42" tv My 42" plasma tv keeps getting a black line down the centre of the screen, it comes and goes but is there more often than not. Is this repairable do you think? I'd appreciate your comments Thanks Keith
  • Anonymous Jun 24, 2008
    Ours seems to go away when the humidity is high in the house such as when we are washing and drying clothes.
  • 2,322 Answers
If this is intermittent, it could be a loose connection on one of the flex cable that connects the digital control board to the screen that is located under the audio/video assemblies.
Posted on May 30, 2008
Have a black line coming straight down centre of tv
Bad tab bond. try twisting the tv by holding the top corners and lightly twist to see if it comes and goes
Aug 08, 2012 | Hitachi 42HDS69 42 in. Plasma Television
I HAVE THREE BLACK LINES AND A YELLOW VERTICAL LINE DOWN THE CENTRE OF MY SAMSUNG 50" PLASMA TV. ONLY 10 MONTHS OLD! WHAT CAN I DO?
The TV should be still under warranty. Most of the flat panel TVs come with a one year warranty from the manufacture. I wouldn't mess with the to void the warranty.
The problem most likely is the buffer/scan boards on the bottom connected to the screen. It controls the vertical image on the screen. The other possibility is the plasma display panel is bad.
Go the warranty route first. This may get expensive to fix.
Apr 01, 2010 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Random 3'' vertical red line on 42'' Hitachi Plasma TV
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.////
Sep 04, 2017 | Hitachi 42HDS69 42 in. Plasma Television
Have LG 42 inch plasma, 1 inch black line down center of screen, picture good other than black line blocking center of screen, comes and goes sometimes
Sounds like the middle scalar board is defective. Since the issue comes and goes it could just be a loose connection to the between the scalar board and the PDP Module (plasma panel).
Great caution needs to be taken when checking this connection because it is a ribbon cable connection it and needs to be put in correctly aligned or it could cause a short in one of the circuit boards.
Oct 07, 2009 | LG 42LC2D 42 in. LCD HDTV
Black line in centr of Screen
sounds like a bad panel, try reseating any cables you can on the buffers . the buffers would be on the lower edge right where the black line appears. unfortunately Vizio does not supply panels.
E
Jul 28, 2009 | Televison & Video
Sky PDS4250 42'' Plasma TV - Black line down centre of screen
not sure if this is the fix or not ...but i was tryin to fix a problem with my tv(not the same as yours)...but in the menu under adanced you can split the screen ....when i do that it puts a blue line down the middle of the screen
Dec 04, 2008 | Protron PLTV-4250 42 in. LCD Television
Black lines on plasma
The matrix controler or the matrix drive area is failing. The fix is to change the proper circuit boards, and then do the factory setup to match the board is necessary. In the worse case, it may be the display screen itself that has a failure occuring.
You will have to bring the set for factory service to have the work done. If the set is out of warranty, it may be expensive to service.
Jerry G.
Apr 12, 2008 | Hyundai ImageQuest HP4240 42 in. Plasma...
Black line down the center of screen
Usually this means pixel, but I would question if the line is mostly near right side or left side of screen? If more to one side this could be a bad board inside. for more info ctechnicians.com
Dec 31, 2007 | Hitachi CMP4201U 42 in. HD-Ready Plasma...
Sky 42 inch plasma tv
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Sep 06, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
199 people viewed this question
Top Televison & Video Experts
Electro Med Services...
