Question about LG DLE2532W Electric Dryer
My clothes won't dry. It is getting hot, but I have to run it 3 or 4 times to dry anything. I can't figure out where it vents out either. My dryer backs up to a closet, not outside. Couldn't find the tube in the attic.
    Sergeant:
    Champion:
  • 351 Answers
Hi check your vent make sure it clear
Posted on Oct 10, 2010
CLOTHES WONT DRY. IT GETS REALLY HOT INSIDE. THEY SEEM WETTER AFTER IT RUNS FOR AWHILE. TAKES PROLLY 3 HRS TO DRY.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
May 22, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
Dryer runs fine does not dry proper run 2 or 3 times and still damp clothes vent was not clogged pl,ease help
this website is very helpful, I would disconnect vent tube and dry a load of clothes, if they dry then my vent tube is restricted or too long. If it does not then my dryer needs to be cleaned out on the inside from the lint trap down. I hope this helps Tim
http://www.applianceaid.com/general.html#vent
Nov 29, 2010 | Whirlpool WED5500S Electric Dryer
My clothes come out wet after running for a length of time but they are hot
You have an vent issue..If the clothes are hot but not drying your not getting proper air circulation, you need airflow thru the unit to help remove the moisture from the clothing other wise you end up with warm moist clothing... Start unit and go outside to where the dryer vent comes thru the wall and check the airflow with your hand ,you should feel a good flow of warm air. If not some where between the unit and the vent their is a restriction either in the flex duct or the duct work in the wall which will need cleaned out before the clothes will dry in a normal time frame..Plus it cost a lot to run the dryer 2 or 3 cycles to dry clothes Hope this helps Good Luck
Aug 26, 2010 | Maytag Dryers
Dryer gets hot close wont dry cleaned vent as well
how long is the vent run,anything over 15 feet will slow drying process
Mar 18, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My dryer runs and gets hot but cloths don't dry.
Your problem may be attributed to a clogged exhaust system (e.g.: clogged inside the dryer's vent, flexible vent behind dryer clogged and/or clogged inside wall, etc.).
Feb 22, 2010 | Whirlpool GEW9250 Electric Dryer
My Kenmore series 70 dryer heats up but takes 3 times on 70 minutes to dry the clothes. After every 70 minute period when i check the clothes i open the dryer and it is like a steam room. It is getting...
Check your dryer venting for obstruction.  Take the vent hose off and run the machine,  If it works with the venting disconnected, It is between your wall and the outside of the house.  If it still has the same problem it is somewhere in the exhaust.  If the dryer can't circulate air, nothing will dry.
Dec 04, 2009 | Dishwashers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
My dryer will not dry,eventhough the dryer gets hot
Your exhaust vent on the rear or the connecting vent to the outside if blocked with lint.
Remove the vent from the rear of the dryer and run a timed load at 40 minutes.
If it is dry your problem is with your connecting vents.
Mar 22, 2009 | Maytag Dryers
LG DLE2532W Electric Dryer Logo
321 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
