Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
The T.V. will not turn on. The red light flashes six times?
    Scholar:
  • 143 Answers
Read this post and see if any of this will help! http://www.fixya.com/support/t496045-sony_fd_trinitron_wega_kv_36hs500 Good luck!
Posted on Oct 10, 2010
Morning, it flashes red light six times
From the manual:
Press the (ON/STANDBY) switch to turn on the projector. If
the power is not turned on, disconnect the AC power cord, then
confirm the ON/STANDBY lamp is turned off. After about 10
seconds, reconnect the AC power cord and turn on the power
again. If the indicators still light up, the electrical system has a
problem. Consult with qualified Sony personnel.
Jul 08, 2016 | Sony VPL-VW95ES Full HD 3D Home Cinema...
Red flashing after tv turn on for KDS-R60XBR1
How many times does the red light flash before it pauses and then starts again? This is important info as it helps to diagnose your problem.
Mar 20, 2013 | Sony Grand WEGA KDF-55WF655 36" Rear...
50PF9631D won't turn on... red light flashing/blinking 6 times
Your TV main board is damaged and you need a new one. You can order one on ebay and fix it yourself. Make sure you have the TV model/serial number on the back label of the TV to have the right part when ordering.
Jan 09, 2013 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Tv will not turn on, red flashing light comes then turns off
tv will not turn on, red flashing light comes then turns off.
light flashes six times.
Aug 15, 2012 | Sony KP-53HS30 53" Rear Projection...
My sony won't turn on. when I use the remote to turn on it flashes green six times, I hear a click and then it flashes red six time.
six times means the thermal fuse on top of the lamp tripped. Replace it and give it a good cleaning and it should work.
Feb 20, 2011 | Sony Grand WEGA KF42WE610 42" Rear...
My tv (32PF321D/37) won't turn on and the power light is flashing red six times, pausing, then doing it again. Any ideas?
Check bulging capacitors in power supply that causing 6 red LED flashes. Replace them and fix the problem. philips-32pfl5322d-37-04.jpg?w=770
Feb 01, 2011 | Philips 32PF7321D 32 in. LCD Television
MY wega 42inch wont turn on...the little green light flashes like five time as if it where to turn on but never does...and then it turns red and flash six times pauses and then again the red light flashes...
Six blinks indicates a faulty power supply. often caused by open thermistor located at under lamp assembly or beside it. Or a defective regulator on power supply section.. Check the thermistor and replace if found defective.. Or contact the nearest Sony service center at your area.
Oct 01, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
TV does not turn ON and red light keeps flashing six times stops reapeats again with six times red flashing
Sounds like a power supply issue. order a new power supply or trouble-shoot the current. Look for any capacitors that are bulged up on the top and not flat.
Jan 29, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Will not power on, red light flashing six times
the problem is in the power supply most likely. The overvoltage protect circuit is causing you not to be able to turn the tv on. This is common to all tv's. Solution unfortuantely is get another tv unless you know someone who can either work on or replace the internal power supply
Jul 01, 2009 | Sony KP-61HS30 TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
27 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
