Question about Toshiba Satellite L25-S12 Notebook
How do I clear the Bios password on a toshiba satellite L305D-S5974. When it boots I get a blue enter password screen. I tried to short B500 leads under the memory but it does nothing. Any body know the backdoor password to H2 bios? My kid set a password and has now forgotten it.
    President:
  • 2,653 Answers
There is no backdoor password, you'll have to take it to an authorized Toshiba repair center.
You can find one here.
They usually charge about 100 to remove the password, BUT if you keep insisting that you didn't set the password they'll probably remove it for free shhhh ;)
Posted on Oct 10, 2010
Toshiba satellite L850 bios password reset
Under the RAM there is a jumper "B500" Remove the battery. power source and RAM. Link B500 for one minute.
Feb 27, 2014 | Toshiba Satellite L850-ST2NX1 : Laptop...
I cannot restore the operating system on Toshiba L305D-S5974. I keep getting the BSoD with different codes. I have also flashed the bios to reset it to factory settings since I could not remove the CMOS...
Sounds like a potential memory problem. If you have two sticks, remove one and see if it clears up; then try the other. If not, download on a friends computer memory test from http://www.memtest.org/
Create a CD and try it on your computer.
Hope this information will help.
Your response is very much appreciated...Thank you for using Fixya...
Sep 26, 2011 | Toshiba Satellite L305D-S5974 Laptop
My bios password is unknown and i can not access the actual settings. i can however boot into windows.
Normally, Toshiba may have a default password such as "toshiba", try that first.
If not successful, then power down the laptop, remove the battery for about 30-45 minutes, then power back and go into bios, the password should be gone.
It is important to remember that with this method, the bios goes back to factory defaults and the time and date may have to be reset.
It neither do not remove the password, then the bios has it's own battery and would have to be accessed and removed to clear out the password. I do not recommend this option unless you
are knowledgable about disassembling the portion on the unit to get to the battery.
Good Luck
Aug 25, 2011 | Toshiba Satellite L305D-S5974 Laptop
Hello, When I tried to reinstall windows on a formated drive, after I changed the boot sequence , before starting bios it requires a password. Plese help
Easiest way is to reset the BIOS. If you remove the battery, and leave it unplugged and without it's main battery and BIOS battery, it should clear it.
This is another reply posted by another tech:
Toshiba A215 Password Removal By purpledog1 on Aug 18, 2008
Follow these steps to remove / disable the BIOS (CMOS) Password on the Satellite A210 / A215 (PSAFGx ) models:
1. Turn the computer OFF, if it's on.
2. Remove the memory module cover, on the bottom of the computer.
3. Check the configuration of memory modules in the two sockets. It's necessary to have a memory module present in the outermost socket only.
  • If there is a memory module in only the outermost socket (the one farthest from the system board), then continue to step 4.
  • If there is a memory module in only the innermost socket, move it to the outermost socket.
  • If there are memory modules in both sockets, remove them both, then re-insert one of them into the outermost socket.
4. With the computer oriented as in the photo above, carefully peel back the black Mylar film. Pull this film to the side enough to expose the B500 solder pads (see photo below). Tape the film to the computer's case, as shown. Do not remove the film completely, because it may be difficult to re-attach it correctly.
5. Short the B500 solder pads on the system board. Needle-nose pliers or a flat-blade screwdriver works well to short them.
6. While continuing to short-circuit the solder pads, turn the computer on, and continue shorting the pads until the Toshiba Logo Screen disappears.
7. Re-position the Mylar film over the system board.
8. If you removed a memory module, turn the computer OFF, then re-insert it.
9. Re-attach the memory slot cover.
10. Restart the computer to verify that the password prompt no longer appears. If it does still appear, then repeat this procedure, starting with step 1.
Jul 26, 2011 | Toshiba Satellite A215-S4747 Notebook
I Cant get my toshiba satellite L305D-S5974 to load. I get either a blank screen with curser arrow or message that says: no bootable device -- insert booth disk and press any key. Can't find any of my...
The laptop is not seeing any hard drive. remove the panel underneath (2 screws) and remove and refit the hard drive. If it still does not work then enter the bios by hitting the F2 key while booting and look at that page. under HDD model name and hdd serial number there should be information on the drive. If there is such info then the drive is being seen but cannot be accessed. Anyway it looks like the drive has had it. You will need to find your windows disk when you fit a new drive and reinstall windows.
Apr 27, 2011 | Toshiba Satellite L305D-S5974 Laptop
Hi, I have a problem with my Toshiba Satellite L305D. I clear a BIOS password, and I need the built-in HDD passwoard. Could you help me please. Thank you.
Hi
if you have just cleared the bios password
i think if you go back and do the same for the hdd password it should work
power up pressing F2 then use arrow keys to go to security and click on hdd password
and try to disable it
Feb 01, 2011 | Toshiba Satellite L305D-S5914 Notebook
How can I replace the screen bezel clips on my toshiba satellite L305D-S5974 laptop?
The cheap way is do not replace them Get some clear silicone and sparingly put silicone in their place.
The right way is to replace the bezel which comes with the clips. I found one here for $32.95 plus shipping.
http://www.laptoprepairparts.com/html/LRsearchmodelresults.asp?brand=toshiba&model=L305-&txt=Satellite L305 Series#case
Hope this helps
Apr 04, 2010 | Toshiba Satellite L305D-S5874 Laptop
How do I clear the CMOS password on my Satellite
To remove the bios (cmos) password, With notebook turned off;
Open Wi-Fi Cover that's located under the laptop and remove the WiFi card, locate & Short Out pin JP1 for 15 Seconds, or short out pin G1 for 15 seconds.
Sometimes you have to short the pins out while turning the laptop on.
The power on (bios) password will now be cleared so you will need to enter the bios to input the date and time.
Regards.
Dec 02, 2009 | Computers & Internet
Toshiba Satellite L25-S12 Notebook Logo
742 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
