Question about GE Refrigerators
I have a GE Model PSC23MG Refrigerator. The freezer section does not get cold enough. Starting several months ago the refrigerator was noiser than normal. I appeared that the noise was coming from the evaporator fan in the freezer section. The excessive noise stopped a month or so ago but it sounds like the evoporator fan is still running. The temperature in the freezer is barely cold enough to freeze items in the freezer. This also has caused problems with the ice maker because the ice partially melts and becomes a big ball of ice.
docjohn174
  • 943 Answers
SOURCE: fan in freezer - evaporator fan?
HI. thanks for the question. yes the fan in the freezer must be replaced.and also the drain tube in the freezer, is clogged. cut power to the fridge. remove back panel . replace the fan motor . also clean ice build up. clean drain tube, from freezer to the drain tray, at the back, near the compressor. thanks the appliance doc. please rate my answer. thanks
Posted on Oct 07, 2008
jumptrout51
  • 3361 Answers
SOURCE: the refrigerator section is not cold
Replace the freezer fan motor.
Posted on Feb 21, 2009
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    • 97 Answers
    SOURCE: GE Refrigerator/Freezer not cooling
    Loss of coldness is common with compressor related problems....relay and overload(simple fix), loss/leak of refridgerant(need a cert. tech). need to check the compressor and see if its running....do this by pulling the unit out and removing the back panel, place your hand on the compressor and see if it feels like its running....if not probably just a relay, if it is running, could be a more serious problem dealing with sealed system.
    Posted on Jun 10, 2009
    Sea Breeze
    • 4654 Answers
    SOURCE: Amana Side by side refrigerator/freezer barely cold
    I am having trouble finding any of the numbers you listed. Where is your location, USA, Canada, UK? I can possibly help if you can email me at appliancepartsse@yahoo.com web site http://servicepartstec.blogspot.com/ Phone 864-812-1887 leave a message if not answered then leave your name and number I can make international calls if needed, Thanks, Sea Breeze
    Posted on Jun 11, 2009
    Freezer fine, fridge not cooling
    This sounds like a small Freon leak. It could come from cleaning the coils, or movement by the compressor. A technician with a gas tester (locator) can find any small leaks and repair that section. The cost is not excessive and a new unit is over $1000, so consider the options.
    Mar 10, 2014 | GE GTS22WCP Top Freezer Refrigerator
    GE fridge/freezer on but no cold air
    The main board on the back of the unit has gone bad or in lockout. Try unplugging unit for about 30 seconds. Then plug it back in. If it doesn't start the board is bad. wr55x10942 at about 169.00. Hope this helps. Very common GE problem
    Mar 07, 2010 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
    I have a model GSS20DBMD side by side model,It has frost on the back of the freezer and the temp is not cold enough to freeze water in that section, also, the refrigerator side is not cold enough . the...
    You must replace the defrost heater and defrost thermostat inside the freezer. Remove the shelves and bins,then remove the rear panel of the freezer to access the parts.
    Sep 08, 2009 | GE Refrigerators
    Freezer is cold but not keeping icecream frozen.
    If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
    Aug 27, 2009 | Refrigerators
    Roper fridge is not cold enough now.
    Check the back wall of the freezer.
    Is it iced up?
    If yes, replace the defrost parts.
    Mar 10, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
    HOTPOINT/GE REFRIGERATOR NOT DEFROSTING
    I have the same problem. A lot of people in forums are telling me it could be the defrost heater. Anyone know how to test it?
    Jul 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    Ge side by side not cold enough in fridge or freezer
    if there is no frost build up in freezer section sounds like a refrigerant leak
    Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    Refrigerators Logo
    Top Refrigerators Experts
    Sal DeAngelo
    Charles T Nevin
    Charles T Nevin
    Andrew Taylor
    Andrew Taylor
