Question about HP LaserJet 4si Printer
HP 4si keeps jamming
I have been printing large amounts of reports recently that went through fine. Now the 4si keeps jamming everytime. I am clearing everything out...making sure there are no "pieces" left behind, but still it is jamming as it is just coming out of the tray.
  • MonicaTess May 30, 2008
    Have cleaned the rollers, too
  • K L'Heureux May 11, 2010
    perhaps the tray is out of alignment?
    President:
  • 173 Answers
This pdf might be useful, it will show you how to change the rollers. Hope this helps and let us know if you need further assistance. if the pdf does not open you can find it at this link, it will be the very first link which will open the pdf.
Posted on May 30, 2008
  •  Bobby
    Bobby May 30, 2008
    Sorry it will be at this link
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
I have a jam on my printer that says there is a print carriage access jam how do i solve it
I have the same problem.... trying to use lubricants and done some cleaning, but no luck... till i found out that using an extension cord with several devices plugged in will lessen the amount of current that flows to the devices.. that's why the printer's motor can't able to do his job because of no enough power.... Connect the printer's plug directly to the wall...
it works for me....
---ritchie---
Jan 13, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Hp printers continue to jam
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report .
IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue. Solution one: Clear the paper jam Follow these steps in the order presented to resolve the paper jam. Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism
Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Constant paper jam
It appears to be the printer it self is malfunctioning and may require service. Please call your printer manufacturer and ask for warranty.
Aug 14, 2009 | HP PhotoSmart C4280 Laser Printer
HP G85 PAPER JAM ERROR ,but still prints from scanner fine
Remove the rear cover...clean the rubber rollers with alcohol
Feb 17, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
Paper Jam Photosmart C3180
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | HP Photosmart C3180 All-In-One InkJet...
Paper jams every time
does the same doc jam or all docs jam ?
on the first page or there after ?
Sounds like your printer may need a normal clean and service...
any decent printer repair company does this for a very reasonable fee...
Dec 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP 4SI print black page
hi,,
try to replace a different toner of your printer..
Oct 29, 2008 | HP LaserJet 4si Printer
Wont print properly
63 NEEDS SERVICE ليزر جيت 4
Jul 17, 2008 | HP LaserJet 4si Printer
How to cancel job in buffer
Hi Try disconnecting printer cable and printer power cable for at least 1 minute.
Should reset to default.
Good Luck!
Tinteiros (Ebay)
May 29, 2008 | HP LaserJet 4si Printer
Open Questions:
HP LaserJet 4si Printer Logo
122 people viewed this question
Seeker5211
Seeker5211
