Question about Sharp LC-46D64U 46 in. LCD HDTV
My Sony LCD HDTV flat screen just went blank while I was watching this Morning.I tried all the steps in trouble shooting, like reseting it and unplugging it for one min .Nevertheless all these steps didn't work. the red LED stanby light keeps blinking. If I put it on it goes back to the stanby light which keeps blinking.Please I need help!!! The model is Sony LCD Digital Color TV , Model:KDL-523000.
    Top Expert:
  • Sharp Master
  • 24,709 Answers
The count of the led gives a code to tell you where the fault is.
Posted on Aug 05, 2017
SOURCE: Sharp aquos lcd screen goes blank
i was having these same problems with the screen going black, and i found that when i hit the back of my tv it would work sometimes. so, i improvised on some of the advice on this page and so far no problems. here is what i did (its very easy):
1. lay the tv on the floor and take off the back panel. (i think 12 screws)
2. on the right side of the tv (as you are looking at the back) you will notice a large metal covering that is held in place by 6 screws. unscrew these and remove the metal cover.
3. you will notice that the three screw holes on the left side of the board have some sort of metal or solder around them, in sort of a star pattern. when i looked closely i noticed that most of the metal (solder) was tarnished, or kind of blackened. (this must mean that the ground screws werent getting a good connection and this would explain why it would work sometimes when i hit it because it would vibrate the screws enough to get a good connection! )
so, take a pencil eraser and erase all the black or tarnish off the metal surrounding the screw holes. thats it! (to be safe i took some sandpaper and cleaned up the screw holes on the back of the metal covering, but i dont know if that was necessary)
at this point i followed another gentleman's advice to do a hard reset. this involved unplugging the 8 connections although i dont know if this was really necessary because i believe my problem was a ground issue. i did it just to be safe. his advice is on this site if you want to do this step.
4. i put everything back together and it worked! i performed a soft reset at this point which puts your tv back to factory settings. just go to menu>setup>reset>return to factory settings? yes
this will turn your tv off and back on. that's it. so far so good for me.
Posted on Dec 18, 2008
SOURCE: Blinking green power light
I had the same issue after one month of use. A repair cie came and fixed the problem. It appenned to a neon connector that wasn't properly plugged in the TV.
The Technician explained to me that m TV had 16 neons and a sort of controler for those. Often - from factory - a cable is not sitting properly in its position...
Since I have no problem.
Posted on Mar 03, 2009
  • 1779 Answers
SOURCE: need replacement 32 inch screen for sony lcd model
Cost of the screen will be in the $1100.00 area. That is your Display Panel..
Posted on Jun 13, 2009
  • 5 Answers
Most of you that are having problems,it has nothing to do with your screens themselves,but with the capacitors in the power supply,the caps,over heat and the tops pop out and the dry out and are no longer any good,a soldering iron,solder,and flux are really all that is needed to repair this problem,get good caps at radio shack,or equal location,pay attention to polarity on the two contacts on the bottom of the caps,replace all that are poped up
Posted on Jul 19, 2009
  • 8457 Answers
SOURCE: How to color balance the KDL-52'XBR9 HDTV
Reset the colors back to factory setting.Turn down the colors about 40%.That should look good tries it.
Posted on Jan 16, 2010
I have sound but no picture can you assist
power supply trouble check caps and inverter board.
Feb 12, 2014 | LG 42LG50 42 in. LCD HDTV
Sony Bravia - no picture, no sound. Just a blank screen. We were watching a show and the screen went blank and no sound.
First thing to try: unplug from the wall; count to ten; plug back in; try again
Second thing to try: unplug from the wall; count to 10,000 (or wait 10 minutes or so); plug back in; try again
#1 worked for me when it would power on with no video, no sound, just small green light + white logo
Dec 06, 2010 | Sony KDF-E42A10 42 in. LCD Television
When watching TV, the picture is only in the center of the screen, but when watching a DVD, it fills the whole screen. How do I make the TV shows fill the screen, too?
`Simple, just hit the Zoom button on your remote control (of course, I found this by chance as no where in the instruction booklet does it trouble shoot this one for you). Hope that works for you.
Sep 23, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I was watching tv and the screen went blank. It
You would have to try an INIT and see if it causes the tv to be operational again. It is something that you have to be walked through step by step by step and can erase the memory of the tv if done improperly. Call Sharp tomorrow morning at 9AM CST and someone can walk you through one. Call 800-237-5277 or if you have an aquos advantage model call 87-332-7867
May 15, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Rca L32hd31 lcd no picture blank screen.
Your mainboard is damaged, replace it and that will solve your issue.
Jun 06, 2009 | RCA L32HD31 32 in. LCD HDTV
Screen has gone blank. Is this common? Fixable?
Contact us to join our group who is taking action for the same issue.
Jun 02, 2009 | HP PL4260N 42 in. Plasma HDTV
Blacking out for 20 seconds over and over
The lamp is going bad. Very common for some Sony to do exactly what you are describing.
May 18, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony Bravia TV went Blank
Jun 29, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
TV shutdowned while watching and it wont power up again..
just replace your Lamp. Thats it
best regards
Aug 25, 2007 | Sony KDF-E55A20 55 in. LCD Television
Open Questions:
See all Sharp LC-46D64U 46 in. LCD HDTV Questions
Sharp LC-46D64U 46 in. LCD HDTV Logo
186 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
