Question about Dishwashers
Water is standing in the bottom of the dishwasher.
  • 5,081 Answers
Since the drain pump will pump the water out using the "cancel/drain" button, if it did not work then your problem is likely to be in the drain hose system or the garbage disposal downstream from the drain pump. Check for kinks in clogs in the drain hose. Grease can build up in the portion of the drain hose just before it attaches to the garbage disposal.
If you are having problems getting the water to drain out of your dishwasher then there are a few things that you need to check out.
First check the drain hose that it has not gotten pinched anywhere. Then check it to see if it may be plugged with dirt and debris. If you have it hooked to a garbage disposal make sure that the hole into the garbage disposal is open.
If all of that checks out, then check the screen inside at the bottom of the dishwasher. Excessive food buildup will block the flow of the water into the pump.
If that is clear then you may need to remove the bottom rack, and the bottom spray arm. This will allow access into the pump. Some dishwashers have a diverter flap that opens to allow the water into the bottom impeller, which is the pump out impeller. Also check that the bottom impeller is in good shape and not deformed. The switch that operates the diverter flap can also go bad. You need to check that it can operate and that is does if power is applied to it.
By checking all of these things you should be able to find your problem. You may have to take the time to eliminate the problems one by one till you get to the cause of your problem.
Check the below link for an detailed description
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
COURTESY:
heatman101 -A senior Expert in fixya..
Posted on Oct 10, 2010
Water stands in the bottom after washing
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Aug 29, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
Standing Water
Here is a tip that I wrote that will help you with your problem...
heatman101
May 06, 2010 | Dishwashers
After drying there is water in filter trap is this normal
IF THE WATER IN PORTABLE DISHWASHER AT THE BOTTOM IS MORE THAN THE DRAIN HOSE FULL OF WATER THEN ASK WARRANTY PEOPLE. WHEN PUMPING WATER UP IT CAN ONLY PUMP SO MUCH WATER OUT OF HOSE BEFORE THE WATER DRAINS BACK INTO DISHWASHER.-- HOPE THIS HELPS
Mar 08, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Standing water in dishwasher
This is because you have a problem with the diswasher pump and/or pump motor. There should NO water standing at end of cycle.
Sep 20, 2009 | Tappan Dishwashers
Standing water in bottom
None. You have a problem with either your pump and/or pump motor.
Sep 20, 2009 | Tappan MDB531RF Dishwasher
Tappan Dishwasher w/ Standing water
Try draino first then take it apart on the inside bottom to see what might be clogging it.
Aug 04, 2009 | Dishwashers
Trouble shooting kenmore dishwasher
I have a kenmore ultra wash II Model #1675590 Serial # FC1024731
Will not run and water is standing in the bottom. I have checked the electrical breaker and tried different cycles. Can you help.
Oct 03, 2008 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Standing Water
are you leaving it long enough to finish it's programme or are you opening it when the drying light is on as some dishwashers leave a bit of water in the bottom to help with the drying programme
Dec 08, 2007 | Dishwashers
Dishwashers Logo
37 people viewed this question
Top Dishwashers Experts
Owen Barnes
