Question about Jet 3 Ultra Power Chair
When I turn my chair on it shows me the level of charge by turning the little ligths all on, but as soon as I move the joystick at any direction it does a little sound like a breaker popping and the little ligths starts to flash all together, tree times in a row and then a rest for a couple of seconds.
  • 692 Answers
The code indicates bad left motor wiring or connection. Check the left motor wiring connector and if it looks ok then you will need to replace the left motor. If medicare paid for your chair they will pay for most of the repair cost. you can contact repair xpress @ 1-877-581-3733 or roadrunner mobilty @ 1-800-467-2668 these are two great repair companies that will bill Medicare for the repair cost. Hope this helps
Posted on Oct 10, 2010
Why does joystick light drop to red as soon as u move motor were done new cable and joy stick
The batteries are to weak to drive the chair. It takes a lot of battery power to start moving but not when you just turn it on. Using a volt meter in the charge port before and when you push the joystick will confirm this. Very typical of wheelchair batteries to do this when weak.
Sep 09, 2014 | Health & Beauty
I have a Quickie S646SE wheelchair with a Qtronics Pilot+ romote controller. I charged the chair last night. When I turned it on today the profile lights scroll left to right and the chair does not move. I...
Press and hold power button til beep then push joystick forward and hold joystick til beep then pull the joystick back and hold joystick til beeps. turn power off then on. should be unlocked now
Mar 17, 2014 | Quickie Wheelchairs Quickie S-646 Power...
Battery level indicator continually flashes when turned on, chair does not move.
Not much info to go on, but you may be in Lock Mode. On a VSI the Profile LEDs scroll left to right.To Unlock a VSI: Push joystick forward until beep, then pull joystick back until beep. Unit is now unlocked.
Mar 09, 2013 | Health & Beauty
I charged the batteries for 12 hours and then turned the chair on. The batteries appear to be bully charged, but the chair will not move. The joystick is flashing 8 times. Apparently a joystick fault? ...
There isn't too much you can do to fix this problem. You will have to have the joystick replaced. If Medicare paid for the chair then they will pay for most of the repair costs contact the provider that sold you your chair to have them order a joystick from Pride and repair the chair for you Hope this helps
May 04, 2011 | Pride Mobility Products Pride Jazzy 600
CHAIR IS CHARGED UP BUT WILL NOT MOVE
ajnss I need more information. can you turn the power on at the joystick? are you getting all the lights for battery level lit? are any of the lights blinking on the joystick? do you hear a clicking noise when you try to move the chair? Give me as much info as you can thanks
Feb 05, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Do not know if chair is taking a charge lights just keep moving across armrest .how do u tell when fully charged?
hi let me see if i can help ,
When the lights go back and forth on your joystick that means the chair knows its pluged in .Now the chair itself has a built in charger that is mounted on the back of your chair .The back of the chair ,there is a opening a cutout in the frame .when you plug in your chair there will be a red light and a yellow ,yellow means the chair is charging, wait till it turns green,this means fully charged.When you plug in the chair youll see the lights through that hole.Look for the lights.
I recommend my customers to leave there chair charging over night look at the light it will be green when you turn the chair on the joystick should show fully charge.
Good luck hope i was of some help.
Jan 20, 2011 | Invacare Supply Group Invacare Pronto M51...
When i plug in the charger the led light stays on green but on the joystick the lights are moving back and forth as if it is charging but wheelchair does not move
Joy When you plug in the charger the lights on the joystick will scroll because of something called charger inhibit which disables the joystick when charging It is a safety feature. Now when you disconnect the charger turn off the chair and then turn it back on you should then get all the battery lights indicating the charge level If fully charged all the lights will be lit. If after you unplug the charger and you still get the scrolling lights then you have a problem with the charger inhibit function in the joystick and it will have to be replaced. Hope this helps you
Sep 25, 2010 | Quickie Wheelchairs Quickie Aspire Power...
How do i get my power chair going after its all fully charged? wat do i press to turn it on get it going?
press the top button on your joystick the lights on the joystick will come on showing battery charge and speed wait about 5 seconds then push the joystick forward and away you go I would suggest placing the spped on slow until you get used to driving the chair
Aug 15, 2010 | Golden Technologies Alante' Power Chair
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
Jet 3 Ultra Power Chair Logo
99 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
MobilityRepairSpecia...
Level 1 Expert
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
