel 845GE Motherboard
M2N32-SLI Deluxe Motherboard: don`t reconize sata hdd...
The SATA port on the motherboard or the SATA cable or the HDD itself could be bad.
May 03, 2010 | Computers & Internet
Me pide sata port 0 hdd user password
don't speak your tongue, try using safemode to enter pc than fix the problem inside user accounts by deleting account and creating a new one,may work
Apr 22, 2009 | Computers & Internet
Mar 31, 2009 | ASUS K8S-MX Motherboard
2 Sata Hdd not supported
Hi rafiqbrush, let me go over a few things for the P5B MB.
There is a total of 5 serial ATA SATA drive ports on the board & one ATA IDE/PATA port.
The 4 main SATA ports are numbered, 1 - 4. Your primary SATA drive must be connected to SATA port 1. Your second SATA drive must be connected to SATA port 3. See page 2-26 in your manual.
All SATA drives are seen as master drives. Once the two SATA drives are connected (As per manual), boot to the bios main menu.
At the main bios menu make sure your bios shows both SATA drives. Than go to the bios title "Boot". Make sure your primary SATA drive 1 is listed in the boot order. Save & exit the bios. (SATA drive 1 must have windows installed on it).
Link to Asus P5B web site;
http://support.asus.com/download/download.aspx?modelname=P5B&SLanguage=en-us
Good luck rafiqbrush!
Thank you for using fixya.
Mike
Dec 10, 2008 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
David Payne
David Payne
