Question about Toshiba 57HX81 57" Rear Projection Television
Bad picture until tv warms up
When we turn on our tv you can't see a picture-or atleast it is so bad you can tell what it is. Wavy, squiggly vertical lines-then about 5 min later the picture is great. I wanted to find out if it is a easy fix or do we just use it till the tv dies and it's not worth fixing. Toshiba 65H81 - I have the same problem. It takes about 5 minutes to clear up. Works fine on HD channels though. Pics from DVD have the same problem. This has been occuring for about three months. It is almost 6 years old.
  • gurubilltosh May 31, 2008
    I am mainly intrested in trying to determine how much longer the TV will last. I could probably replace a board if I had too. The 23786217X deflection board was replaced last year (TV would not come on and the powere light continously blinked). This was on my extended warentry. I have figured out the problem does not occur in the 1080i mode.
    Genius:
  • 3,587 Answers
That's from an old and unhappy video control board..or the power supply or both
Posted on May 30, 2008
  • Patrick Michaels
    Patrick Michaels May 30, 2008
    you inclined to do this sort of repair yourself?
    Genius:
  • 1,142 Answers
Well its a problem fo an ic causing the issue that needs to be replaced
  • Maanita Chadha
    Maanita Chadha May 30, 2008
    please contact toshiba service center for the repair as this would include opening the set and locating the ic on the board that is faulty and replacing it with a new one
2 Suggested Answers
SOURCE: bad picture until tv warms up
Its bad surtace mount caps in the hyper board.I dont know which ones .Any ideas out there ?
Posted on Jul 08, 2008
24af45 from top to bottom picture is wavy until set warms up
Check and replace all the electrolytic capacitors at its vertical scan output stage circuit. Replace all of the once.
Apr 04, 2013 | Toshiba 24AF45 24" TV
Hello..Toshiba 51HC85, 2005 model. Turn on TV and verticle wavy lines appear until TV is warmed up completely. After warm up the picture is great again. Any ideas?
I've had the same problem for about the last 6 months. My workaround which was to leave the tv on 24 7 and just turn off the TWC service box. But now the symptoms are vertical dark lines going all the way across screen. My guess is that it will cost more to fix than worth it. I paid @$2000 for it new in 2004. Technology has gotten better so I may just go out and get a Samsumg for considerably less and be way better off. None of Toshiba's products had done well for me. 2 laptops, 3 tvs, etc. have taught me this.
Sep 20, 2010 | Toshiba 51H83 51" Rear Projection...
Start up problem
Bill;
Cause 1
1. VERTICAL ROLLING, VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE, ALSO MAY HAVE HORIZONTAL PULLING OR TEARING. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB.
2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Replace all these if they look bad or not. If you can't do it yourself call a service Company and get an estimate, it should cost about $450 if they know what they are doing.
Thanks using FixYa, Big Irish.
Nov 21, 2009 | Mitsubishi VS-50705 50" Rear Projection...
I have a Toshiba projection tv (46H84). When I
Yes!!!
You need to open the case, then remove the board from the unit, then check all the circuit, probably there's damaged circuit connections, use soldering iron to fix this problem....
Oct 18, 2009 | Televison & Video
I have a Sony KV-27S36 purchased mid to late 90's. I suddenly have sound but no picture. At first, I could get a picture by turning it off and on and letting it warm up, now I cannot even do that. ...
yap! That sound vertical problem! just solder all old parts in vertical section and check yoke if have mold? Check all looking old's electrolytic capacitors and change that if nothing happened tha'ts the time to change vertical IC.
Sep 24, 2009 | Sony KV-27S36 27" TV
About two months ago when we first turned on the TV there were wavy lines across the whole picture. When it warmed up they would go away. Now, the lines are there almost all the time and it's getting...
hi
You are experiencing a lack of vertical deflection or vertical collapse. Since it will come back the first thing I would suspect is “ring cracks” in the solder joint in the vertical circuit, mainly the vertical IC. These suspect solder joint can be re-soldered and the television set repaired.
I would suggest that you contact a local servicer. If you are repairing the set yourself, be careful, there is always a risk of shock when dealing with electronics.
OR
Check your equipment connections. Disconnect your equipment (VCR, DVD or set-top box) from the TV and reconnect, making sure each connection is in tight.
OR
chek this site,i blieve u will b helpfull
http://www.dshosu.com/how-to-fix-toshiba-rear-projection-hdtv-wavy-lines/
regards
Jul 01, 2009 | Toshiba 57H82 57" Rear Projection...
Apex GB4308 43" tv have to set convergence each time I turn it on
Replace your STK ICs and look for Bad capacitor by vertical IC 100uf 35v.
Jan 14, 2009 | Apex Digital GB4308 43" Rear Projection...
this is a very common occurance in these sets. toshiba has issued a servece bullteen with this set. Sorry to tell you this but this is a problem with some very small capacitors on what is known as the hypermodule. in my shop we fix 2 to 5 of these a month. you really have to know how to solder. Idealy replace the hypermodule is the best way. but......that board is hard to find. so we replace these 11 very very small componets with twezzers and a big magnifier. we charge about 250 to 350 for this repair.
May 30, 2008 | Toshiba 65H81 65" Rear Projection...
Feb 24, 2008 | Toshiba 57HX81 57" Rear Projection...
Toshiba 57HX81 57" Rear Projection Television Logo
210 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
