Posted on May 30, 2008
DIFFERENCE BETWEEN IPOD CLASSIC & IPOD TOUCH
SIR I WUD LIKE TO KNOW WHAT IS THE MAJOR DIFFERENCE BETWEEN IPOD CLASSIC & IPOD TOUCH
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on May 31, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
6013
Points
29
Ipod classic has at least 2 to 3 times the capacity of ipod touch.
Ipod touch is touch screen and has max 16gb capacity
whilst ipod classic only has click wheel.and is like 60gb or something.
ipod touch is the iphone but without the phone bit,
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Sep 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7116
Points
You can convert your ipod touch in to an iphone by buying a case from www.buypeel520.com
You can call and text from your i pod touch then. not from your ipod classic.
A
Anonymous
What is apple ipod customer care number ?
Round The Clock and Yearly Customer Support to Fix iPod Issues -1-855-550-2552
Apple iPod is a portable media playing device. It let its users to play audio and video media files. It provides data storage from 2 GB to 128 GB. Currently there are four different iPod devices available, they are: iPod touch, iPod classic, iPod nano, and iPod shuffle and these devices are available in five different colors, color are: Gold, Silver, Pink, Space Grey, and Red.
iPod also have some issues, such as: forgot passcode in iPod Touch, unable to connect Wi-Fi to iPod Touch, unable to change the language in iPod Classic, how to change battery in iPod nano, etc. These types of issues are quickly fixable via our customer service. iPod users can avail our customer service for 365 or more days and 24 hours a day. We provide independent and personal customer service via telephonic instructions. Here are 2 issue-resolving samples from our customer service.
Issue-resolving samples from customer service:
Issue-resolving sample 1, how to reset iPod shuffle? Steps are:
If the iPod is already connected to your pc. Then unplug it.
Turn the switch of the iPod to Off. When the iPod is off, you will not be able to see green stripe.
Wait for at least 10 seconds.
Turn the switch to one of the play positions and you will see the stripe turn to green.
Issue-resolving sample 2, how to change maximum volume limit in iPod nano? Steps are:
Open Settings and then open "Volume Limit".
If you set a combination, then enter it using "Click Wheel" and then click on Center button for confirming it.
Change the maximum volume limit by using "Click Wheel".
Lastly, click on the Center button to accept the change.
Ring Apple iPod customer care number to avail support for bugs:
iPod users can avail our customer support for resolving issues by ringing our toll free Apple iPod customer care number. http://www.fixtechnicalsupport.com/apple-technical-support-number
Ipod classic has software issues
Dear sir or madam,if you are having problems with your iPod classic i would recommend plugging it into your computer, opening iTunes and clicking on the restore button. If you continue to have problems with your iPod classic take your iPod to your local apple store with a genius bar appointment already set up and they will help you furtherI hope this helps and that you fix your iPod
Sir, i have a apple ipod classic 80 gb but recently i cannot hear at one side of the headphone may be the reason i hve dropped it so i need to know how much cost to fix it in ...
Usually if you can only hear sound from one side of the headphones then it is often due to a problem with the headphones rather than the iPod.
Try a different pair of headphones and see if the audio improves. Otherwise, I would recommend inRepair, based in india to get a quote on a repair.
Just purchased a 32 gig ipod touch . the unit
It appears as though you are attempting to charge the ipod with a cable that is not compatible. Some newer ipods cannot be used with older chargers and adapters for cars. Apple does this to maximize their profitability and in my opinion rip off consumers.
My daughters new ipod will work on her old FM adapter in my car but it says it does not support it on the ipod itself. It will transmit through the wire, but will not simultaneously charge it as the older ipod did both.
It is similar to cell phones and batteries. If you own the original razor and upgrade to the next generation razor, the usb connectors are different (hence the chargers will not work) and the battery connections are different so you cannot interchange batteries between the two. Even though you would think Ipods are Ipods and everything should be interchangeable, they are unfortunately not.
I hope this helps and good luck!
3answers
Jamo i200 doesn't charge iPod Touch
have you tried changing the charger or charging it through a computer. some chargers are too outdated for the ipod to charge!
I have an Ipod Classic ( the newest version). It hasn't given me any problems until I let my friend use my Itunes to put msic on his new Ipod shuffle. Worked fine for him but now my computer wont recognize...
Try unplugging and plugging it back in, this happens to every ipod user once in a while. Try plugging it in a different USB port. Let me know how it goes.
2answers
Itouch charging
Some speaker systems which are only compatible for charging the ipod nanos and classics do not work with the iPod Touch and the iPhone, the internals are slighly different from one another which will not allow that speaker system to charge your iTouch.
To play & Charge your touch, i suggest getting a speaker system that supports the iPod touch platform.
Hope this helps ?!
GPX Docking Station for iPod
Check here:
http://www.gpx.com/store/p/214-SA308S.aspx
The pictue on MyCoke shows an iPod Touch but the same model on GPX's site shows a different iPod.
Ask the support team.
IPod mini vs Touch
I would buy a touch, the ipod mini is old and no longer made in the factory.
http://www.apple.com/ipodtouch/
 Grubhead
Grubhead
SmartAviator
SmartAviator
